Rust on Shocks
Discussion in 'Suspension' started by tsfenrir, Feb 26, 2012.
  1. Feb 26, 2012 at 11:03 PM
    tsfenrir
    tsfenrir [OP] Member
    Travis
    Fort Bragg, NC
    DBL SB TRD Off Road 4X4
    Fox 2.5 RR and RR in rear, Dakar 2.75 leafs, TC UCA's, Shrockworks front bumper
    I came back from a year in Afghanistan to find my $1300 Fox coil-overs looking like they were salvaged off the Titanic. Has anyone here encountered this, or know a means to combat it.
    I took them off once to clean with just about every type of rust remover on the market, and they reappeared like this. I've also e-mailed Fox with the enclosed pics to see if their service can clean them up a bit.
    If anyone has any advice, I appreciate it, thanks.
    Pirhett likes this.
  2. Feb 27, 2012 at 12:33 AM
    Sublime
    Sublime Well-Known Member
    Phoenix, AZ
    08 TRD 4x4
    Icon/All Pro.....chopped for 35's
    Wow man, that is terrible! Wonder if they have a coating they could add to it. Icon's got a coating for $100 more!
  3. Feb 27, 2012 at 12:51 AM
    toytaco11
    toytaco11 Well-Known Member
    Albuquerque
    11 TRD 4x4 lwb doublecab
    coming soon!
    wow that's crazy. I think this happens to all coilovers after awhile. I used silicone spray on my SAWS and it did seem to help a bit.
  4. Feb 27, 2012 at 1:05 AM
    Taqoma
    Taqoma Well-Known Member
    Brennan
    Los Angeles
    2011 TRD Off-Road
    TRD Supercharger, TRD CAI, Camburg LT, Fox 2.5x8 coilovers, Fox 2.0 bumps, Deaver e30 leafs, Fox 3.0x18 triples, Avid sliders, Yaesu 2900R, Pro Comp 7089 16x8, DDM 55w HID Hella 500FF, DDM 35w HID headlights, Magnaflow 11255 muffler, PLX DM-100 OBDII, Autometer Ultra-Lite II Boost gauge, Flex Pod gauge mount, LSK tube bumper, McNeil fenders, Fiberwerx bedsides, 285/75/16 Toyo MT's
    in a thread I read some guy said Fox's are made of steel and can rust where others like King use aluminum.
  5. Feb 27, 2012 at 9:06 AM
    Supermoto
    Supermoto Well-Known Member
    Landon
    Encinitas/San Diego
    Not true, they all make the body from steel
    I disagree, I have owned many fox shocks over the years and never had rust. Without maintenance any shock will rust.
  6. Feb 27, 2012 at 9:18 AM
    Supermoto
    Landon
    Encinitas/San Diego
    Yeah but put any shock through that without maintaining and it will rust over time.
  7. Feb 27, 2012 at 9:37 AM
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    I reccomend you go back and do some more research.
    Kings most definitely have aluminum bodies. Aluminum dissipates heat faster then steel so your top of the line manufacturers like King utilize it.
    Not true at all. My Kings are 100% fine after 2 years of salt belt abuse.
    From Kings site:
    Lightweight hard anodized 6063 aluminum alloy reservoirs dissipate heat quickly and will not rust due to gas charging contamination.
    Aluminum components and vehicle specific mounts are machined from aircraft quality billet. Front and rear kits all include all necessary vehicle specific mounting brackets and hardware along with detailed installation instructions. Technical support, if needed, is only a phone call or email away.
  8. Feb 27, 2012 at 9:46 AM
    Supermoto
    Landon
    Encinitas/San Diego
    No i recommend you do more research, both king and fox use DOM steel for the shock body. The reservoirs are made from aluminium.
    "The shock body is made from low carbon DOM steel tubing then honed and threaded."
    Just wondering how many shocks have you opened up and rebuilt?
  9. Feb 27, 2012 at 10:03 AM
    OffroadToy
    OffroadToy This ain't Dodge City, and you ain't Bill Hickok
    4X4 Offroad
    snugtop, piaa, weathertech, westin, oem bed mat, trd seat covers, avs inchannel vent visors, 2" suspension lift, front diff drop, rear differential breather extension, oil filter drain hose, a/c drain hose extention & reroute, front window tint, cat theft protection plate, tailgate clamp mod, xpel headlight/foglight protecters, oem block heater, bfg 265/75R/16 a/t k/o's, cabin air rodent protection screen, rcbs illuminated 4X4 switch mod
  10. Feb 27, 2012 at 10:04 AM
    Robertocritser
    Robertocritser Well-Known Member
    Levi
    KY
    08 sport
    Dirt king 3.5 LT kit with kings, 4 link rear with foa, 4.56 gears, Detroit and arb lockers, one piece drive shaft, armor, and some other things.
    Let me know what fox says about it, this is also starting to happen to me.
  11. Feb 27, 2012 at 10:06 AM
    XXXX
    sKiP
    05 Prius
    So why is it that after 2 years I have corrosion on the bodies and threads not rust?
    I don't see what rebuilding a shock has to do with metallurgy.
  12. Feb 27, 2012 at 10:07 AM
    SDHQ OFFROAD
    SDHQ OFFROAD Cuz Stock Sucks! Vendor
    SALES
    Gilbert AZ
    This is correct.
  13. Feb 27, 2012 at 10:08 AM
    Supermoto
    Landon
    Encinitas/San Diego
    its the coating they use breaking down. If you don't believe me call king and ask them what their coilover bodies are made from.
    Ive done more than just bolted them on, thats what.
    Thank you!
  14. Feb 27, 2012 at 10:10 AM
    XXXX
    sKiP
    05 Prius
    King must electroplate their shocks then.
    I have never seen corrosion similar to aluminum corrosion on steel before.
    Guess you learn something new every day.
  15. Feb 27, 2012 at 10:12 AM
    SDHQ OFFROAD
    SALES
    Gilbert AZ
    :facepalm: I think you need to do some more research on who the "high end manufacturers" are.
    http://www.youtube.com/watch?v=3lPnx7iX8mk
    just saying...
  16. Feb 27, 2012 at 10:14 AM
    Supermoto
    Landon
    Encinitas/San Diego
    No kidding
  17. Feb 27, 2012 at 10:14 AM
    SDHQ OFFROAD
    SALES
    Gilbert AZ
    If you live in the salt belt the IVD coating from Icon does a terrific job at keeping your shocks clean and new looking.
  18. Feb 27, 2012 at 10:16 AM
    SDHQ OFFROAD
    SALES
    Gilbert AZ
  19. Feb 27, 2012 at 10:17 AM
    Supermoto
    Landon
    Encinitas/San Diego
    You work with ALOT of shocks and installs. In your opinion does one brand have a better coating than another? (not counting the old sway aways ha) IMO they are all very similar
  20. Feb 27, 2012 at 10:21 AM
    Supermoto
    Landon
    Encinitas/San Diego
    I co drove for him at ridgecrest back in 07, wow all i can say is wow. He over all'd that one.
