Rust worries when drilling body/frame???
Discussion in '2nd Gen. Tacomas (2005-2015)' started by RacerAV, Jun 7, 2011.
  1. Jun 7, 2011 at 3:22 PM
    RacerAV
    RacerAV [OP] Well-Known Member
    OC, CA
    '09 DCSB4x4 (sold)
    When I put my sliders on, I noticed small bits of rust around the frame rails, more in the crevices, etc. Then I had to drill holes in the frame, to bolt the AP sliders, should i coat them with anything? what kind of rust damage can happen over say the next 10 years? anything to worry about? Im a little OCD and dont like knowing its under there.. Been thinking of taking my angle grinder with a steel brush wheel, going to town under there, THEN rubber spraying EVERYTHING, including wheel wells, (to quiet it down) ... ive done this on a couple other cars with great success... what do you think???
    Thanks
    Adamo
  2. Jun 7, 2011 at 5:35 PM
    JKD
    JKD Well-Known Member
    Any time I drill a hole in vulnerable metal, I paint it or otherwise try to provide some sort of seal against corrosion.
  3. Jun 7, 2011 at 5:38 PM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    X2
  4. Jun 7, 2011 at 9:02 PM
    808hiker
    808hiker Taco addict
    Justin
    Big Island, Hawaii
    Yeah it would be a good idea to paint it. Bare metal is asking for rust to start forming. However, I would personally not use rubber spray on the undercarriage since some claim that it traps moisture and makes the frame rust under rubber coating. Without rubber coating, you would actually be able to see the rust forming and take care of the problem before it gets out of hand.
