Rustoleum Truck Bed Coating Spray on Toyota OEM Tube Steps
Discussion in '2nd Gen. Tacomas (2005-2015)' started by joe812, Nov 17, 2010.
  1. Nov 17, 2010 at 8:24 AM
    joe812
    joe812 [OP] Well-Known Member
    Joe
    NJ
    ARE LSII Cover w/ BedRug, CravenSpeed Shorty Antenna, Husky Liners, Wet Okole Seat Covers, OEM Tube Steps, Bilstein 5100 set @ 1.75 with rear leaf TSB.
    I am thinking of spraying my Toyota OEM Tube Steps with Rustoleum Truck Bed Coating.
    http://www.rustoleum.com/CBGProduct.asp?pid=367
    Any advice on preparing the steps besides removing the plastic caps and making sure it's nice and clean? Do they need to be sanded as well?
    Anyone have any experience with this Rustoleum product?
    I called a local Line-X store and they quoted (ballpark) $250-$400. That's not gonna happen. I would ditch the steps but they are functional for my wife, dog, etc.
  2. Nov 17, 2010 at 8:30 AM
    Mark C.
    Mark C. If you want it bad, you usually get it bad!
    Mark
    Connecticut
    2010 MGM SR5 4WD AC
    LED Dome, Reed Switched LEDs in Glove Box and Center Console, Bumper Fogs, Tailgate anti-theft, LEDs over Cig lighter, Back-up camera anytime, Outside Temp add-on, Hidden GPS power, Sockmonkey 3rd Brakelight decal, 4X4 switch illumination, reed switch controlled engine compartment Flood LEDs, Elite Hitch Cover, Plasti-dipped cupholders and door switch control panels, Elite Hitch Cover.
    sub'd. Am curious too!
  3. Nov 17, 2010 at 8:50 AM
    Pugga
    Massachusetts
    '18 Ford F-250 SCREW
    F-250 Land Yacht Mod
    I'd rough 'em up a little bit to make sure it sticks. When you clean them, wipe them down with rubbing alcohol to remove any oil residues or wax.
  4. Nov 17, 2010 at 10:31 AM
    fatsac
    fatsac Well-Known Member
    Millbury, MA
    07 Tacoma DC Offroad
    Katz Leather, heated seats, Tint, KN Filter, OME 887, Camburg UCA, Dakar packs, 17x9 XD, 295/70 Toyo MT w cab mount chop, fender massage, Weathertechs, Black PC steps, skidplate, 2012 grill, Bushwacker painted flares, Nearly every TSB you can think of, TRD quickshift, All-Pro front w/ Skids, 9k winch, Tonneau cover, voodoo tailgate cap...
    Same issue here. I like the OEM steps but hate the color. They're at the powdercoat shop now since painting will chip too often, IMO. $175 for the pair and aftermarket TRD skidplate.
    Regarding the step pads, I'm planning to break the clips and glue the pieces back in place. There is no way in hell anyone could get to all those clips. Some good gorilla glue should work. I hope!
  5. Nov 17, 2010 at 11:15 AM
    Pugga
    Massachusetts
    Hilti makes a very nice construction epoxy that is used to hold in relocated anchor bolts... If Gorilla glue doesn't work, that stuff certainly well.
  6. Nov 17, 2010 at 11:32 AM
    fatsac
    Millbury, MA
  7. Nov 17, 2010 at 11:52 AM
    joe812
    Joe
    NJ
    Thanks for the pic. Maybe I'll look into Herculiner.
  8. Nov 17, 2010 at 12:02 PM
    fatsac
    Millbury, MA
    Just found out replacement pads are $50 each. OUCH!!
  9. Nov 17, 2010 at 12:07 PM
    BakoTruck
    BakoTruck Well-Known Member
    Herbie Hancock
    Bakersfield, CA
    05 PreRunner TRD
    Mostly stock for now, I have added a cb radio, various cheap mods and I plan on adding aftermarket wheels and other items in the future.
    You may also want to look into rubberized coating spray, I have used it once and it worked good. Good on price too.
  10. Nov 17, 2010 at 12:32 PM
    Pugga
    Massachusetts
    Haha, yeah, thats the stuff. We had to verify the strength of that stuff so we tested it by drilling an anchor bolt into a concrete footing and pulled the bolt to 80,000lbs. Stuff still didn't let go! It's obviously overkill and I wouldn't use that except for a last resort. It's expensive but it certainly works well!
  11. Nov 17, 2010 at 12:37 PM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
  12. Nov 17, 2010 at 1:00 PM
    28Gauge
    28Gauge Well-Known Member
    Brian
    Grapevine, TX
    06 PreRunner SR5
    Sockmonkey Graphics, K&N Drop In Air Filter, 265/75/16 Bridgestone Dueler A/T's, Weathertech Digital Fit Floor Mats, Dee Zee Bed Mat, Map Light/Dome Light LED's, Flo-Pro Muffler w/Stainless Steel Tip, Dome Light/Map Light Mod, Mobil 1 Synthetic Motor Oil, LED Cupholder Mod, Grillcraft with TOYOTA emblem, Vision 375 Warrior Wheels, Extra Bed D Ring Mod, TRD Skidplate, Bilstein 5100's on all four corners, Front 5100's set at zero with Eibach springs, Toytec 1.5" rear TSB add-a-leaf springs, Toytec swaybar relocate kit, Katzkin Leather Seating, Front Window Tint
    I did mine about 3 months ago and I am quite happy with the result. Mine were that ugly light gray color and they just didn't look right on the truck. I took them off the truck, removed the end caps and sanded them down to bare metal. I used painters tape to mask off the step pads. The Rustoleum coats well, but the spray nozzles tend to clog up very quickly. I don't have any chips yet, but I don't go off road much and I still have my mud flaps on.
    Also, what little spots that might get missed with the spray can be touched up with one of those cheap, disposable foam brushes from Home Depot. I just sprayed some of the Rustoleum on a piece of cardboard and dabbed the foam brush in it and then touched up what was missed.
  13. Nov 17, 2010 at 1:06 PM
    joe812
    Joe
    NJ
    Thanks. This is the kind of info I was looking for!
  14. Nov 17, 2010 at 1:47 PM
    Mark C.
    Mark
    Connecticut
    2010 MGM SR5 4WD AC
    Perhaps some clearcoat might help to protect the paint?
