Rust proofing frame, axle??
Discussion in 'Detailing' started by Quivira9, Jun 30, 2009.
  1. Jun 30, 2009 at 8:38 PM
    Quivira9
    Quivira9 [OP] Member
    KANSAS
    09 OFF ROAD WHITE
    I have a new 09. The underside looks great, except three small one inch areas of surface rust on the rear axle. Two of them are exactly opposite location almost like that is where they lifted the truck or something...
    anyways should I just ride it out and monitor it or should I try to sand it off or use a rust chemical thing that eats the rust....then prime and paint over it....
    if you google it there is very little and confusing info...
    what to use? what to paint? sanding, scraping or chemical? I look at the bottom of the truck and I can't imagine just painting stuff....the frame and axle -- (black metal areas yes, but what else?)
    Confusing topic...any help from an expert? I don't want to jack something up by doing something to a brand new truck...
    :confused:
  2. Jul 2, 2009 at 1:51 PM
    kilgoja
    kilgoja Well-Known Member
    Alabama
    2009 regular cab 4x4 2.7L (silver)
    :mudding:
    yeah mine has some spots on the axle too on each side...i don't think it's a big deal...just surface rust...but you could get it off and paint it if you wanted to
  3. Jul 14, 2009 at 12:23 PM
    bb609
    bb609 O.F.
    NH
    '09 TRD Sport Access Cab
    FOX 2 1/2" CO's STOCK UCA's - They used to be Icons! Icons suck!!! TSB Rear w/Bilstein 5100's - Air Lift System - Leer 550 Bedcover - Ventshades - Yota Bed Mat - Sheepskins!!! - Weathertechs
    Toyota does a crappy job of painting the undersides of our trucks. Every time I rotate my tires, I get under the truck with a wire brush and a rattle can. The rear axle, front knuckles, and welds on the frame rust first, then random rust spots will appear occasionally on the frame. Just hit them with the brush and have a party with the rattle can! In time, it makes a difference.
  4. Jul 14, 2009 at 12:35 PM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    There are chemical sealers (there was a thread about one the other day) that seal rust with just one coat.
    You can also sand and wire brush- use pro15 or another sealer like that.
  5. Jul 14, 2009 at 1:10 PM
    mgtaco
    mgtaco Member
    Houston TX
    09 PreRunner SR5
    Some spots of the frame have a little superficial rust. I think that, as it was said, it may be surface rust that developed in areas where the paint/protection was chipped due to contact during lifting/transportation. Also, the very top of the screws for the rear shocks show the same as well.
    I wouldn't worry too much for surface rust. Whenever I'd get bored I'd get some sand paper or steel wool and clean then and spray them with this paint https://www.mclendons.com/img/products/10/10953072.jpg
    You can purchase it for about $4 in the home depot.
    That thing is really tough ;)
  6. Jul 15, 2009 at 8:23 PM
    ghostboy808
    ghostboy808 Well-Known Member
    Silver Mica Prerunner TRD Sport
    Gibson SS, TRD S/C
    look into POR-15. It's expensive but probably the best rust inhibitor on the market.
  7. Jul 16, 2009 at 6:14 AM
    Quivira9
    KANSAS
    09 OFF ROAD WHITE
    Thanks for all the info!
  8. Jul 20, 2009 at 4:23 AM
    travelingman
    travelingman What would Scooby do?
    Brian
    Ohio
    07lb4x4DC
    ticking eng.mo,ventvisors,locking tailgate,wheelmasters ss spare tire inflation line,weathertech mats
    Check out some stuff called Rust Bullet.
  9. Jul 20, 2009 at 4:38 AM
    Coastie Joe
    Coastie Joe Well-Known Member
    Andy
    NM
    16 TRD Off Road
    The wire brush and rattle can are the way to go... Cheap and it WORKS for years and years... Plus the stuff is like a buck at Walmart... I have always done that with no problems... Undercoat seems to hold dust and dirt and starts to look crappy... Where gloss black makes things look like new... :cool:
