Rust on 2018 Front End Components...need advice
Discussion in '3rd Gen. Tacomas (2016-2023)' started by gamerunner, Jul 8, 2019.
  1. Jul 8, 2019 at 4:08 PM
    Hennessy
    Hennessy Well-Known Member
    Charlotte NC
    13 Red DC TRD Sport
    Demello Baja bumper, Mcneil Fiberglass, Fabtech Uniball Upper Control Arms, Emu Dakar leaf springs, Fox 2.5 Factory Series Coil-over IFP, Fox 2.0 Performance Series IFP
    good thing you don't live in the rust belt, but as mentioned above a good cleaning and some paint and it is good as new.
    there does seem to be some sand and such in the caliper, but a good rinse with the wheels off would take care of most, and maybe hit id with some brake parts cleaner...
    KY_Rob likes this.
  2. Jul 8, 2019 at 4:09 PM
    JdevTac
    JdevTac Well-Known Member
    Josh
    MD/GA
    2nd gen
    Wire wheel, hit the bolts with some fluid film or equivalent, you can wire wheel the calipers, and call it a day. Wash it off much better next time.
    Pro-Taco, gamerunner[OP] and KY_Rob like this.
  3. Jul 8, 2019 at 4:10 PM
    Hennessy
    Charlotte NC
    13 Red DC TRD Sport
    I second this your shop is just trying to scare you into getting additional work done that you don't need..
    KY_Rob[QUOTED] likes this.
  4. Jul 8, 2019 at 4:14 PM
    little squirt
    little squirt 808 ALLDAY!!
    808 ALLDAY!!
    your fine, just normal surface rust. Nothing is going to fail or break because of surface corrosion.
  5. Jul 8, 2019 at 4:15 PM
    gamerunner
    gamerunner [OP] Well-Known Member
    2018 TRD OR
    TRD Pro grill
    Would I wire brush it then spray fluid film on it? Or vice versa? Is WD40 safe to use or would it cause a bolt to loosen?
    KY_Rob likes this.
  6. Jul 8, 2019 at 4:20 PM
    Blue92
    Blue92 Well-Known Member
    Daniel
    North Carolina
    2018 Sport
    Spray the wd40 on first to loosen up the rust, then agitate with a wire brush and then hose off with brake cleaner. Yes its all perfectly safe on the rubber boots, no it wont loosen any bolts. Theres a cotter pin in there to prevent that from happening.
  7. Jul 8, 2019 at 4:22 PM
    basshole
    basshole Well-Known Member
    chicagoland
    2018 OR MT
    Man some southern guys must not know what "normal" rust looks like, or they just trying to rip ya off. Some of the vehicles up here look like science experiments underneath.
    2001 4x4 and KY_Rob like this.
  8. Jul 8, 2019 at 4:42 PM
    Commfishmtk
    Commfishmtk Well-Known Member
    You will be fine like others have said spend some winters in the NE and you will will see some real rust. I live on the coast so not only do they salt the crap out of the roads we are surrounded by salt water on three sides. I honestly have never hosed my truck off after going on the beach or launching the boat at the ramp just drive through some puddles you will be fine.
    gamerunner[OP] likes this.
  9. Jul 8, 2019 at 4:52 PM
    Ronzio
    Ronzio Well-Known Member
    Pennsylvania
    17 DCSB TRDOR
    If your got ocean water in the wheel bearings...put those on the list as well just a matter of time.
  10. Jul 8, 2019 at 4:56 PM
    Pro-Taco
    Pro-Taco Well-Known Member
    Lou
    Commiefornia
    2019 OR DCSB 4X4 Prem/Tech Cement
    All TRD Pro parts
    Looks like your shop is trying to take you for a "ride". It would take an honest shop a whole 5 min to clean that off, then give you a 5 min lecture on how to keep it clean and earn some honesty points. Change your shop.
    Greg.Brakes.Tacos, jcayce and KY_Rob like this.
  11. Jul 8, 2019 at 5:12 PM
    gamerunner
    2018 TRD OR
    TRD Pro grill
    Thanks for the advice everyone. A lot of knowledge on here. Will attempt to clean them myself. Hopefully it comes out ok
    KY_Rob likes this.
  12. Jul 8, 2019 at 7:26 PM
    psmura
    psmura Well-Known Member
    Paul
    Syracuse, NY
    2018 TRD OR MT
    Fluid film your entire truck except for the brake components. That rust is minor nothing to worry about.
  13. Jul 9, 2019 at 6:40 AM
    Ziemann
    Ziemann Member
    '19 Toyota Tacoma TRD OR MGM
    Bone Stock
    Wow- I feel bad for the original poster. They sensed that he wasn't experienced or knowledgeable, and they tried to take advantage of him by scaring him in to needlessly spending money. Wow- what a horrible shop. This is why I don't trust repair shops.
    Where I live, salt is used on the roads for about 5-6 months (November-April) to keep them clear of ice and snow. Rust like that is expected and completely normal up here.
    Kudos to those that gave this guy good advice and helped him see through the BS that the repair shop was feeding him.
    KY_Rob likes this.
  14. Jul 9, 2019 at 7:00 AM
    Beancooker
    Beancooker Alea iacta est
    The middle of Arizona
    2021 Jeep Wrangler Rubicon
    Lots, straight from the factory.
    Looking at the pics and the rust... Find a new shop. Don’t have them fix anything. Pay them their diagnosis fee and run. They are trying to scare money from your wallet.
    I am new to the Tacoma, but have been modding cars forever. Nothing looks like it’s in need of replacement right away. The tie rods may need to be checked again in the future.
    The comment about the calipers seizing in the next year is crap. Yes, a caliper may seize. The odds of it happening to yours isn’t much different than it happening to mine.
    Find a new shop with honest people.
    KY_Rob likes this.
