Rusted out Rear Axle Housing PICS
Discussion in '1st Gen. Tacomas (1995-2004)' started by mdenesha34, May 9, 2011.
  1. May 9, 2011 at 4:39 PM
    mdenesha34
    mdenesha34 [OP] Active Member
    Rochester NY
    2002 SR5 TRD
    This is my 2002 Tacoma with 145,000 miles
    [​IMG][​IMG][​IMG][​IMG][​IMG][​IMG]
    Any thoughts? Currently looking for a bare housing, but not having much luck here in NY. Might try to weld it..
  2. May 9, 2011 at 4:39 PM
    truckboattruck
    truckboattruck is one of the sharper tools in the shed
    evan
    MD
    silver sport
    99superjet 11ktm350
    :redxfall:
    use an image hosting site like tinypic/photobucket.. or upload to tw
  3. May 9, 2011 at 4:40 PM
    JLee
    JLee The Man! Vendor
    Jerry
    Grass valley CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    Pics are not working.
  4. May 9, 2011 at 4:53 PM
    mdenesha34
    Rochester NY
    2002 SR5 TRD
    How about now?
  5. May 9, 2011 at 4:54 PM
    truckboattruck
    evan
    MD
    silver sport
    99superjet 11ktm350
  6. May 9, 2011 at 4:55 PM
    JLee
    Jerry
    Grass valley CA
    Nope
  7. May 9, 2011 at 4:56 PM
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    don't use drop box. Try something like tinypic or photobucket
  8. May 9, 2011 at 5:00 PM
    mdenesha34
    Rochester NY
    2002 SR5 TRD
    Thanks truckboattruck... hopefully it worked this time!
  9. May 9, 2011 at 5:02 PM
    Sigi
    Sigi Well-Known Member
    Sigi
    Sfv ca
    06 tacoma 4x4 trd offroad
    that sucks. I'm glad i live in california.. Don't have to worry about rust!!!
  10. May 9, 2011 at 5:03 PM
    KBToyota
    KBToyota Well-Known Member
    Kurt
    Spotsy, Virginia
    96 Tacoma V6 4X4
    OME 883, 5100 all around, Wheelers 3 leaf progressive aal
    Wow, I lived in New England and never saw anything that bad. I would think the salvage yeard would be n easy find. Next time some preventative maint. might be the best bet.
  11. May 9, 2011 at 5:04 PM
    92LandCruiser
    Nevada
    Cummins, tons, 40s
    I'm seeing them now. Yes pretty damn rusty, but doesn't look like its rusted through. Where is the leak coming from? Get an angle grinder with a wire cup wheel and go to town.
  12. May 9, 2011 at 5:07 PM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    WOW! hows your frame look??
  13. May 9, 2011 at 5:11 PM
    AC13JohnG
    AC13JohnG Señor Member
    Black 5 lug
    Preventative maintenance my ass, you shouldn't have to worry about maintaining a frame or rearend! A god damn body shouldn't rust if you regularly wash it either! Fucking manufactures should build vehicles that last in all road conditions! :mad: Ok I'm done being mad. :D
  14. May 9, 2011 at 5:12 PM
    mdenesha34
    Rochester NY
    2002 SR5 TRD
    Brought it to a dealership a month ago and they said the frame was alright and didnt need to be replaced yet. I did some preventative maintenance. I purchased it 3 years ago with 95,000 miles and immediately had the bottom coated by Ziebarts.. Did it the following year, had a horrible experience and didnt go back last year. Ziebarts blows in my opinion, and obviously they didnt clean it well enough and i think it actually may have made the rust worse.
    The rust is actually coming from right in the bottom middle of the axle housing.. I wipe it off and then out of nowhere it seems oil starts to appear on the housing
  15. May 9, 2011 at 5:37 PM
    mdenesha34
    Rochester NY
    2002 SR5 TRD
    Its too bad that from the pictures you can't really get a feeling for the size of the flakes coming off.. not only in diameter, but their thickness also
  16. May 9, 2011 at 5:38 PM
    92LandCruiser
    Nevada
    Cummins, tons, 40s
    I'd hit it with a wire wheel, if you don't have an angle grinder you could use a drill with a wire wheel. Get it down to clean metal and see how you're looking. Might try hitting it with a ball peen hammer, make sure it's sound. But it'd be pretty hard to rust all the way through these housings. If it's not leaking from one of the plugs my guess is it's cracked some where. I think the rust is bad but not as bad as it looks. Like I said, get it all cleaned off with a wire wheel and you'll be able to see what's going on.
  17. May 9, 2011 at 7:25 PM
    WASTE MANAGEMENT
    WASTE MANAGEMENT Well-Known Member
    Travis
    Umatilla Florida
    97 tacoma 4x4 3.4 w/5 speed
    new 31x10.5 tires, mag wheels, drilled rotors, new sound, and a cb.
    I'm from Florida, we don't have rust like that here. What is this Ziebarts that you say they sprayed it with, is is a rubber coating like a bed liner or a chemical that oils the metal like cosmoline?
  18. May 9, 2011 at 7:32 PM
    05tacoSPORT
    05tacoSPORT Well-Known Member
    Tennessee
    TRD SPORT
    Geared and Locked
    sell it, and wash the next one and undercoat yearly
  19. May 9, 2011 at 8:29 PM
    mdenesha34
    Rochester NY
    2002 SR5 TRD
    sell what, the whole truck?
  20. May 10, 2011 at 11:09 AM
    DblCabMN
    DblCabMN Well-Known Member
    Mpls, Minnesota
    03 DC TRD/LTD
    Bilstein 5100's all around - Toytec/Eibach 112-620 Coils, Wheelers 5-Pack+Wheelers 2"AAL. 33x10.5x15 KM2s - Siped on Summit Racing 84-5883 rims with 3.750 BS. 4.88s. Demello HD round sliders. Home built full skids. Home built front bumper. Plasti'd badges. Energy Susp. steering rack bushings. Sway bar delete. Deck plate mod. aFe Pro-Dry. Gibson exhaust.
    Nah, forget selling, brush it down so you can see if it's cracked. keep an eye out for used/salvaged rears and bring your truck to the dealer every 6 months for a frame inspection. If i'm looking at the right part in your pics, your frames already pretty rusty. Don't let someone else get that %150 value $$$ just wait patiently and keep an eye on your levels. I smell a nice check in your future.
