Rust??? Tacomas...
Discussion in 'Toyota Trucks & SUVs' started by Truex56fan, Jul 17, 2012.
  1. Jul 17, 2012 at 9:11 AM
    Truex56fan
    Truex56fan [OP] Member
    MAA
    NJ
    I've been shopping for a gently used Tacoma 4x4 V6 Access cab for many weeks now. Almost all that I've viewed (with mileage lower than 20K) (years 2009 and up) seem to have significant amount of rust o parts/pieces like the trailer hitch, the bolts on the bed racing the cab, underneath the truck on a variety of areas, components around the brake assembly, etc. These trucks have been in markets where there is little to no snow, nowhere near ocean, etc.
    I am asking for feedback because I am now rethinking the vehicle purchase in general. Everyone's feedback would be most welcome.
  2. Jul 17, 2012 at 9:15 AM
    babytruck
    babytruck Babytruck, babytruck...I've got a babytruck :)
    NorCal
    2010 Barcelona AC 4x4 4.0 6spd
    They are around. Mine is a 10 with 8k miles. I don't have rust on the frame, maybe some surface rust like in all vehicles but that's nomal. How much are you looking to spend?
  3. Jul 17, 2012 at 9:34 AM
    TacomaBuzz
    TacomaBuzz Well-Known Member
    CT
    2014 RegCab 4x4 TX Special Edition
    Sirius, Bugflector,back-rack, stepsides.
    Doesn't matter if you drive a chevy, ford, dodge, nissan, or Toyota. Any used pickup truck is going to show slight surface rust. If you want perfect, I would suggest buying new. Surface rust is just that, it looks bad but is only on the surface. the structure underneath is still strong.it can of course eventually compromise the structure if left untreated. they use thin, crappy paint on the undercoat so it's best to repaint it with a good undercoat such as eastwood.
  4. Jul 17, 2012 at 9:35 AM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    Mines an 07 with 18,750 miles. The only thing thats got some corrosion is the muffler/tailpipe...which is normal. The rest of the underside is spotless with no signs of rust. Keep looking and you'll find one in good shape. :)
  5. Jul 17, 2012 at 10:15 AM
    Truex56fan
    MAA
    NJ
    I have a 2005 Subaru which seems to have less rust then most of the Tacomas I've test drove which are much newer and less mileage. Not sure what to think...here is an example of a 2010 I looked at
  6. Jul 17, 2012 at 10:17 AM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    On the coast here , my '09 frame has rust all over it
  7. Jul 17, 2012 at 10:30 AM
    Truex56fan
    MAA
    NJ
    I live in an area where we don't get any significant snow and am 50+ miles from the coast...
    I work with a man who has a Tacoma 2004 with minimal rust. Almost less than what is shown in the previous post with photos.
  8. Jul 17, 2012 at 10:34 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    i'd be concerned about the body rust in the 2nd pic but the frame of that 2010 doesn't look bad at all in my opinion. You should see my 2007 :D
  9. Jul 17, 2012 at 10:37 AM
    BuzzardsGottaEat
    BuzzardsGottaEat Well-Known Member
    Some Toyotas
    Round tires
    Are you on a timeframe for which you need the truck? If you can wait it out I would advise doing so. Something will pop up if given enough time. I was looking for a project and almost "settled" for this and that and even started changing my mind as to what project vehicle I was going to get because there were just no options that weren't high miles and rusted out horribly, then exactly what I wanted in the first place popped up in great condition with low miles and I snagged last second before several other people.
    If you have the time to lay in wait, keep an eye out. If not, good luck I guess. My advice would be if you aren't happy with it don't "settle" and buy it anyways, no matter if other people tell you "its not that bad" or not
  10. Jul 17, 2012 at 10:43 AM
    babytruck
    NorCal
    Mine has way less rust than that. And yes. That truck you pictured has a considerable amount of body rust on that back panel. Something must have happened there. Again, if you don't mind me asking, how much are you looking to spend? I might upgrade.
  11. Jul 17, 2012 at 11:37 AM
    Truex56fan
    MAA
    NJ
    I have been looking for something with 15,000 miles or less and in the range of $24 to $27k dependent on "bells & whistles" of said vehicle : ) I'm in South Jersey.
  12. Jul 17, 2012 at 11:39 AM
    Truex56fan
    MAA
    NJ
    I have time to wait it out although I did want to take advantage of my credit union's 2.5% financing which is only guaranteed thru mid August. I do believe things happen, or not, for a reason, so I'll keep looking and keeping driving my Subaru.
  13. Jul 17, 2012 at 12:17 PM
    babytruck
    NorCal
    Do you drive stick?
  14. Jul 17, 2012 at 12:26 PM
    4banger09
    4banger09 Well-Known Member
    Alex
    Nb, Canada
    09 Tacoma Access cab 4cyl
    Leveled
    I'm on the east coast and my under side looks great just surface rust in the corners of some spots, the guy before me got it undercoated a few times and I just took sand paper and some brake dust cleaner to the bad parts and sprayed it with rocker panel guard. Might try something a little tougher if I'm bored on the days off. Mine looked similar to he pictures above. Mine is an 09 btw.
  15. Jul 17, 2012 at 12:35 PM
    Truex56fan
    MAA
    NJ
    Yes but want an automatic.
  16. Jul 17, 2012 at 6:30 PM
    babytruck
    NorCal
    Alrighty. Another reason to keep it then. :D
