Rust under plastic panel door frame
Discussion in '2nd Gen. Tacomas (2005-2015)' started by gulfcoasttroll, Mar 5, 2018.
  1. Apr 1, 2018 at 7:33 AM
    #41
    WNYTACOMA
    WNYTACOMA Well-Known Member
    Clarence, New York
    09 Metalic Grey TRD OFF ROAD
    Toyota Nerf steps Bugflector 2 Tool box Weathertech floor liners Wet Okole F/R - Bk/Char
    Agreed. I live about a half hour outside f Buffalo and have had a 87'. 00' and 09' Toyota pick ups and have never had that along the rocker. None. I have had some rusting where the seat leg mounts on the door side.
  2. Apr 1, 2018 at 7:40 AM
    #42
    Bajatacoma
    Bajatacoma Well-Known Member
    SC
    05 TRD Off-Road, SR5, 6 speed
    No idea why the seat brackets/bolts on mine would rust; the door sills are OK, no signs of water that I've ever noticed, I don't live in an area that sees snow often, the bolts and panels under the the truck are generally in good shape although everything metal (aluminum or steel) under the hood looks like crap, my frame doesn't show rust even though it's an early production, etc. Toyota just seems to have crapped out on a lot of parts on these trucks, especially the fasteners.
    :annoyed:
  3. Apr 1, 2018 at 7:42 AM
    #43
    Newfiebruh
    Newfiebruh Well-Known Member
    Tom
    2010 Black sand pearl access cab Base
    LED's, Tonneau cover, Fog lights, Front mud flaps, Cooper discoverer a/t3 tires, Tailgate reinforce, Cruise control, LED ditch lights, Bluedriver, 8-ball shift knob, Hitch, SR5 grille.
    I'm shocked it rusted on you in a non salty area. Try some of the rust converter!
  4. Apr 1, 2018 at 7:52 AM
    #44
    spitdog
    spitdog Well-Known Member
    2015 Access Cab V6 4x4 SR5 MGM
    Mine is only rusty right where the bolt goes and the rust goes down to where it rest on the carpet.
    I just now removed the bolt, slipped a baggie over it and sprayed it with corrosion X. I will let it sit that way for a day. Then replace the bolt.
  5. Apr 2, 2018 at 2:31 AM
    #45
    PackCon
    PackCon Well-Known Member
    Connor
    2017 Subaru Forester Limited
    Well do you clean your engine bay?
    What you don’t keep clean will be prone to rusting and corrosion.
    You can get a de-ironizer to spray on areas to help prevent major rusting on certain points.
  6. Apr 2, 2018 at 5:11 AM
    #46
    Bajatacoma
    SC
    Yeah, the engine bay gets cleaned every now and then, at least hosed out, and I never leave mud on the vehicle, not that I intentionally go mudding; I got that out of my system years ago. I actually pulled the bolts on the seats yesterday; the bolts themselves looked OK but the two metal frame rails on the driver's seat had some scale rust on the front two areas. I have Husky liners so it's not like they're getting wet from my feet. I wire brushed them and put some epoxy paint on them. It's just weird how my frame looks fine but so many of the fasteners under the hood and all of the aluminum look like crap. No issues with the body panels either.
  7. Oct 29, 2019 at 5:37 PM
    #47
    Johnyboy
    Johnyboy New Member
    2014 tacoma sr5
    I have the same problem, looks like the salt water gets stuck behind the plastic part and creates rust! wire brush, primer and paint will fixe the problem. after these steps put a 3m film sticker.
  8. Oct 30, 2019 at 10:34 AM
    #48
    jmanscotch
    jmanscotch Well-Known Member
    Jake
    Colorado Springs
    2021 TRD OR DCLB
    Incorrect on the moisture and thus the confusion on why it's so bad. A high salt (and thus acidic pH environment) and some dirt/grime will accelerate metal loss faster than just neutral pH water as an electrolyte for the corrosion cell.
    Newfiebruh likes this.
  9. Oct 30, 2019 at 12:07 PM
    #49
    Collins
    Collins Well-Known Member
    North Carolina
    09' Tacoma, 2.7L, 5spd, 4x4
    OP,
    As rusty as the seat posts look, I'd have a look under the carpets to see what else is lurking there...
    for peace of mind if nothing else.
    goforbroke123 likes this.
