Rust Proofing
Discussion in '3rd Gen. Tacomas (2016-2023)' started by jws6295, Sep 12, 2019.
  1. Sep 12, 2019 at 4:01 PM
    jws6295
    jws6295 [OP] Well-Known Member
    Central PA
    2016 SR5 double cab long bed
    I’m sure this has been discussed a million times but I’m looking at purchasing a 3rd gen Tacoma this weekend. I’m from south central PA and the truck I’m looking at is coming from Northern pa. The truck already seeing two pa winters (it’s a 17 and sold in the summer of 17) I want to get a head start on everything..
    my question is what’s your guy’s experience with using cavity wax on frames etc? I thought about using cavity wax or fluid film etc. Also transmission fluid ran across my mind. My fear is though if I spray the inside of the frame with trans fluid would that “trap” the junk inside? Or would it kill the salt etc.. Any tips?
  2. Sep 12, 2019 at 4:10 PM
    crashngiggles
    crashngiggles Tacomaworld's Resident Psych Dr.
    Jared
    Wilbraham, Massachusetts
    2013 MGM TRD 4x4 DCLB Trail Limo
    Go with fluid film, get it done every six months or so and it will keep your truck frame looking pristine. Check are at local guys in your area that might do it for $40 or so.
    jws6295[OP] likes this.
  3. Sep 12, 2019 at 4:17 PM
    MinookaBlues
    MinookaBlues Well-Known Member
    2022 Super White SR5 Access Cab
    Stock
    I'm from Northeast Pa. and have my truck sprayed with Krown every year.. $148..... in Mechanicsburg.... Line-X of Cumberland county. Fluid Film is also big on this forum... you can either have them sprayed by a shop or do it yourself. My truck and it's frame look great so far....5 years of road salt and no rust on the frame. They also spray inside the rocker panels, engine compartment, tailgate, inside the door jambs.
    https://www.youtube.com/watch?v=WgvL40QefZ0#action=share
    jws6295[OP] and skiergd011013 like this.
  4. Sep 12, 2019 at 4:34 PM
    skiergd011013
    skiergd011013 Well-Known Member
    2010 TRD Offroad 4x4 AC SSM
    Krown. I have a 2010 in the northeast that has a nearly rust free frame. It gets done every fall around oct/nov. As stated, they do the insides of all the body panels as well.
  5. Sep 12, 2019 at 5:48 PM
    jws6295
    Central PA
    That’s not to far from me since I live in Harrisburg and am from Carlisle! The truck I’m looking at is somewhat up your way at a toyota dealer.. I’m looking at in Wilkes-Barre
  6. Sep 12, 2019 at 5:50 PM
    stun gun
    stun gun Well-Known Member
    Aaronski
    Tacomas.
    17 4X4 sr5spd/01 LT sr5spd
    Mavcoat. Do it yourself.
    TeecoTaco likes this.
  7. Sep 12, 2019 at 5:51 PM
    TeecoTaco
    TeecoTaco Liberty Biberty
    SW Ontario
    16 Taco DCSB TRD Sport 6MT
    Modified the level of gas in the tank
    Pfft, I got people for that
    stun gun[QUOTED] likes this.
  8. Jan 4, 2020 at 9:49 AM
    ll_coolray
    ll_coolray Well-Known Member
    Ray
    Rocklin, CA
    '17 Quicksand Taco LTD 4x4
    Reviving this older thread with a few questions. I plan to crawl under my taco and do the following:
    1. Wire brush away any visible rust.
      • Is there anything to NOT wire brush?
      • Should I only be brushing the steel frame, nothing else?
    2. Apply Por15 top coat paint.
      • Again, is there anything to NOT paint? Or just go nuts down there.
    3. Apply Fluid Film coating.
      • Any tips or ticks here?
      • How often should I re-apply? (northern california)
  9. Jan 4, 2020 at 10:04 AM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    Just be smart. Don't abraid anything rubber or plastic/soft. That's about it. That goes for all of your bullet points.
  10. Jan 4, 2020 at 10:33 AM
    Tacowin1013
    Tacowin1013 Well-Known Member
    2017 OR DCSB 6MT MGM
    I apply FF twice a year, usually in late fall before the winter starts and once again in late spring early summer. Goal is to just get under there and look around for any rust spots and treat early. I found 2 spots directly behind my front tires probably from a rock kicking up, its pretty small a few mm so i'll probably wire brush it in the spring and treat it.
    I'm wondering if i should treat it or let Toyota do it under their "frame recall" I'm afraid they'll do something to just mask the rust and it'll still be rusting underneath whatever they do
    Muddycoinwash likes this.
  11. Jan 4, 2020 at 11:48 AM
    Skydvrr
    Nick
    YMH
    Black '17 OR
    I saw someone recommend some cosmoline, RP-36 or something like that, if I lived in a rusty area, that's what I'd do, then fluid film would be second.
