Rust on suspension: New Truck 2011
Discussion in '2nd Gen. Tacomas (2005-2015)' started by JonJonXD, Sep 3, 2011.
  1. Sep 3, 2011 at 1:44 PM
    JonJonXD
    JonJonXD [OP] Active Member
    PA
    2011 PreRunner SR5 V6
    Is this normal. Thought it odd for a new truck
    Some rusting spots on bolt heads, rear suspension parts, etc
  2. Sep 3, 2011 at 1:45 PM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    Sucks , but normal for these trucks
  3. Sep 3, 2011 at 2:27 PM
    JonJonXD
    PA
    Really. On a brand new truck?
    I'm going in for a 30 day free checkup.
    I'm going to instruct them to fix the existing spots
  4. Sep 3, 2011 at 2:31 PM
    jcayce
    jcayce Well-Known Member
    Texas
    17 DCSBTRDOR4X4
    You probably drove it in the rain.
    If you do tell them to fix the rust, what do you really think they are going to do? Replace, sand and paint, undercoat...If they replace it will rust again, if they sand and paint it will rust again, if they undercoat it will continue to rust.
    Some battles are not worth the effort.
  5. Sep 3, 2011 at 2:31 PM
    OZ-T
    Peter North
    British Columbia
    Let us know how that works out for you .
    The term " surface rust " will come up
  6. Sep 3, 2011 at 2:33 PM
    jcayce
    Texas
    17 DCSBTRDOR4X4
    And you live in PA. Wait until you see what it looks like after the winter.
  7. Sep 3, 2011 at 2:38 PM
    JonJonXD
    PA
    I'll let you know.
    At what point should I become concerned?
    $28,000 and 180 miles later.... Rust. Lol
  8. Sep 3, 2011 at 2:38 PM
    wmdpowell
    wmdpowell Well-Known Member
    Bill
    Selkirk, NY
    4x4 reg cab, 5 speed
    Better tires Hurcules Terra Track, trimmed front mud flaps, (access limited tonneau-took off) softopper, ats running boards, Piaa fogs, window vents, Wireless thermometer, extra bed rings, valley hitch
    Rustoleum and rustoleum undercoat, both rattle can, both readily available. That's what I did.
  9. Sep 3, 2011 at 2:41 PM
    jcayce
    Texas
    17 DCSBTRDOR4X4
    Don't become concerned. The frames as well as several other components on these Tacomas have made it a disposable truck. In 5 years trade and start again. The only thing on your side is high resale.
  10. Sep 3, 2011 at 2:46 PM
    jcayce
    Texas
    17 DCSBTRDOR4X4
    Painting or undercoating rust will not stop it. Even sanding and painting will not. Unless you are ridiculously fast and in a vacuum, iron exposed to oxygen will begin to form rust immediately. Undercoating is probably the worst thing you can do if there is already rust.
    Waxoyl, boiled lintseed, or used motor oil are your friends East Coaster. Crawl under there once a year and give it a good spray then forget about it.
  11. Sep 3, 2011 at 2:51 PM
    OffroadToy
    OffroadToy This ain't Dodge City, and you ain't Bill Hickok
    4X4 Offroad
    snugtop, piaa, weathertech, westin, oem bed mat, trd seat covers, avs inchannel vent visors, 2" suspension lift, front diff drop, rear differential breather extension, oil filter drain hose, a/c drain hose extention & reroute, front window tint, cat theft protection plate, tailgate clamp mod, xpel headlight/foglight protecters, oem block heater, bfg 265/75R/16 a/t k/o's, cabin air rodent protection screen, rcbs illuminated 4X4 switch mod
    Surface rust will always form on exposed metal parts (suspension,exaust, etc.) It's completly normal. Even vehicals that sit on the lot will get it just from moister in the air.
  12. Sep 3, 2011 at 4:15 PM
    SPENCAF
    SPENCAF Well-Known Member
    Shiloh, IL
    2012 TX PRO 4X4
    AFE Pro dry filter, AttennaX, bed liner on front skid plate, AVID sliders, AVID light bar, KONG Storage Box, OME 2.5" 885 coils 1.5" AAL 265/75R16 Guard Dawgs
    It is normal. you could always use "gemplers rust converter" They use it up north in the dump bed salt trucks. If you do, never plan on take any bolts without a cutting torch.
  13. Sep 4, 2011 at 4:24 AM
    808TRDTaco10
    808TRDTaco10 Black Sand Mirror
    Justin
    Big Island, Hawaii
    10 Access Cab TRD OR 5AT 4x4; 08 Regular Cab 5MT 4x4
    TRD Off Road 265/75/16 Goodyear Wrangler Duratrac Load Range C | Toytec Ultimate Lift with Emu Dakar Leaf Packs | 3* Axle Shims, CB Drop, Sway Bar Relocates | AVS Vent Visors, AVS Bugshield | Scangauge II | Wet Okole Seat Covers | Weather Tech Floor Liners | Pop n Lock | OEM Bed Mat | Truxedo Lo Pro QT Tonneau Cover | TRD Cat Back Exhaust | Aftermarket Alarm System | Pro Coat "Electronic Rustproofing"
    Mine had a lot of surface rust on the tow hitch and rear axle back when it was brand new sitting on the dealer's lot...or maybe even earlier. Just never noticed it until a week after I bought it. :mad: I've come to accept that our Tacoma's rust easily and 1 year later after I got the truck I touched up the rust spots with POR-15. Heard great things about the stuff and I plan to do yearly touch-ups under there. Just wouldn't be able to stand there and watch my baby rust away and do nothing about it.
  14. Sep 4, 2011 at 4:29 AM
    paintdiddy
    paintdiddy Machine gun shits
    shithead
    nj and not from "the jersey shore"
    silver bullet
    All cars and products are shit. Nothing is made with the same quality as 20 years ago. Not sure if it's cutting corners or metals that have been recycled 10 times before it became your truck. My buddy was at a jeep dealer and brand new jeeps were rusted pretty good and they had zero miles on them.
  15. Sep 4, 2011 at 4:36 AM
    MakoTacoma
    MakoTacoma Well-Known Member
    Dave
    Georgia
    '97 xtra cab DX 4x4
    There's businesses out of Canada, called Krown, that will rust-proof vehicles. Their product is apparently strong enough that the E.P.A. doesn't want them in the U.S. at the moment. They guarantee your vehicle not to rust, so long as you use them annually. And they're not expensive. No Zie-Bart cheapness is good enough for my Taco. I live in Michigan and will be taking advantage of this. :cool:
  16. Sep 4, 2011 at 4:38 AM
    MakoTacoma
    Dave
    Georgia
    '97 xtra cab DX 4x4
  17. Sep 4, 2011 at 4:41 AM
    paintdiddy
    shithead
    silver bullet
    It's so good that your hair will fall out and give you cancer. :D
  18. Sep 4, 2011 at 6:14 AM
    Capita
    Capita Well-Known Member
    Corner Brook, Newfoundland, Canada
    09 TRD Sport Double Cab
    I been getting my truck Krowned for the last few years and I'm still getting a lot of rust. I'd hate to see if I never had this treatment done.
  19. Sep 4, 2011 at 6:31 AM
    Ivan
    Ivan Well-Known Member
    Ivan
    Western Mass
    06 Tacoma, 4x4 + SR5
    I just got my 2006 taco, there wasn't any major rust, but I'm bringing it to VT and getting the everything cleaned and undercoated, its only like 60-80 bucks depending on how much there is to do, not a bad deal
  20. Sep 4, 2011 at 7:27 AM
    PSJ
    PSJ Prerunners Work
    Sebastian Inlet
    09 Access Cab Prerunner
    Rear Leaf spring TSB, Bilstein 5100's all around w/ front set at 1.75", 265/75R/16 Mickey Thompson Baja STZ's, Trailer hitch w/custom wiring, AFE drop in dry filter, Rear Diff breather mod, Debadged truck, customized stock TRD wheel center caps, added factory fog lights, bed mat, door sills, tinted windows
    Since it is a new truck, if you ask them to paint it I am sure they will. But, like mentioned its a on going battle. For me, I hate the site of rust so I just get under there form time to time and do a touch up. Just about any truck will have these issues, you see many new ford trucks on the lot with the diff covers completely covered with rust, or other heavy metal parts like axles, springs, etc. showing rust. I am garaged kept and still have issues. If your truck is stored outside, you will have to keep up on it more.
