RUST! Third gen taco
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Conor M, Jun 15, 2022.
  1. Jun 16, 2022 at 5:13 AM
    #41
    Spare Parts
    Spare Parts Well-Known Member
    Southern Maine
    2022 Off Road Premium 4Runner Lunar Rock
  2. Jun 16, 2022 at 5:21 AM
    #42
    Hairless_Ape
    Hairless_Ape Well-Known Member
    South Jersey
    2021 F150
    A thread of who knows best when it comes to rust prevention...I've never seen one of these before.
  3. Jun 16, 2022 at 5:37 AM
    #43
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Welds rust. Sand blast and paint pretty much a yearly thing in the rust belt. I'm in Maine not far from NH they seem to remove snow with salt, my truck gets the once over twice a year with FF it had rusty spots from the factory, granted I own a lift but my frame is black. (I am too after the work is done) It's a 2011.
    Spare Parts likes this.
  4. Jun 16, 2022 at 5:40 AM
    #44
    Oh_Goliath
    Oh_Goliath New Member
    2019 Silver Taco
    Being from Ohio, my 2019 looked the same until last year. Cleaned up all the surface rust and took it to Krown for undercoating. Haven't had any trouble with it since.
  5. Jun 16, 2022 at 5:44 AM
    #45
    Silentshredr
    Silentshredr Well-Known Member
    Chuck
    16 DclbOr4x4
    Not so much. The rust happens during the winter and especially through out spring as freeze/thaw cycles start.
  6. Jun 16, 2022 at 5:50 AM
    #46
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    Rust will happen anytime you have oxygen with a wet, or humid environment. Add salt to that its like throwing gasoline on a fire .
    Drippy4x4 likes this.
  7. Jun 16, 2022 at 5:55 AM
    #47
    Mindgame
    Mindgame Well-Known Member
    22' Offroad limited
    Decals removed
    I'm glad i found this. I live by the coast and would like some or protection underneath.
  8. Jun 16, 2022 at 6:36 AM
    #48
    Spacecoast
    Spacecoast Well-Known Member
    2022 White SR5 2.7L
    Trailer wiring kit, hitch, seat risers
    Does anyone make aftermarket wheel well liners for the Tacoma? The stock liners (if you can even call them that) are totally inadequate and about as thick as a cheap milk container. I can't believe how cheap some elements are of this truck.
  9. Jun 16, 2022 at 7:40 AM
    #49
    Sharpish
    Sharpish Well-Known Member
    Brian
    Victoria, British Columbia, Canada
    2012 Tacoma TRD OR 4x4
    That’s why you thoroughly clean and rinse the frame when the weather warms up then coat it in the summer when it’s dry. He’s advocating coating a wet frame in the spring and trapping salt under grease.
  10. Jun 16, 2022 at 7:59 AM
    #50
    clg
    clg Well-Known Member
    2017 Off-road
    Wire wheel the welds, brush on POR 15 and top coat with semi-gloss tremclad for blending. Before winter hits get underneath and spray all the surfaces with fluid film. If you treat your truck annually, it'll be looking the same a decade from now.
    Welds on these trucks always rust long before the frame, and it'll take a few seasons of neglect before you'll start having frame paint peel. If you treat it before this peeling occurs, you'll have no issues. Make this an annual thing on a hot summer weekend so you can wash and properly dry it ahead of the painting and you'll be fine.
    cammerv8 likes this.
  11. Jun 16, 2022 at 8:40 AM
    #51
    Otterstuff
    Otterstuff Well-Known Member
    2022 White SR5 Access Cab 4WD V-6
    Tube steps, Vision Turbine wheels, bug deflector, seat covers, and tonneau cover
    I agree. They are pathetic. I think a sharp rock will tear them.
  12. Jun 16, 2022 at 11:39 AM
    #52
    cammerv8
    cammerv8 Well-Known Member
    2019 Silver Tacoma Trd Sport DCSB
    Bed inlays stickers
    does not look that bad. will suggest rust reformer. POR-15 you can use a wire brush, to remove the rust flakes, then an alcohol rag to clean the area and then brush the POR-15 that will change the remaining rust to steel oxide and you'll be covered.
    Otterstuff likes this.
  13. Jun 16, 2022 at 12:34 PM
    #53
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
  14. Jun 16, 2022 at 5:50 PM
    #54
    JJ Diablo
    JJ Diablo Well-known member.
    JJ.
    CT
    2021 Cement TRD Sport Premium
    BOSS HTX Snowplow, Bilstein 5100s, Vled reverse light kit, Vled interior lighting, FitCamX dashcam, Timbren SES
    That’s surface rust. Happens to every vehicle in the rust belt . You can spend time chasing after it every year or pay a shop to coat it yearly with Fluid Film or Cosmoline type protection. But its not abnormal.
    cosmic65charlie likes this.
  15. Jun 16, 2022 at 7:00 PM
    #55
    Mozart
    Mozart Well-Known Member
    Cortland NY
    2018 ACLB SR5 4x4 V6
    32” Tires, BPF Front Recovery
    Anyone can insult someone. How about making a convincing argument and proving me wrong? Too cowardly?
  16. Jun 16, 2022 at 7:11 PM
    #56
    Borracho Loco
    Borracho Loco My truck identifies as a Prius.
    DFW, Texas
    2021 Voodoo Blue - Tacoma TRD Offroad DCSB
    Oh look, another mod....
    I'm glad I don't have to worry about this. Wait...do Tacoma owners in North Texas have to worry about this? We never salt our roads.
  17. Jun 16, 2022 at 10:00 PM
    #57
    PinktacoDM84
    PinktacoDM84 Well-Known Member
    Dan
    BC
    2015 trd OR/AC
    St Maxx on Trd pro wheels, mbrp exhaust, k&n cai, jba's, 887's over 5100's, medium dakars and 5125's.
    Not piggy backin on what Ol' Sharpish said there, but your initial comment stating 'bad advise' lacks logic imo. Unless of course you have a heated garage to leave the truck in for minimum a week (I would guess it would take even longer to draw out every bit of moisture in that frame), and a second vehicle to use in the meantime... coating the frame end of summer, after months of dry weather, logically makes sense. Unless I'm missing something?
    Mozart[QUOTED] likes this.
  18. Jun 16, 2022 at 10:01 PM
    #58
    PinktacoDM84
    Dan
    BC
    2015 trd OR/AC
    Also wanted to ask anyone familiar with POR 15, seems to be a few of you suggesting that product, do y'all use the Degreaser and Metal Prep products by them as well?
  19. Jun 16, 2022 at 10:06 PM
    #59
    Cushmaat
    Cushmaat Well-known wiseass.
    SE AZ
    2022 TRD OR 4x4 DCLB MGM
    I have an ‘06 4Runner that spent the first 10 years in the NE. Looked a lot like that 10 yrs ago. Still looks like that today. I’ve done zero to cover/fix/etc. I would bet my paycheck that the interior will deteriorate faster than that frame will rot from here on out. Drive it like you stole it. Keep washing it. Forget it.
    Conor M[OP] likes this.
  20. Jun 17, 2022 at 7:32 AM
    #60
    zoo truck
    None
    If you live around here like in the salt belt, op should take you up on that offer.
