Rust proofing
Discussion in 'Ontario, Canada' started by Westsideott, Aug 24, 2020.
  1. Aug 24, 2020 at 11:37 AM
    Westsideott
    Westsideott [OP] Well-Known Member
    Ottawa, ON
    2020 DCSB OR
    Getting new tacoma in September, planning on keeping it for some time. Was curious about thoughts on rustproofing or atleast undercoating Tacoma given Ontario's salty winters. Factory undercoating I assume isn't great but would it be ok for first winter?
    Thanks!
  2. Aug 24, 2020 at 11:41 AM
    Clearwater Bill
    Billy
    Largo Florida
    Not if it was mine.
    Fluid film if you DIY, especially inside the boxed parts of the frame hard to wash.
    If that product is not available there, I'm sure some searches will find other good options. Many threads on the topic.
    But what you don't want to use is any of the rubberized types of product. They can actually make things worse by trapping moisture.
  3. Aug 24, 2020 at 11:56 AM
    Westsideott
    Ottawa, ON
    2020 DCSB OR
    Noted ... thanks.
  4. Aug 24, 2020 at 1:43 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    Do Fluid Film or CRC Marine (cosmoline). A less preferred option is Krown - not as effective as Fluid Film, but you will probably find more shops spraying Krown, and it's certainly better than not having any.
    Just avoid the dealership undercoating. That's the rubberized crap that traps moisture and cracks after a few years, leaving behind a rubbery mess that gums up wire wheels and sanding discs.
    RedWings44 likes this.
  5. Aug 24, 2020 at 5:35 PM
    MinookaBlues
    MinookaBlues Well-Known Member
    2022 Super White SR5 Access Cab
    Stock
    Can you point me to some information/studies that says Krown is less preferred and less effective than Fluid Film?? I have my truck Krowned every year and so far after 6 years my truck has no rust and I live in Pennsylvania....one of the saltiest/briniest states. I think it's personal preference as opposed to one being better than the other. The one thing I do agree with you on is that you HAVE to do something to prevent the frame from rotting out from under you ;)
  6. Aug 24, 2020 at 6:50 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    Welcome to the Canada section! Does your truck sit in this for 3 months each year?
  7. Aug 24, 2020 at 7:13 PM
    onakat
    onakat Well-Known Member
    Canada
    2000 indestructaco!
    Yes, NEVER EVER use a product that hardens on after application as an undercoat. It will make things worse as moisture will eventually get behind it though cracks or chips, accelerating the corrosion process as it gets trapped between the frame and the undercoating product
    The best option is oil-based undercoatings, like Fluid Film, Krown and similar products. But these are good only if you apply them on a YEARLY basis. Their consistency is both their strenght and flaw. They have water-like consistency and will creep anywere, into the smallest crevice and corner BUT this consistency will also allow them to get washed off on areas exposed to elements. This is why you must apply it yearly
    Fluid Film is an excellent product for this purpose, but it's expensive here
    A good alternative and less expensive option is Honey Goo. Easily found at canadian tire and auto stores
    Works just as good as fluid film, minus the smell ;)
    I only use this stuff now
    But it can only be found as spray cans, not the 5 gallons like Fluid Film
    3JOH22A likes this.
  8. Aug 24, 2020 at 7:18 PM
    Northern Taco
    Northern Taco Well-Known Member
    2022 Tacoma trd off road premium 2023 tundra trd off road
    Being a fellow canuk, rust check and krown are great options. I've used both as well as family and Co workers with great success in keeping rust away. I live in NS, so salt on the roads salt in the air
  9. Aug 24, 2020 at 8:03 PM
    Westsideott
    Ottawa, ON
    2020 DCSB OR
    Many thanks everyone for the input
  10. Aug 26, 2020 at 5:34 PM
    MinookaBlues
    Stock
    Again....6 years and no rust....I'll keep using Krown
    ontarioyota and lynyrd3 like this.
  11. Aug 26, 2020 at 5:52 PM
    RedWings44
    RedWings44 Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4, 2019 MGM 4Runner SR5
    Fluid Film for sure. Just remember that wash from the roads will eventually wash it off of the exposed surfaces such as lower control arms so keep a can or so around to reapply as needed (although it doesn't wash off immediately). Also be sure to rotate your CV axles to get the other sides of those. Krown is good, but as shown in the video; not as good as Fluid Film.
  12. Aug 26, 2020 at 6:09 PM
    lynyrd3
    Bill
    East Central Upstate NY
    Krown
    MinookaBlues likes this.
  13. Aug 27, 2020 at 9:00 PM
    qk90412
    qk90412 Active Member
    Ontario, Canada
    2018 silver TRD OR DCSB
    DD SS3 fogs, Garmin 56 cam, MT BB tires
    Over the years I’ve used Krown but my go to application now is Corrosion Free. Very pleased with the results for both but CF is clear coloured and doesn’t drip. Like other have said, it has to be applied yearly. Whatever you do, don’t get the electronic rust modules that the dealer tries to sell or even throw in as bargaining tool.
    llamasmurf likes this.
  14. Aug 28, 2020 at 9:22 AM
    Northern Taco
    I hear great things about corrosion free, however like any rust proofing, it's reliant on who is applying it and how well
  15. Sep 26, 2020 at 5:05 PM
    llamasmurf
    llamasmurf Herpa Derp
    Wes
    Northern Ontario
    '15 Matte Black TRD AC
    FJ t-case with twin sticks, UTE bed, some other things :D
    I jumped on the Corrosion Free train when I bought my rig,
    4 years on and I see no rust on the underside.
    Even though I was a noob :mad: when I bought the truck and got suckered into the dealership undercoating, the corrosion free has done amazing at keeping it moist and not letting it dry out. It seeps in behind the stock undercoating when I peal it off, there is corrosion free behind it and water is beading up everywhere I peal that crap off.
    I am religious about application though. :cookiemonster:
    Marc70 and Westsideott[OP] like this.
  16. Oct 1, 2020 at 7:35 AM
    Haun0002
    Haun0002 Well-Known Member
    2020 TRD sport 6MT - MGM
    I also got the dealer to undercoat my truck because I thought it would be better and they told me they will warranty any rust. The more I read this forum the more I believe I’ve been conned. Damnit! I’m not going to peal it off but will any product like krown work on top of the undercoat to prevent rust?
  17. Oct 1, 2020 at 7:38 AM
    MikefromCT
    MikefromCT Well-Known Member
    CT
    2013 TRD OR DCSB
    OME Bp-51; Relentless Armor
    Wool wax or fluid film. Theres a handful of kits on Amazon; but i found it was a couple bucks cheaper to go direct at https://www.kellsportproducts.com/. Also found a discount code on a different forum :anonymous:
    Haun0002 likes this.
  18. Oct 4, 2020 at 6:35 PM
    TacoRocco
    TacoRocco Well-Known Member
    Niagara Region, ON
    09 Tacoma TRD OffRoad
    OME 2 inch lift
    I got suckered into the free stealership undercoat after they told me my frame was fine and didn't need to be replaced.
    Is there a way to remove that junk? That being said, whoever did it, did a terrible job.
  19. Oct 4, 2020 at 6:47 PM
    CdnSldr
    CdnSldr ______________
    Canada Eh!
  20. Oct 21, 2020 at 8:46 AM
    bill_bly_ca
    bill_bly_ca Active Member
    Bill
    1997 RHD 90 series LC Prado
    I have used a fellow out of Kitchener (Houghton Rustproofing) for the last 25 years with some fantastic results.
    My 88 Pajero, which I sold last Jan after 17 yrs on Ontario roads, only had a small breakout of rust on the back panel behind the passenger doors. We had an 03 Mazda MPV for 10 yrs and it left us
    It is $89 per coating and I get it done 2x a year. One in July or August - One in March
