Rustoleum and Fluid Film
Discussion in 'Technical Chat' started by Bayrider, Nov 14, 2011.
  1. Nov 14, 2011 at 6:21 AM
    Bayrider
    Bayrider [OP] Active Member
    Kal
    Hatteras,nc
    4dr,4wd,v6 auto
    After reading several posts on rust and rust proofing, I think I will paint the under carriage of the truck, since it is brand new, with Rustoleum and spray it several times a year with Fluid Film. Does Rutoleum require a primer?
  2. Nov 14, 2011 at 6:52 AM
    mjp2
    Milton Juevo Portimous II
    NJ
    Current: '21 Bronco Badlands. Previous: '06 TRD Access Cab, v6, 6-speed
    Thread moved to the proper section.
  3. Nov 14, 2011 at 7:03 AM
    Hardscrabble
    Hardscrabble Well-Known Member
    Scott
    McDonough, GA
    ‘20 Sport M/T AC 4WD & '15 TRDOR DCSB 4WD
    A little of this and a little of that.
    I've always painted the frames, fender wells, axles, and various brackets of my trucks with rattle can black paint. It keeps the truck looking good from the ground up.
    I don't currently live where they salt the roads, or near the ocean like you, but I've never had any rust issues on frames.
    I'm not 100% sure, but I don't think you need to primer before using rustoleum. Follow the instructions and you'll be golden.
    Good luck.
