Rust issue?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TAC1, Jan 27, 2013.
  1. Jan 27, 2013 at 1:07 PM
    TAC1
    TAC1 [OP] Well-Known Member
    Tac1
    Miami, FL
    2015 DCSB O/R 4WD
    Hello Forum,
    I washed my '08 DCSB this morning & noticed this under the right lower corner of the rear window:
    This is the left lower corner of the rear window:
    Is this something for me to be concerned about or am I making a big thing out of nothing?
    Is this an easy fix?
    Can I do anyhting to stop it from growing?
    Thanks
  2. Jan 27, 2013 at 1:10 PM
    82 yotaman
    82 yotaman H.O.G Hunter Of Gunman
    BUBBA
    Wyoming
    1982 toyta pickup/2013 toy MGM dcab 4x4 trd
    avs bugshield, avs inchannel vent visors, weather techs, trd shift knob, tailgate theft mod, windows tinted to 20%, wet okole front and back and black level 8 guardians wrapped in 265/75/R16 Duratracs oil catch can mod interior LED's, pop & lock pl5500, Leer 180 topper, OME full lift with Arb bullbar
    I would take it to the dealer cuz to me the first pic looks like rust under the paint could be caused by leaky window seal or something like that if it was my truck I would be taking it in first thing
  3. Jan 27, 2013 at 1:15 PM
    jandrews
    '09 FourDubDee TRD OR
    Fuck the dealer, he's out of warranty.
    OP, find a good body shop and get an estimate. Hopefully that area hasn't rotted too much and it can be relatively inexpensive to repair. Definitely get it checked out. The nastiness could go quite a bit further than what you see.
  4. Jan 27, 2013 at 1:16 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    I would wonder why there is a crack there
  5. Jan 27, 2013 at 1:17 PM
    jandrews
    Either impure metal or poor metallurgy.
  6. Jan 27, 2013 at 1:30 PM
    82 yotaman
    BUBBA
    Wyoming
    his truck is covered against rust perforation for 60 months regardless of mileage take it in if not over that time frame
  7. Jan 27, 2013 at 1:34 PM
    TAC1
    Tac1
    Miami, FL
    2015 DCSB O/R 4WD
    I purchased my truck from a Dodge Dealership on January 3, 2012. I took my sons Dodge for service, saw the Tacoma & bought it. You think the dealership will still cover it since I am the 2nd owner?
  8. Jan 27, 2013 at 1:38 PM
    OZ-T
    Peter North
    British Columbia
    The only way to know that for sure would be to drive by your local Toyota dealership and ask
    IIRC , the perforation corrosion warranty is 7 years and transferrable , whether or not this qualifies I can't answer , but as others have said , whatever route you take , you should deal with it sooner than later
  9. Jan 27, 2013 at 1:38 PM
    jandrews
    Not sure that covers sheetmetal, but if it does, then agreed, go for the warranty.
    IIRC rust perforation warranty is frame/suspension.
  10. Jan 27, 2013 at 1:39 PM
    82 yotaman
    BUBBA
    Wyoming
    Yes they will cover it doesn't matter if your the second owner the rust perforation follows the truck for it's life unless older than 60 months so says the warrenty and service guides
  11. Jan 27, 2013 at 1:42 PM
    82 yotaman
    BUBBA
    Wyoming
    the warrenty book says, "This warrenty covers repair or replacement of any original body panel that develops perforation from corrosion."
  12. Jan 27, 2013 at 1:46 PM
    TAC1
    Tac1
    Miami, FL
    2015 DCSB O/R 4WD
    Yeah. I need to go to the dealership. I'll go this week for sure.
    Thanks
  13. Jan 27, 2013 at 1:51 PM
    82 yotaman
    BUBBA
    Wyoming
    No prob OP let us know what they say
  14. Jan 27, 2013 at 2:33 PM
    jandrews
    Good to know. I threw my warranty book away about 1 month into ownership. Thanks.
  15. Jan 27, 2013 at 2:36 PM
    Plain Jane Taco
    Plain Jane Taco Well-Known Member
    USA
    Hopefully this is not an indication that the truck has had some previous damage to it.
  16. Jan 27, 2013 at 3:16 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    That is in a seam that should be filled with a body seam putty. It looks like the putty was cracked and water got into it... It will get worse if unattended to. Hard to say but it appears to have had body work...
    Get it checked.
  17. Jan 28, 2013 at 1:40 PM
    TAC1
    Tac1
    Miami, FL
    2015 DCSB O/R 4WD
    This morning I read my manual and it has another booklet attached stating the warranties. I found where it states: 60 month/unlimited mile corrosion protection if there is a perforation.
    I took my truck to Lehman Toyota. They said it is covered but they don't have a body shop. They suggested that I take it to Headquarter Toyota.
    I took it there and the receptionist in the body shop department said that the 3yr/36K will not cover this. I told her that the manual states otherwise. She then called the body shop tech. I explained to him that if you lift up the rubber you see it more. He said that it's a seem in the metal where the 2 pieces are joined together. He lowered the seat to look at the window from the inside. He said that he did that to verify that it has not been previously tampered with. Thats a good sign. He then brought out a camera but my picture looked better than his so I emailed it to him. He then showed his manager and he OK'd it. He asked me to drop it off this Wednesday morning. He stated that they can't cover a rental for me (which I never asked for). I said "That's fine, as long as it gets fixed correctly, I am happy."
    I would like to add that the receptionist did not have a bad attitude. She seemed to believe it was 3yr/36K.
    Wish me luck. I'll keep you posted.
  18. Jan 28, 2013 at 2:56 PM
    TwzteD
    TwzteD Well-Known Member
    Kyle
    St Lucie Fl
    2013 4x4 reg cab Auto
    2013 4x4 reg cab, 2011 4runner sr5 rims, 265 general grabber at2's, 5100's All 4 corners with fronts at .85, De badged, Egr Rainguards, Led tail lights, Int wipers, fog lights, Trailer Hitch, POwer locks+ keyless entry, Extang Solidfold Bed Cover, WeatherTech Mats, Stubbie Antenna, Trd Skid Plate, Tint, Scanguage, Cargo net in bed, Sound Ordnance B-8PT, FULID FILM Under Coat.
    Good luck! hope it turns out good. I had nothing but bad experiences bringing my truck and previous Tacoma to the dealer.
  19. Feb 7, 2013 at 3:38 PM
    TAC1
    Tac1
    Miami, FL
    2015 DCSB O/R 4WD
    Hello Forum,
    I picked up my truck on Tuesday morning from Headquarter Toyota in Miami on nw 57th ave & the Palmetto. I am very happy with their service. It appears to be a very well done job. They even had to remove the bed in order to access the area behind the window. I know this was done because I have d-rings bolted to the bed through all 6 bolts & I have them installed in the same linear position & the bolts are painted. There was also a bunch of pieces of rubber in the bed & I can see the new rubber seal on the inside of the window. They also washed the truck, except for some debris in the bed but I am not complaining!
    It's about time I get lucky. I missed the warranty for a repair on my sons Charger by 600 miles!
    Thanks forum
    :D
  20. Feb 9, 2013 at 4:14 AM
    TAC1
    Tac1
    Miami, FL
    2015 DCSB O/R 4WD
    Thank you!
