Rusted/Stripped Nuts on Front Coilover Mounts
Discussion in '1st Gen. Tacomas (1995-2004)' started by Sodom, Jul 18, 2017.
  1. Jul 18, 2017 at 6:41 PM
    Sodom
    Sodom [OP] Well-Known Member
    New England
    2001 Xtra Cab SR5 4x4 3.4L 5-Speed Gold
    Rust
    I'm replacing my front stock coilovers with some Foxes. I'm having a very difficult time actually removing the stock ones however. The 3 nuts holding them in at the top won't budge. These are 14mm, correct? I put a 6pt socket on one of them and stripped it incredibly easily. Same story with another one, and on the third, a 13mm actually fits over it.
    My frame was replaced, but I don't know when. Regardless, Toyota had to take off the assembly and mount it onto the new frame. Anyhow, the studs and nuts are rusted to Hell. I've been soaking them in PB Blaster for the week prior to attempting this.
    Has anybody had to cut these out? Any advice or tips for doing so?
    I haven't bothered trying to look at the other side yet. I was able to loosen the 19mm bolt holding the bottom of the shock in though, so that's good.
  2. Jul 19, 2017 at 1:30 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Living here in Pa when I went to change The front Suspension every one of those twisted out so the whole piece just spun.
    I broke out the 4.5" grinder and cut them all off Using a cutting disc not a grinding one.
    It was a pain but the only way they were coming off.
  3. Jul 19, 2017 at 7:00 AM
    frizzman
    frizzman Well-Known Member
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    OME 2.5,Tundra 17s,Falken Wildpeak AT3W hitch w/ 7-pin, ARE cap, JVC HU w/BT, HID/LED lights
    ^ exactly. cut them off and get new ones. we rust belt people know all too well.
    not sure if they make SS quality ones or not but you can put grease on the new studs and nut once they are on to deter any future rust.
    TooMuchToDo likes this.
  4. Jul 19, 2017 at 7:09 AM
    Seagull233
    Seagull233 Well-Known Member
    Tom
    Upstate New York
    2004 DC 4x4 V6
    BMW seats, OME Suspension, CBI and NWTI plates front and rear, 13,000 winch, LED light bars, Ham Radio, topper with roof rack added, stainless exhaust, 2nd battery, inverter, sound deadener
    As a fellow "rust belter", I have adopted the policy that any nut or bolt that I remove goes back on with a liberal coating of anti-seize compound (obviously excluding those that get locktite). Recently removed my trailer hitch after 12 years, and the nuts were still shiny on the inside!! Same with my leveling disks on top of the coilovers, came right off last year.
    ClevSix and mechanicjon like this.
  5. Jul 19, 2017 at 8:54 AM
    Wyoming09
    New Tripoli Pa
    Super Springs
    I buy Never seize buy the case
    I can`t recall putting Locktite on anything unless it was machinery installs
  6. Jul 19, 2017 at 7:08 PM
    Seagull233
    Tom
    Upstate New York
    2004 DC 4x4 V6
    Nor I on the locktite, but didn't want someone to ding me on that point if I was forgetting something.
  7. Jul 23, 2017 at 10:51 AM
    Sodom
    New England
    Rust
    Thanks for the help; I was able to cut the nuts off with a Dremel tool. Wasn't as hard as I thought it would be.
    Dalandser and 12TRDTacoma like this.
