Rust proofing
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Paddyd, Jul 25, 2021.
  1. Jul 25, 2021 at 4:07 PM
    Paddyd
    Paddyd [OP] Active Member
    Pat
    2021 Tacoma, Army Green TRD Off Road
    lift
    Hi soon to be new tacoma owner. I just ordered a 21 TRD OFF ROAD With the lift kit.
    I live in Michigan and rust is an issue. What is the best and most effective product to have applied?
    Thanks.
    Tocamo likes this.
  2. Jul 25, 2021 at 4:12 PM
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    I use KROWN Rustproofing. Not sure if you have it in your neck of the woods
    But the most effective is yearly rustproofing, none of those 1 time applications...
  3. Jul 25, 2021 at 4:14 PM
    OMGitsme
    OMGitsme Well-Known Member
    Sold
    Cosmoline. Black is easier to monitor.
    RustyGreen and Skydvrr like this.
  4. Jul 25, 2021 at 4:16 PM
    trouble_shooting
    trouble_shooting Active Member
    Trig
    2021 TRD Off-Road
    I find parking it on salt days and drive my winter beater works best
    ETA: I paid for rust proofing my 2019 Silverado. The only visible thing was sound deadener on the frame rails.
    Keep it clean and touch up when needed.
  5. Jul 25, 2021 at 4:20 PM
    gwiz
    gwiz Well-Known Member
    Indiana
    2020 Tacoma SR5 4x4 V6
    GFC v2
    Indiana here. I get mine treated at Ziebart. Not sure what they use but I’ve got a rust warranty fwiw.
    eta: just noticed you were asking what’s the best option. For that I have no idea, mine’s less than 2 years old.
  6. Jul 25, 2021 at 4:26 PM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    Welcome to TacomaWorld
    Rinse off road salts often.
    Every Spring and Fall apply Fluid Film, Wool Wax, Cosmoline or other soft rust inhibitor.
    NEVER apply rubberized or bitumen based undercoating. They harden and crack sealing in salts while looking pretty, all black and shiny.
    Ziebart is the worst.
  7. Jul 25, 2021 at 5:39 PM
    DrewMaca
    DrewMaca Well-Known Member
    Drew
    2016 TRD Sport 4x4 Double Cab
    Writing from Ontario, Canada. Lots of salt on the roads.
    I get a yearly Krown application on my truck. So 5 years now anyway. I plan on keeping the truck for as long as possible, so that is why I get it done. If you are leasing or plan on trading it in after 4 or so, I wouldn’t bother.
  8. Jul 25, 2021 at 5:43 PM
    Mastiffsrule
    Mastiffsrule Well-known member, but no one cares.
    Scott
    2021 Taco XP Predator
    Tagging along here. Do the newer models need additional treatment on top of factory? Just wondering.
    Just jacked up my 2021 and put a scratch in the rail. Will need to touch it up, but not sure if need to do anything else as well like OP. I am in NC and snows only 1x a year. Mild weather.
  9. Jul 25, 2021 at 5:46 PM
    GT3North
    GT3North Well-Known Member
    Krown.
    Living in Nova Scotia we have tons of salt used on our roads in the winter. Krown is awesome.
  10. Jul 25, 2021 at 5:51 PM
    Stocklocker
    Stocklocker Well-Known Member
    17TRDORDCSBAT
    Tacomas rust because the frame has multiple layers and pockets that collect silt, coupled with the fact Toyota can’t paint metal to save their lives.
    A couple times a year do this:
    Drop your spare and put the truck up on Jack ramps. Accept you are gonna get wet and get right under there with a hose. Wash all the silt off the frame, paying close attention to the crossmember brackets, fuel tank hangers, rear cab mounts, and the C-channel trough. These areas collect salty/wet/silt. Also hose out the front boxed sections (you may have to remove the plastic shields).
    Once washed, coat the frame, especially the trouble spots mentioned above, with a non-hardening rust preventative like Woolwax / Fluid Film / Krown / cosmoline etc.
    Toyota frames general rot where the cross members meet the frames, the gas tank and spare tire hangers, the back c-channel under the bed, and in the front box sections. Keep an eye on these areas.
  11. Jul 25, 2021 at 5:56 PM
    Timetraveler66
    Timetraveler66 Well-Known Member
    Here we go again!!
  12. Jul 25, 2021 at 5:57 PM
    Mastiffsrule
    Scott
    Do you need to go as far as spraying in a cavity wax with a wand in boxed areas?
    Stocklocker[QUOTED] likes this.
  13. Jul 25, 2021 at 6:02 PM
    Stocklocker
    17TRDORDCSBAT
    I have mixed feelings about 3M cavity wax. I sprayed it up in there once, but found it glued some dirt and pebbles that were up in there in place as it hardens quite a bit. Now I use fluid film and the long nozzle you can buy to apply the cavity wax.
    https://www.amazon.ca/KBS-Coatings-...Cavity+wax+spray+nozzle&qid=1627261276&sr=8-1
  14. Jul 25, 2021 at 6:03 PM
    usmc2msu
    usmc2msu Well-Known Member
    TJ
    2017 SR5
    I do. If I can get a wand in it, salt can too.
  15. Jul 25, 2021 at 6:05 PM
    Mastiffsrule
    Scott
    Here come another weekend project.:annoyed:
    Unless I trade in soon.
  16. Jul 25, 2021 at 6:07 PM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    Cosmoline
  17. Jul 25, 2021 at 6:16 PM
    usmc2msu
    TJ
    2017 SR5
    Once you do a really good coating (I use Wool Wax) I found the hardest areas to get have almost none washed off. You really just have to get the high-wash areas yearly, but I know some do a heavy coat every year. It’s not necessary from what I’ve seen on mine. It’s not too bad with a crawler and some jacks….dare I say enjoyable. lol
    Big tall dave likes this.
  18. Jul 25, 2021 at 6:59 PM
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    Many areas have moved away from traditional road salt to a spray on product. Salt gets less effective as the temperature drops below about 20 degrees, the spray product keeps working well below zero -- and it keeps working on your vehicle too.
  19. Jul 25, 2021 at 7:10 PM
    Stocklocker
    17TRDORDCSBAT
    We have brine application where I live so I understand. Ford frames are mostly good in our conditions. Toyota can’t paint a frame to save their lives. They are not only designed to catch silt, with multiple layers you can’t clean between, but are also painted with water colours or house paint or some shit that doesn’t work and never has, hence the endless frame recalls since the beginning of time.
  20. Jul 25, 2021 at 7:15 PM
    Skydvrr
    Nick
    YMH
    Black '17 OR
    Water colors :rofl:
