rust on 03 frame
Discussion in '1st Gen. Tacomas (1995-2004)' started by toy03, Mar 1, 2014.
  1. Mar 1, 2014 at 7:45 AM
    toy03
    toy03 [OP] Member
    RhodeIsland
    03 tacoma 4-dr trd
    had the recall done on my 03 Tacoma where they paint some crap on it .now its all falling off and my frame looks worst then when they did it .anyone else have this problem?
  2. Mar 1, 2014 at 7:56 AM
    travelfeet
    travelfeet Well-Known Member
    Andrew
    Troy, NY
    02 xtra 4x4 v6
    There are many like that. If Toyota coated the frame you should still be warrantied. I almost bought one in that condition last year, but I was worried it wouldn't rust out fast enough :D to get a replacement before the warranty was up (15 years from first use).
    You should be able to take it in for inspection at Toyota and if its bad enough you should be eligible for a frame replacement.
  3. Mar 1, 2014 at 8:47 AM
    fast5speed
    fast5speed Well-Known Member
    Washington D.C.
    2005 Access Cab 5speed 4cyl 4x4 SR5
    do you know when it was treated? My truck was treated in 2011 I believe..whatever coating they put on is some tough stuff. It's so goo-ey and not dried up or flaking at all. I think it's a really respectable coating. Issue is, I have no idea if they just sprayed it over existing rust or not. I know that Toyota wouldn't replace the frame just over surface rust, but even that would eventually get worse.
  4. Mar 1, 2014 at 10:27 AM
    toy03
    toy03 [OP] Member
    RhodeIsland
    03 tacoma 4-dr trd
    Was done in 2011 I live in RI lots of salt. The stuff never dried. If I touch it or goes on a lift the stuff will just peel off.
  5. Mar 1, 2014 at 10:49 AM
    toy03
    toy03 [OP] Member
    RhodeIsland
    03 tacoma 4-dr trd
    just called Toyota usa opened a claim .told me this shouldn't happen .they want a rep to come out and look at my truck.heres the #1-800-331-4331 got right threw very helpful if anyone else having same problem.
