Rust question
Discussion in '1st Gen. Tacomas (1995-2004)' started by Talstar, Jun 10, 2018.
  1. Jun 10, 2018 at 1:16 PM
    Talstar
    Talstar [OP] Member
    2002 regular cab SR5 Auto 4WD
    Detroit Truetrac
    My 2002 Tacoma is rust free now. I’m thinking about taking it to Ohio this deer season and leaving it for 3 months instead of hauling my atv every hunt.
    What’s the chance of rust in that time span?
  2. Jun 10, 2018 at 1:47 PM
    onakat
    onakat Well-Known Member
    Canada
    2000 indestructaco!
    do they use winter salt and chemicals there? That's what the real killer is. Makes cars rust much faster than they normally would (only takes a few years of exposure to turn a car into swiss cheese).
    If it is going to be driven in the winter salt season, I strongly suggest you get it thoroughly rustproofed or do it yourself with some fluid film
  3. Jun 10, 2018 at 2:10 PM
    Talstar
    Talstar [OP] Member
    Detroit Truetrac
    I may just use my Honda Pioneer instead, don’t won’t to ruin my Tacoma:)
  4. Jun 10, 2018 at 2:21 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Its the company truck
    If you just coat the bottom in fluid film and make sure to also wash off the under side after you dive over road salt you will be fine
  5. Jun 10, 2018 at 4:09 PM
    Talstar
    Talstar [OP] Member
    Detroit Truetrac
    Thanks for the advice.
    I could also limit the use of the truck to the property. At most it would be driven a few miles pavement between our stands. Maybe 50 total miles of highway use for the season.
  6. Jun 10, 2018 at 4:17 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Coat it all in this https://www.amazon.com/Fluid-Film-1...film+spray&dpPl=1&dpID=61WLDzwkaDL&ref=plSrch
    If you have a compressor you can get a gun and buy the stuff in bulk and its alot cheaper and easier to apply
    PvilleJohn likes this.
  7. Jun 10, 2018 at 4:43 PM
    Talstar
    Talstar [OP] Member
    Detroit Truetrac
    I’ll do that, already have a few cans of it.
    Going to order more, thank you for the help.
  8. Jun 11, 2018 at 8:53 AM
    taco57
    taco57 Well-Known Member
    Jeff
    Columbus Ohio
    2003 Tacoma SR5 4X4 2.7 5 speed
    Fluid Film is great!
    Used it on my '03 went through this past winter in Ohio and it looks like I just applied it even after rinsing the salt off several times. Pay particular attention to the bumpers, especially the rear at the hole for hitch, under the license plate. The way the bumper is constructed invites moisture to build up and rust in between the multiple metal plates. Also, the front bumper seems to rust from the inside out around the headlights. Take a look at any untreated rust belt Taco and you'll see what I am talking about.
  9. Jun 11, 2018 at 9:40 AM
    Danno1985
    Danno1985 Well-Known Member
    Milwaukee
    2003 Prerunner TRD Off-Road (RIP)
    I agree with all of this. Fluid film works. My truck originally came from Arizona but has seen two winters here in Wisconsin, which has the shittiest winter drivers in the country and thus some most aggressive road salting, so I've been religious about keeping the underside coated with Fluid Film. So far, it's worked like a charm. I'd also recommend hitting the inner rockers/cab corners through the weep holes, as well as the doors. Mostly though it's your frame you have to be careful with, I really only see significant body rust on 01-04 Tacomas when the truck is obviously totally neglected.
  10. Jun 11, 2018 at 10:11 AM
    Talstar
    Talstar [OP] Member
    Detroit Truetrac
    I appreciate the replies, I’m familiar with fluid film just never used it for that purpose here in North Florida. Ohio winters are a different animal for sure. I plan on spraying, and then spraying again the undercarriage of my Tacoma before hauling it up there.
  11. Jun 11, 2018 at 4:12 PM
    RysiuM
    RysiuM Well-Known Member
    Rysiu
    Was Golden State, now Poland EU
    1995 4x4 LX Ext Cab, I4 2.7, MT, 335K miles
    DD Deck+backup camera, LED DRL, All LED except H4 Hella
    My California truck went so far through two winters is in Poland (salt on the road). Treated with Fluid film every year. So far zero rust. Keep my fingers crossed.
    Dalandser likes this.
  12. Jun 11, 2018 at 4:25 PM
    tony2018
    tony2018 Well-Known Member
  13. Jun 11, 2018 at 4:31 PM
    757yotas
    757yotas Well-Known Member
    Virginia
    2007 TRD Sport
    ICI Magnum front bumer Rigid LED lighting OME lift 285/70 Nitto Exos 17" Fuel Hostage TRD Exhaust TonnauPro Cover Oil Catch Can Tint Pioneer Nav system Sound System LED lighting Euro headlights Paint
    I had to go a whole winter in Northern Michigan last winter, you literally cant find a spec of rust on my truck because i was VERY on top of fluid film and properly washing and taking care of the truck. You will be 100% fine if you fluid film it and wash it 4-6 times while its there
  14. Jun 11, 2018 at 6:01 PM
    golfcarz
    golfcarz Member
    1998 & 2004 extra cab 4x4 sr5
    I wouldn't worry about it at all. The roads are only treated when it ices or snows. Chances are you won't even be driving on a treated road. I live in SW Ohio and I don't think our roads were treated more than 10 times all last winter. Northern OH is probably a different story. Besides driving in salt and snow one or two times won't ruin a vehicle if you properly spray it off. It takes years for vehicles to start rusting here. 3 months of sitting around won't cause any problems. Try to park it on pavement if possible. Parking in dirt or gravel in any state for long periods isn't good.
  15. Jun 12, 2018 at 6:47 AM
    Talstar
    Talstar [OP] Member
    Detroit Truetrac
    I’ll be in the Newark, Ohio area. Last year we had 2 hunts that had snow and only one of them the roads were salted.
