Rust Problem ?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jeff1304, Aug 6, 2009.
  1. Aug 6, 2009 at 9:38 PM
    jeff1304
    jeff1304 [OP] Well-Known Member
    09 Single Cab 4x4 SR5
    extra tie downs in bed
    Im looking at buying a new 2009 single cab 4x4 tacoma and was wondering what is the 2nd gen tacoma with rust so far ? are they holding up well ?
  2. Aug 6, 2009 at 9:40 PM
    Incognito
    Incognito No better friend, no worse enemy
    VA
    2012 Pyrite AC TRD OR
    Spacer lift, bumper stickers, ejector seat, etc.
    So far they have been good, but the paint has been sorta weak and thin.
  3. Aug 6, 2009 at 9:41 PM
    carmellocafe
    carmellocafe Begin With The End In Mind.
    KEVIN
    N. California
    2014 TRD OR Access cab longbed
    No prob. here:)
  4. Aug 6, 2009 at 9:54 PM
    jeff1304
    on any certain colors or just all of them in general ?
  5. Aug 6, 2009 at 9:56 PM
    Incognito
    VA
    All in general. :eek:
  6. Aug 7, 2009 at 7:03 AM
    bb609
    bb609 O.F.
    NH
    '09 TRD Sport Access Cab
    Bilstein 5100 CO's @ 1.75" - Icon UCA's - TSB Rear w/Bilstein 5100's - Air Lift System - Flowmaster 50 Duals(RIP...back to stock for now) - Avid Offroad Arctic Bar - Avid Offroad Nerf Bars - Leer 550 Bedcover - AVS Hood Protector(RIP) - Ventshades - Yota Bed Mat - Sheepskins!!! - Weathertechs
    They cut off half of the frame on the newer models so now you only have half the problem!:D
    Look under a new one. You probably find surface rust already showing up but it's only that, surface rust. Don't worry about rust, they're fine. A little maintenance done to the frame from time to time (wire brush and a rattle can) and they will last forever.
  7. Aug 7, 2009 at 7:33 AM
    jeff1304
    would my time be better spent just putting a layer of some kind of rustproofing on it ? rather than a steel brush and a rattlecan ?
  8. Aug 7, 2009 at 7:41 AM
    nad
    nad mmmm tacos!
    Jordan
    Canada
    2014 Sierra All Terrain
    definitely get an undercarriage coating if you are buying new. My 05's frame is very rusted as well the clear coat on the paint seems to chip off so I have these blotches all over my truck. They aren't bad tho because its silver and you cant c them from a distance.
  9. Aug 7, 2009 at 8:02 AM
    Caddmannq
    Caddmannq MotoNerd
    California
    2012 PreRunner TRD Sport DC LB
    Undercover toneau
    Not a speck of rust here yet, but then it never rains here either.
  10. Aug 7, 2009 at 8:18 AM
    Demoncleaner
    Demoncleaner Well-Known Member
    Upstate NY
    05 Dcab 6spd 4x4 TRD Sport w/Tow
    TRD exhaust Homemade bed mat & bed extender, front Drings, Short clutch throw, Summer: Stock 17's Winter: Blizzaks on 16' black steelies
    Had mine since Dec 04, paint is doing well very, I just wax it 3 times a year. Frame can take a beating in heavy snow areas, I undercoated mine last year.
  11. Aug 7, 2009 at 8:24 AM
    grivera
    grivera Well-Known Member
    Hanover, MD
    '08 DC SR5 4x4, Desert Sand Mica
    Rear Suspension TSB, Bilstein 5100 on all 4 corners-fronts set at 1.75". BFG A/T's @ 265/75/16; Access LE Roll-up cover; Iron Cross Tube SS Steps; Fumoto valve; WeatherTech Liners; AFE Pro-Dry; front side windows tinted 20%; TW Decal!
    Isn't the clear coat issue covered by warranty?
  12. Aug 7, 2009 at 9:19 AM
    Capita
    Capita Well-Known Member
    Corner Brook, Newfoundland, Canada
    09 TRD Sport Double Cab
    Frame starting to show signs of surface rust. I'll be getting it undercoated before winter. Will the undercoating splash up much on my white paint?
  13. Aug 7, 2009 at 9:24 AM
    Caddmannq
    Caddmannq MotoNerd
    California
    Undercover toneau
    Are you asking: "Do idiots splash paint on things?"
    ;) Yep! ;)
    Find the right guy to do the undercoat & you won't have to wonder.
  14. Aug 7, 2009 at 9:32 AM
    Capita
    Thats true. I guess if any do splash it should come off fairly easily. Hopefully they don't get the seats though. Maybe I should do it myself, :)
  15. Aug 7, 2009 at 10:16 AM
    ozmon420
    ozmon420 Well-Known Member
    miami, florida
    08 tacoma
    18x9 pro comp 7031 rims, alpine iva-d310 w/sirius sat radio, ipod connection, tv tuner, reverse camera, bug deflector, wet okole seat covers, tinted windows, running boards, toytec coilovers front set at 2.5'' , AAL rear,5100's rear, TC UCA, leer topper, bruteforce rear bumper, ARB rear locker.
    no rust problems here
  16. Aug 7, 2009 at 10:38 AM
    VTDave
    VTDave Well-Known Member
    Vermont, USA
    05 Access Cab 4x4 Base 5sp Man, 16 DCSB 4x4 Sport 6sp Man
    Where I live, the paved roads get salted to death, the dirt roads get sanded, and my frame gets coated with most of the above half the year. My '05 had surface rust spots on the frame and on some fasteners after about 3 years. I sanded it off and repainted with Rustoleum.
    Beware undercoating products. Some work and some can make rusting worse. For instance, certain oil products trap salt and moisture close to the frame, accelerating the rusting process. Do lots of research before you decide.
  17. Aug 7, 2009 at 1:09 PM
    bb609
    bb609 O.F.
    NH
  18. Aug 7, 2009 at 1:13 PM
    nad
    nad mmmm tacos!
    Jordan
    Canada
    probably but the warranty is up and the previous owner didnt get any tsbs or anything at all done to it, I think he was a country boy who treated it like a ford :mad:
  19. Aug 7, 2009 at 1:48 PM
    KodiakVA
    KodiakVA Well-Known Member
    Richmond Virginia
    09 4x4 XCab Sport BarcelRed
    I'm headed to Zeibart tomorrow with my new 09. I had that done on my 99 Ranger in the fall of 98 and lived in the Pocono Mts of PA till the summer of 03. Lots of long commutes to NJ through lots of salt. I lived in the boon docks and washing the salt off the truck didn't happen till the spring. I only had follow up service done twice while I lived there.
    I just traded it in and the undercarriage of the truck was in outstanding condiction. Small surface rust spots where the undercoating had taken some damage is all it had. It really looked great. How much of that great rust protection was due to the undercoating, or due to the metal protection Ford used, I don't know. I do know that it sold me on it and everyone at the dealer that looked at the truck asked me what I did to keep it so nice.
    Pity though I have to drive 110 miles to DC to find the nearest dealer.
