Rusted out stabilizer bar frame mount
Discussion in '1st Gen. Tacomas (1995-2004)' started by chadthurow, Jul 20, 2014.
  1. Jul 20, 2014 at 7:46 AM
    chadthurow
    chadthurow [OP] New Member
    Northern WI
    99 TRD
    Any one out there have a solution for my 99 tacoma. The bracket that is fatory welded to the frame you would normaly bolt your bushing and stabilizer bar bracket to has rusted off my frame on the pasenger side.
    Is there any one out there that has a junk tacoma that is willing to torch this part off for me?
    Or is their a better pro mod i could do?
  2. Jul 20, 2014 at 8:08 AM
    dispatch55126
    dispatch55126 Well-Known Member
    MN
    2004 Xtracab SR5
    Complete OME kit w/ 881's and dakars. All-Pro Sliders, CB, HAM Radio and various other minor stuff.
    Call the dealer first and see if your frame can be replaced under recall. Brackets falling off from rust is not a good sign.
  3. Jul 20, 2014 at 8:50 AM
    Andy.G
    Andy.G Well-Known Member
    Andy
    Virginia
    96 tacoma sx 4x4 2.7 5 speed
    Started automatic. Swapped to manual
    Better do it now, because you are at 15 yrs!(frame recall).^^^^
  4. Jul 20, 2014 at 9:03 AM
    Snowman
    Snowman I have a problem for your solution…
    Craig
    Somewhere in Canada
    Check out my build
    They don't replace '99 frames. They crushed the truck and paid the owner for it. That has expired so unless the frame was checked and passed before, you have to fix it yourself.
  5. Jul 20, 2014 at 9:04 AM
    dm1215al
    dm1215al Well-Known Member
    Dan
    Fl
    2014 TRD Offroad 4x4
    Step tubes,Window tint, HomelinK rear view mirror, changed the entune image screen Rear Differential Breather Relocation Extended AC condensate hose KB Voodoo tailgate cap Redline Tuning QuickLIFT ELITE hood lift system.
    :eek:That is really bad.
    I started to inspect the new truck every month for rust.
    If I see any it gets sanded down and touched up with a rattle can.
    Some of these pictures oh here showing rust really scares me.
  6. Jul 20, 2014 at 11:04 AM
    Andy.G
    Andy
    Virginia
    Best thing op would get is buyout assuming it's been in for recall in past 5 yrs here. That's what haopened to a buddy of mine.
  7. Jul 20, 2014 at 6:47 PM
    tacomataco2
    tacomataco2 A dude
    Mass
    15’ ACLB
    Some of this Some of that
    if that happened i really bet theres more than a few holes somewhere in that frame
  8. Jul 24, 2014 at 8:29 AM
    chadthurow
    Northern WI
    99 TRD
    Took it to the dealership today. The recall expired 8 months ago so no luck their. I was able to order the part from them and it only cost $34.00.
    I did check the frame over my self everything looks solid other than some flaking.
  9. Jul 24, 2014 at 3:23 PM
    Andy.G
    Andy
    Virginia
    If I were you op I would wire brush,scrape that flaky stuff and paint with rust inhibitor.then topcoat.
