Rust that shouldn’t be!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by JOHNNYPICKLES, Sep 1, 2018.
  1. Mar 18, 2021 at 3:45 PM
    Chris.767
    Chris.767 New Member
    Hi, I have the same problem on my 09, did you end up getting it fixed? If so, how much did it cost ?
  2. Mar 19, 2021 at 3:53 AM
    beaudeen
    beaudeen Active Member
    Ontario, Canada
    2005 trd off road
    Rust Free States are for the WEAK...!!! lol
  3. Mar 19, 2021 at 10:00 AM
    igno1tus
    igno1tus Small member
    Lehigh Valley Area , PA
    '07 Tacoma Access Cab TRD Off Road
    how do you get those plugs out ? They just pop out with your finger nail ? Or is there a special tool ?
    wonder if my 07 has them
  4. Mar 19, 2021 at 10:01 AM
    kgarrett11
    kgarrett11 Master Yoda
    Garrett
    CA desert
    2015 DCLB
  5. Mar 19, 2021 at 10:04 AM
    PackCon
    PackCon Well-Known Member
    Connor
    2017 Subaru Forester Limited
    The rust is occurring from the inside out. Unfortunately the only fix is to cut out the affected metal, re-weld on a panel, and repaint. So it wouldn't be a practical or cost effective fix.
    It seems like water continuously got up under that area, sat, started rusting through. You can see where paint is bubbling, which means the rusting is occurring under the paint job.
    maritimer8 likes this.
  6. Mar 19, 2021 at 4:21 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Keep telling yourself that, LOL.
    beaudeen[QUOTED] likes this.
  7. Mar 19, 2021 at 5:56 PM
    [KD]
    [KD] Used Import
    Dan
    Halifax, NS
    06 DCSB 6MT
    I would hope OP got it fixed under warranty unless that wasn't his '19 in the pic. As for you, most areas where rust is an issue have shops that specialize in replacing rocker panels etc for a couple hundred bucks a pop but for what it's worth you should buy a harbor freight mig welder and some 16 gauge sheet steel and just have at er!
