Rusted rockers
Discussion in '2nd Gen. Tacomas (2005-2015)' started by WV_DAVIS, May 16, 2017.
  1. May 16, 2017 at 2:12 AM
    WV_DAVIS
    WV_DAVIS [OP] Member
    Hi all,
    So I have rust on both rockers on my 08 Tacoma and can't pass inspection. Was hoping someone makes these or knows the best way to fix this problem.
    Thanks in advance
    ChadsPride likes this.
  2. May 16, 2017 at 4:55 AM
    91859706 I like Toyota trucks.
    Ithaca, NY
    2006 DCSB TRD OR
    What state? That's insane...both you rusted through rocker panels and the fact that that is failing your inspection!
    Can you take another picture? Looks like the pinch joint is rusted through, not a body shop expert but will probably need to be cut out and welded back together at this point.
  3. May 16, 2017 at 7:57 AM
    WV_DAVIS
    I'm in West Virginia... brutal winters sometimes. Here are two more pictures, one of each side.
  4. May 16, 2017 at 8:16 AM
    Ithaca, NY
    2006 DCSB TRD OR
    And that caused it to fail inspection? I live in central NY and I see trucks driving around with no fenders or rocker panels and they pass inspection...
    I'm no expert but I feel like you may be getting taken for a ride. What I mean by that is that they are telling you that you need unnecessary work done to your truck for it to pass inspection so they can make some money off you.
    My suggestion is find another person to get it inspected...someone who won't rip you off.
    Again I could be wrong but rocker panels are cosmetic not structural.
    I would take a look at this also: http://www.wvsp.gov/forms/Documents/MVI-Manual.pdf especially pages 53 and also page 36 section 11.
    From page 53
    1. Bumpers, fenders, exterior sheet metal and moldings have broken, sharp edges, or abnormal protrusions extending beyond normal vehicle extremities that would be hazardous to any person likely to come in contact.
    Is that rust really posing a threat to someone because of a sharp or jagged edge?
    Now as far as fixing it, you will need new rockers for that, or at the least to cut out all the rust and weld new metal back in.
    For reference I made a post about rust on my rocker panels earlier this year. I have a 2006 with some surface rust at the pinch joint. I am not at the point of having to replace them and think I can subdue the rust with some sanding/grinding and rust reformer and also spraying the inside of the rocker with Eastwood internal frame coating spray. I would suggest doing something similar to every other cavity on your truck before they all look like that.
    Good luck and find a new inspection site!
    ChadsPride and tomwil like this.
  5. May 16, 2017 at 8:28 AM
    SoCalSteve
    SoCalSteve Sunshine Tax
    San Diego
    2017 F150 XLT
    What's your frame look like?
  6. May 16, 2017 at 8:30 AM
    Ithaca, NY
    2006 DCSB TRD OR
    That was gonna be my other question, did the frame pass inspection?
  7. May 16, 2017 at 8:33 AM
    JeffreyB
    JeffreyB Well-Known Member
    Jeff
    2015 Access Cab 2.7 5 Speed 4X4
    Fiberglass will fix that up enough for inspection. Frame would be another story.
    ChadsPride and PintSize like this.
  8. May 16, 2017 at 8:37 AM
    PintSize
    PintSize Crossthreaded & torqued down
    Texas
    2011 2.7L 5 spd RC 4x4
    I had a truck pass inspection with rust holes using duct tape to cover.
    1mike1888 and ChadsPride like this.
  9. May 16, 2017 at 8:39 AM
    PintSize
    Texas
    Works good for about 2-3 years and then you gotta patch with sheets of fiberglass. :rofl:
  10. May 16, 2017 at 8:47 AM
    JeffreyB
    Jeff
    Yup, it'll keep rusting underneath, but you'll be in code anyway. That area is hell for vehicles of all makes. I'm always amazed at how new the average car on the road is in the Ohio, WV, Western PA area. They just don't last more than 10-15 years because of the salt in the winter.
    PintSize[QUOTED] and ChadsPride like this.
  11. May 16, 2017 at 9:58 AM
    Dragons Taco
    Dragons Taco Well-Known Member
    Derek
    Cary/Raleigh NC
    06 Black TRD-S 4WD 4D 6SPD and MINE!
    Can ya spell Tonneau
    If replacing the metal by cutting and welding is out of scope right now, there is a lasting solution.
    I have had good luck with Evap-o-rust .
    I had to treat my roof before I coated it with bedliner. It seems to have done the trick with the rust not coming back.
    I covered the area with paper towels soaked in Evap-O-Rust to keep the product on the effected area. I then covered it all up with plastic wrap.
    The rust will turn to zinc oxide, sealing it and allowing you to paint or glass over it.
    You could then use filler with long strands of fiberglass to reinforce it. Sand it smooth and cover it with a bed liner. Bed liner (various brands) will hide the imperfections and contribute to the rigidity of the repair. You can tint some of them to the color you want or keep it contrasting. You could use color matched paint instead.
    91859706 and ChadsPride like this.
  12. May 16, 2017 at 9:59 AM
    Dragons Taco
    Derek
    Cary/Raleigh NC
    C'mon @ChadsPride You are going so fast you aren't even reading them.
    ChadsPride and 91859706 like this.
  13. May 16, 2017 at 10:31 AM
    Ithaca, NY
    2006 DCSB TRD OR
    @ChadsPride are you in your own Tacomaworld time zone?
  14. May 16, 2017 at 10:33 AM
    ChadsPride
    Sponsored by TacomaWorld.com
    Something of the sort :p
