Rust Veto - 342 (Cosmoline) Undercoating
Discussion in '3rd Gen. Tacomas (2016-2023)' started by CdnSldr, Feb 6, 2020.
  1. Dec 11, 2022 at 11:36 AM
    #141
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    If using any rust inhibiter, try to get the chassis clean of any dirt or grease first, just as you would before painting something. I found applying cosmoline on a hot day worked well. Its thin enough where its creeps into everything, yet dries in an hour. You just sweat your butt off doing it. Just be sure to apply a 2nd coat.
  2. Dec 11, 2022 at 12:22 PM
    #142
    North7
    North7 Well-Known Member
    2022 trdor
    ZIP was mainly for aluminum but have know of its use on autos. It was designed to be able to see thru it, mainly inspections required in aviation. Will stay sticky for awhile,, even weeks after Appling. Hot soapy water,power washer will remove most of it. Holds up well but will also get dirty over time. Stinks until dry.
  3. Dec 14, 2022 at 1:18 PM
    #143
    dietcokefiend
    dietcokefiend Well-Known Member
    I have a new 2023 Tacoma with about 170 miles on it right now that has been fortunate enough to only see rain in Ohio so far. I have a basement garage that stays pretty warm... figure 50-60 and I could probably pre-warm it some if it got cold. I have a fresh six-pack of Cosmoline right now... I'm assuming even though summer is best for application, getting this onto the truck before full winter/salt hits is the best thing I could do.... right?
  4. Dec 14, 2022 at 1:26 PM
    #144
    acorn27
    acorn27 Well-Known Member
    2021 MGM TRD DCSB Sport
    Yeah I would say do it ASAP. But you might want to reconsider spraying it in a basement garage. Your house may be not be pleasant after that job.
  5. Dec 14, 2022 at 1:33 PM
    #145
    dietcokefiend
    I'm going to get a dropcloth to catch any drips and that sort of spray, but my garage is closed off from the other half of the basement. My plan is a nice carpet-drying type air-moving fan to keep the space well-ventilated.
  6. Dec 14, 2022 at 3:34 PM
    #146
    skidooboy
    skidooboy titanium plate tester
    central lower mich
    2019 Tacoma Sport KDMax Tuned, Cement
    dd light bars, trd cat back exhaust, KDMax tuned, trd skid plate, 2" lift, sema wheels toyo open country at3 tires.
    do it before the salt hits, FOR SURE! warming the room is a good idea but, not required. warming the liquid you are going to spray, would be a requirement. try to warm the cans to 75-85 degrees, and keep them in that state, until you are ready to spray, each individual can. the warmer and thinner the material the better it will spray, and give you better coverage. MAKE SURE TO HAVE GOOD VENTILATION, AND WEAR EYE, AND BREATHING PROTECTION. Wearing a mask is good but, wearing a disposable type 3m refinishing respirator, is the best protection for your lungs. get to it before it snows. your truck depends on you.
    Ski
  7. Dec 14, 2022 at 3:51 PM
    #147
    dietcokefiend
    I'll have some good airflow once it starts. I don't mess around with breathing though, I got a P100 welding mask or some other p100 half masks to use. Might be smelling some of it but won't be breathing in more than vapors.
    Eye stuff I have some old glasses to use but not worried about that too much. I'll have a carpet fan under the front bumper blowing out the garage so any must not bonded will just get blasted out into the driveway.
  8. Dec 18, 2022 at 11:44 AM
    #148
    dietcokefiend
    Got the help of my kid and went to town on the truck today. Got three cans worth on the main areas and under the bed/spare tire area.
    Got three cans remaining. Need to probably remove the wheels next but taking a break. Hit some holes with the straws and I can see why people hate them. It's not the spray blasting them off, it's hitting whatever under the truck lol.
    Aiming for a solid 85% good job. I don't have proper jack stands for this truck yet so this has all been on my back crawling around. Wheels off I'll use my jack and old stand, but I really don't trust those for being under the Taco. Need some nice Esco ones.
  9. Dec 18, 2022 at 4:48 PM
    #149
    zoo truck
    None
    Getting some ramps could be helpful for more clearance if crawling around with no jack stands. Removing the wheels allows you to get at the chassis easier, but some ramps might be the best next thing.
  10. Dec 18, 2022 at 6:34 PM
    #150
    dietcokefiend
    Ended up getting my existing floor back and back stands to suffice and sprayed the wheel wells and metal bits. Got about 2.5 cans left, I think I got things like 80-85%, remainder would be parts of the rails next to fuel tank or muffler that I couldn't really reach.
    Being a SE Ohio truck we see snow occasionally and I have a an underbody sprayer for salt. Main thing was getting all the frame weld points in spray zones. What a massive PITA. Glad my hazmat suit took the brunt of the overspray and a ton of Amazon boxes.
  11. Dec 19, 2022 at 4:56 AM
    #151
    zoo truck
    None
    Now your ready for the 2nd coat. Be sure to get inside the boxed sections of the frame. Surprised that stuff drys in this colder weather without dripping off. I did mine when it was 95 degrees out. That stuff went on nearly like painting a car. Got on 2 nice heavy coats.
  12. Dec 19, 2022 at 5:43 AM
    #152
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Maine, right next to New Hampshire where they clear the roads with salt. 2011 150K black frame FF in the fall every year gallon is good for 2 years. Any thing that shows surface rust gets blasted and painted. I don't care what my frame looks like and I doubt any one will craw under it for a look messy maybe covered yes. Took it to the dealer for the now or never rust inspection they basically said "get out of here".
  13. Dec 19, 2022 at 6:13 AM
    #153
    dietcokefiend
    Got a garage that stays at about 50F, so wasn't too bad. Offgassing is still nuts lol.
    But goal was getting a good amount in before it sees any salt and stuff. Going to attack it more when it gets warmer and keep an eye on things. Smells so bad in my basement right now lol. Needs a rest to not gas the family out.
  14. Dec 19, 2022 at 7:46 AM
    #154
    Braden801
    Braden801 Well-Known Member
    Utah
    2023 trd pro Tacoma
    TBD
    What are everyone's thoughts on Rhino lining?
  15. Dec 19, 2022 at 7:54 AM
    #155
    dietcokefiend
    As chip protection, it would be nice but its a risky bet since the material will hold up to rust pushing behind it for a long time.
  16. Dec 19, 2022 at 8:52 AM
    #156
    zoo truck
    None
    As far as smell fluid film isn't a whole lot better. Crazy doing it in a garage unless you have good ventilation. I used a tarp under mine outside in the driveway.
  17. Dec 19, 2022 at 9:16 AM
    #157
    dietcokefiend
    I had the floor under the truck loaded up with Amazon boxes and then a huge carpet drying air mover in front of the truck that I had giving me a breeze pushing the smell into the driveway. The only bits that smell right now is the offgasing.
    Wife says the basement hardly smells of it with my truck at work now. :cookiemonster:
  18. Nov 16, 2023 at 10:17 AM
    #158
    offroadguy651
    offroadguy651 Well-Known Member
    The North
    2023 TRDoffRoad
    5100's 1.5 front. 1 inch Eibach block in the rear. KO3 285/70/17 RRW RR6-H 17x8.5.
    Cosmoline is the best of the best.
    faawrenchbndr likes this.
