rust
Discussion in '1st Gen. Tacomas (1995-2004)' started by candyrox1, Oct 24, 2016.
  1. Oct 24, 2016 at 1:28 PM
    candyrox1
    candyrox1 [OP] Member
    jr
    central il
    03 sr5
    the under carriage of my 2003 is shot. is it feasible (worth it) to replace the differential, springs et al to deal with a leaky rear end? it's an SR5 4x4 in otherwise good shape, just over 100,000 on it, but I'm too old and inexperienced to do much of the work myself. thanks
    ChadsPride likes this.
  2. Oct 25, 2016 at 3:42 AM
    neatoneto
    neatoneto Well-Known Member
    CT/Mass
    2020 TRD Off Road DCSB
    Pics would help us give you a good answer
  3. Oct 25, 2016 at 10:53 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Just what are you calling the under carriage ??
    If you mean the Frame I would address that issue before a leaky axle housing
  4. Oct 25, 2016 at 2:55 PM
    candyrox1
    jr
    central il
    03 sr5
    specifically the axle housing. its leaking and the fill plug is very badly rusted so I can't easily top it off. if I replace it the springs and u-bolts would be done as well maybe wheels too
  5. Oct 25, 2016 at 3:37 PM
    Wyoming09
    New Tripoli Pa
    Super Springs
    Since this is a 2003 does the truck have a new frame ??
    You plan to get a used axle swap your differential in or hunt for a used axle with the same gear ratio??
    Are you doing this yourself or needing to pay someone ??
    Only you know or can decide if this is worth doing
  6. Oct 26, 2016 at 3:18 PM
    candyrox1
    jr
    central il
    03 sr5
    hi, I didn't qualify for a new frame; I'm not sure I understand your second question (and will have to do some research to find the gear ratio); I will have it done with maybe me helping a little; it's definitely subjective as to whether or not it's worth it- I was hoping to hear from people who have done it so I could figure it out
  7. Oct 27, 2016 at 1:32 AM
    Wyoming09
    New Tripoli Pa
    Super Springs
    Your front and rear gear ratios need to be the same if not they will both turn at different speeds not good for the transfer case
    Maybe look into fixing the axle that is the truck now
    It would be cheaper get the old fill plug out replace with a new one
    Using a epoxy suitable for gear oil fix your leak then paint .
    what else would you do while the axle is out ??
    Here in Pa I have never been able to get U Bolts off without cutting due to all the rust on the threads
    New Springs are just going to add to the over all cost
    Your going to have your labor cost even if it is only food and beverage
    Hunting for a used axle purchase price transportation or pick expenses
    What are the rear brakes like ?? I find it easier to remove them to get the axles out unless you plan to just roll the old axle out and the used one in
    Really hard to put a price when at this time there are so many unknown costs
  8. Nov 8, 2016 at 4:08 PM
    candyrox1
    jr
    central il
    03 sr5
    I used permatex cold steel and it worked about a day so today I traded for a 2015 sr5 4x4 with only 6,000mi. i'll miss the old fellow but the rust issue had me considering gmc. thanks for your input
