Rust on hub...2013 model
Discussion in '2nd Gen. Tacomas (2005-2015)' started by cstallings, Jul 22, 2013.
  1. Jul 22, 2013 at 7:12 AM
    cstallings
    cstallings [OP] Well-Known Member
    Arkansas
    2013 MGM DCSB TRD Sport 4x4
    SOS Front Bumper, SOS Sliders, SOS skids, ARB Rear Air Locker, OME Lift (885x Coils, Nitro Charger Shocks, Dakar Leafs), LR UCAs, Leer Shell, OKLED 30" light bar, Wet Okle Seat covers, etc, etc
    Is this normal? I have a 2013 sport that I bought late March of this year. I only took the drivers side tires off. I was trying plati dip out. Only one lug nut was rusted. This seems a little early for things to start rusting.
  2. Jul 22, 2013 at 7:17 AM
    SpacemanSpiff
    SpacemanSpiff Well-Known Member
    James
    08 TRD Off-road
    No need to worry about it. My '08 has had it for as long I can remember. I just hit with a wire brush and maybe some rustoleum or the like. Never had any on the lugnuts, though...
  3. Jul 22, 2013 at 7:18 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Put some neverseize on the back of the wheel where it contacts the hub, it will help prevent the wheel from seizing to the hub. If the rust itself bothers you, take it off, clean it and rattle can it (use high temp paint).
  4. Jul 22, 2013 at 7:19 AM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    Competely normal
  5. Jul 22, 2013 at 7:20 AM
    OrlPreds
    OrlPreds Mustard Tiger
    Jeff
    State College
    '13 DCSB Sport
    Looks like mine did when i put new wheels and tires on it, after only 2k miles.
  6. Jul 22, 2013 at 7:36 AM
    cstallings
    Arkansas
    Ok...thanks. I may clean it up some, but I'll be watching this. Not sure if my 06 4runner has any rust on the hub.
  7. Jul 22, 2013 at 7:47 AM
    OrlPreds
    Jeff
    State College
    '13 DCSB Sport
    when i rotate tires next, i will wire brush it and hit it with some paint.
  8. Jul 22, 2013 at 8:16 AM
    haider320
    haider320 Well-Known Member
    Roswell, NM
    2013 MGM Double Cab SR5 4x4
    My 13 is only 4 months old and I have the rust too.
  9. Jul 22, 2013 at 10:33 AM
    obscurotron
    obscurotron Well-Known Member
    N. Nevada
    '14 DCSB 4x4
    Too many to list, and I've probably forgotten a bunch.
    It's steel, and it's uncoated. Steel rusts. The speed at which it rusts depends on the composition of the steel and environmental conditions, but all steel will eventually rust. Some of the steel I work with will pick up surface rust in a matter of an hour, just sitting on the work bench.
    I'm not sure why anyone would be surprised that steel rusts. What is a little surprising is the rust on the lug nut itself, since it is coated (chrome, I'm supposing). Usually chrome doesn't rust through that quick, since it has protective layers of copper/nickel and chromium between atmosphere and the underlying steel.
    Do you live near, or drive through, salt water?
  10. Jul 22, 2013 at 12:05 PM
    Jimsc
    Jimsc Well-Known Member
    Jim
    Greenville, SC
    10 PreRunner Double Cab
    Aries Nerf Bars, Cargo Seperator
    Are you getting into any salt water? That will do it.
  11. Jul 22, 2013 at 12:09 PM
    Greytacoma1
    Greytacoma1 Senior Member
    dave
    Sacramento ca
    Tacoma dc lb
    Satoshi grill, Plasti derp, Ready lift kit, Wheelers 2 inch aal, Hella 700, Wheather tech floor mats, Blueinstinct armrest cover, sockmonkey bed decal, BHLM, debadge, 35% tint front windows, OEM roof rack, OEM step bar, TRD skid plate, tacomaworld.com decal, stock antenna trimed, gorilla extended lug nuts,diff breather mod, cab mount chop, AVS window visor, spidertrax 1.25 wheel spacers, toytec sway bar relocate, extra d ring mod
    That's a lot of rust already. Think of how it would look a couple years from now. I hate rust.
  12. Jul 22, 2013 at 12:09 PM
    cstallings
    Arkansas
    No salt water in Arkansas. I just thought it was a little early for this, but according to others I guess not.
