Rustproof or not??
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Zeus661, Nov 7, 2019.
  1. Nov 20, 2019 at 10:03 AM
    #181
    tacoma16
    tacoma16 Well-Known Member
    Peter
    Ontario
    Double cab SR5 4x4
    I am using a cheap gun (from princess auto which is the Cnd harbour freight)that can be attatched to my compressor.
    over60, Big tall dave and GQ7227 like this.
  2. Nov 20, 2019 at 10:10 AM
    #182
    GQ7227
    GQ7227 mw survivor
    J A Y
    i have a question that is puzzling me, maybe somebody knows?
    in the past 25 years has the special 'secret formula' Toyota frame paint & coating ever changed or is it still of the same composition?
    in simple terms, is the frame paint & coating they used on my truck in 1997 the same quality as they put on the new Tacomas now
  3. Nov 20, 2019 at 10:37 AM
    #183
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    Short answer is it is either the coating or frame. However, this does happen to other brands of vehicles, but the manufacture doesn't warranty it like toyota.
    GQ7227[QUOTED] and Boghog1 like this.
  4. Nov 20, 2019 at 10:37 AM
    #184
    uptaco
    uptaco Well-Known Member
    Adam
    Pittsburgh, Pennsylvania
    '19 Cavalry Blue OR 6A DCLB
    I suspect that coating formulas and frame metal compositions fluctuate over the years like most things on a vehicle... if the paints have gotten better on the panels in the last 25 years then surely the frame coatings have changed too. That said, factory frame coating will only get you so far once a rock chips it or a spot weld starts to rust. Once that happens, without a corrosion inhibitor coating like Fluid Film, etc etc then its all down to the metal composition of the frame itself... which at least in the 2nd gens was not up to par. I think I have seen some people with 2016 and 2017 3rd gens have even gotten letters from toyota about frame rust issues and extended service coverage for them...
    GQ7227[QUOTED] likes this.
  5. Nov 20, 2019 at 10:52 AM
    #185
    Big tall dave
    Big tall dave Well-Known Member
    Elora, Ontario, Canada
    2018 Tacoma TRD OR DCLB
    Krown is great for inside frame/body cavities and it creeps like crazy but I find it tends to wash off easily in the winters even without going through car washes or power washing it directly....
    IMO, FF is a shit-job to apply but sticks to undercarriages a lot better than Krown and creeps just as much. Worth the money and time once per year....
  6. Nov 20, 2019 at 10:55 AM
    #186
    Kenstogie
    Kenstogie Well-Known Member
    Ken
    19 SR 2.7 4x4
    . I am guessing that my little pancake compressor would not do the trick or maybe it would?
    GQ7227 likes this.
  7. Nov 20, 2019 at 10:57 AM
    #187
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    my compressor is only good for 4-5CFM. The gun works at 50-70psi off the top of my head. Yours would be running/pushing it a lot. Mine was working hard but it sprayed fluid film in the cold for me...
    GQ7227 and Big tall dave like this.
  8. Nov 20, 2019 at 10:58 AM
    #188
    uptaco
    Adam
    The fluid film website recommends 1500 to 3500 PSI with a sprayer that is for paints and such. I don't know much about compressors and such but they called it airless sprayer or something like that. When in doubt, read the manufacturer recommendations.
  9. Nov 20, 2019 at 11:01 AM
    #189
    uptaco
    Adam
    Per the FF site https://www.fluid-film.com/frequently-asked-questions/
    "The most efficient way to apply FLUID FILM in its bulk form is with the use of standard airless paint spraying equipment. Airless paint sprayers operate under high pressure, usually between 1500 – 3500 PSI, which atomize paint into tiny droplets, propelling them towards the desired equipment. We recommend a minimum of around 2000 PSI. Applied at a film thickness of 3 – 4 mil, this will cover approximately 250 sq. ft. per gallon. We also recommend a spray tip of between 515 -517 for best atomization."
  10. Nov 20, 2019 at 11:04 AM
    #190
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    meh, I did it last year with the aerosol cans and it seems the same as with my compressor. Airless sprayers are more for industrial applications but yes that would be the best method, or some kind of screw/rotary compressor that can pump out the CFM's. Mine was slow, but it worked.
  11. Nov 20, 2019 at 11:06 AM
    #191
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    This is why I have this statement Just Rustproof it yearly! in my Signature! :thumbsup:
    SR-71A and tacoma16 like this.
  12. Nov 20, 2019 at 11:11 AM
    #192
    GQ7227
    GQ7227 mw survivor
    J A Y
    wow 3500 psi sounds professional grade and quite dangerous!
    probably rip the skin right off your body with that pressure
  13. Nov 20, 2019 at 11:20 AM
    #193
    uptaco
    Adam
    It's certainly powerful. I had a summer job power washing once and they gave me a 5000psi power washer. It was a beast.
  14. Nov 20, 2019 at 11:50 AM
    #194
    monkeyface
    monkeyface Douchebag, or just douche if we're friends
    Colorado
    '90,'97,'12,'05 Tundra 4.7,'07 T4R 4.7,'08 T4R 4.7
    I like Eastwood for permanent rust prevention as opposed to annual re-coats.
    FRE1809[QUOTED] and GQ7227 like this.
  15. Nov 20, 2019 at 3:33 PM
    #195
    Kenstogie
    Ken
    19 SR 2.7 4x4
    Wow that is some high pressure....I think spray cans it is.... thanks for all the replies though. :thumbsup:
  16. Nov 20, 2019 at 5:59 PM
    #196
    Tacowin1013
    Tacowin1013 Well-Known Member
    2017 OR DCSB 6MT MGM
    I just got under today since it was pretty warm and gave the undercoating a nice coat. Took about 3 cans to finish the job. Noticed a couple of spots starting to rust small maybe 2 to 4 mm in size behind the front tires my guess is its from rock chips hitting the frame and rusting... I didn't have time to file it down and repaint with rustoleum so that'll be a job for me in the spring
    GQ7227 and Junkhead like this.
  17. Nov 21, 2019 at 4:43 AM
    #197
    Kenstogie
    Ken
    19 SR 2.7 4x4
    Three cans is what I have coming.... nice. Sorry about the rust but it sounds very manageable.
  18. Nov 21, 2019 at 4:48 AM
    #198
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    I may be wrong, but I don't believe there is a permanent rust prevention solution out there that matches getting it done annually. Especially where salt is used.
    GQ7227, tacoma16, Boghog1 and 3 others like this.
  19. Nov 21, 2019 at 6:50 AM
    #199
    Tacowin1013
    Ahhh part of the fun living in the Midwest Salt belt territory. Better to catch it early. I firmly believe half the maintenance of FF annually is noticing rust spots like this and treating it early. Those who don't treat never crawl under to look at 90% of their frame to notice anything
    Boghog1 and GQ7227 like this.
  20. Nov 21, 2019 at 9:55 AM
    #200
    brosenz
    brosenz Well-Known Member
    How do you apply the coat under the car? Just spray it all over? Can it be applied to areas with paint? Is it safe in the wheels area with you have the breaks/disks/drums and all the connecting suspension parts? How long does it takes to dry? Thank you
    GQ7227 likes this.
