Rustproof or not??
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Zeus661, Nov 7, 2019.
  1. Nov 25, 2019 at 7:22 PM
    #221
    uptaco
    uptaco Well-Known Member
    Adam
    Pittsburgh, Pennsylvania
    '19 Cavalry Blue OR 6A DCLB
    I really don't intend this to sound mean. Really I don't. Did you read most of this thread? It's been discussed. The reason undercoat got a bad rap is zeibart tried spraying bed liner as an undercoat and what happened is that the stresses on the frame caused small voids to form behind the bed liner on the frame and then rust ran rampant. Everything looked great but behind the coating it was a rusted mess. I cannot stress enough how risky it is to spray something like linex as an undercoat.
  2. Nov 25, 2019 at 8:02 PM
    #222
    Grossomotto
    Grossomotto Complete 3rd Member
    39.9526° N, 75.1652° W
    2017 4WDV6LB6MT
    I’m not a fan of Linex for anything, not even bed liner.
    Boghog1 likes this.
  3. Nov 26, 2019 at 4:36 PM
    #223
    lojack
    lojack Well-Known Member
    Ahren
    South Shore, Wi
    19 DCSB OR CB
    I bought a gallon of FF and after (hopefully) thoroughly washing my truck and letting it dry in the garage for a couple days, I started spraying the frame and undercarriage. Using a long hose on the gun, it's kind of like reverse liposuction! I've been at it for a couple hours, and I think I'm maybe half done, and I'm sure there are lots of places that I'll miss. I've used half the gallon at least, so I'll probably go until I run out.
    My old SR5 had the toyota stuff done, and with regular washing, it stayed relatively rust free in the ten years I owned it. Hopefully this, and the toyota rust proofing, I should have a decent head start. I'm hoping to have this truck for a while.
  4. Dec 1, 2019 at 8:04 PM
    #224
    Markcal
    Markcal Well-Known Member
    How long do you keep your trucks is the real question?
    GQ7227 and Big tall dave like this.
  5. Dec 1, 2019 at 9:40 PM
    #225
    Stocklocker
    Stocklocker Well-Known Member
    17TRDORDCSBAT
    Can you name a single manufacturer that offers a factory option even approaching this concept of a bed-linered frame? You cannot even order the exact list of presently available features you desire from Toyota, unless they happen to form part of a bundled trim. This would be a first in the automotive industry if offered.
  6. Dec 2, 2019 at 3:57 PM
    #226
    monkeyface
    monkeyface Douchebag, or just douche if we're friends
    Colorado
    '90,'97,'12,'05 Tundra 4.7,'07 T4R 4.7,'08 T4R 4.7
    VW does (or did do) an undercoat at the factory. The latest model VW I have is a 2003 Eurovan and it's rubber undercoated frame, then painted over at the factory. Works pretty good.
    Stocklocker[QUOTED] likes this.
  7. Dec 2, 2019 at 4:27 PM
    #227
    Stocklocker
    17TRDORDCSBAT
    For sure there is rubber type coating, but not something like rhino-liner or LineX
  8. Dec 2, 2019 at 4:56 PM
    #228
    TRDProOne
    TRDProOne Well-Known Member
    CA
    2019 TRD Pro in Super White
    2004 Mini Coopers had the same type of coating on the entire underside. It worked extremely well in preventing corrosion.
  9. Dec 2, 2019 at 5:16 PM
    #229
    Stocklocker
    17TRDORDCSBAT
    That was the glue holding them together (BMW product)
    Silentshredr likes this.
  10. Dec 7, 2019 at 8:25 PM
    #230
    GQ7227
    GQ7227 mw survivor
    J A Y
    i did test the FF through the undercarriage power wash on my naked frame on the passenger side 6 or 7 times in October
    it did not really seem to stick well and is mostly gone other than maybe a very light film with hints of flash rust from checking it today
    perhaps if the paint is of good solid quality it could work?
    i mean, you don't rustproof body panels annually do you until the paint chips or something like that
  11. Dec 7, 2019 at 10:46 PM
    #231
    Stocklocker
    17TRDORDCSBAT
    I just wish Toyota used whatever Ford uses. The Ford coating isn’t flawless, but it’s 3X better than whatever Toyota is doing.
  12. Dec 7, 2019 at 10:48 PM
    #232
    Stocklocker
    17TRDORDCSBAT
  13. Dec 8, 2019 at 1:24 AM
    #233
    Big tall dave
    Big tall dave Well-Known Member
    Elora, Ontario, Canada
    2018 Tacoma TRD OR DCLB
    Ya, I would never expect Krown, RustCheck or Fluid Film to be there after power washing. What i’m saying is that FF sticks a whole lot better than the others. Without power washing directly, FF will still be there in the spring, where as the other two will have washed off just from the snow/water/slush....My experience anyway....
  14. Dec 8, 2019 at 1:27 AM
    #234
    Tacoma1818
    Tacoma1818 Well-Known Member
    Where in northern Ohio you at?
  15. Dec 8, 2019 at 1:31 AM
    #235
    Tacoma1818
    Can confirm that my fluid filmed Tacoma frame still had a lot of FF on it this year when my undercoater sprayed woolwax on.
  16. Dec 8, 2019 at 4:20 AM
    #236
    Timetraveler66
    Timetraveler66 Well-Known Member
    I purchased my truck brand new. Took delivery in Dec just before first snow and salt. I was able to get under and unload 8 cans of FF using the 360 hose I was also able to get inside the boxed areas and inside rockers, doors, tailgate etc. We had a wet salty winter. I only wash my vehicles in the winter when the forecast calls for 50 deg or more. Then as soon as spring hits and I know the salt is off the roads for good I douche the snot out of my vehicles. Power wash under and over, buff, polish, seal, etc. I can say that anytime I sprayed the frame the water just sheeted off all the way into spring. Even after heavy power wash in spring there was a thin layer of FF still there. Then this year I purchased the pro kit with all wands and emptied a gallon of WoolWax under and in. We will see how it compares next spring.
    GQ7227, boynoyce and Big tall dave like this.
  17. Dec 8, 2019 at 5:38 AM
    #237
    GQ7227
    GQ7227 mw survivor
    J A Y
    woolwax would be next on my list of trial and error product testing, but again I have never heard of it before TW came along.
    what does it look like?
    i should test the FF with the 100psi air blaster, see what happens, if it stays put and creeps around, or just blows off everywhere
  18. Dec 8, 2019 at 9:41 AM
    #238
    Northern Taco
    Northern Taco Well-Known Member
    2022 Tacoma trd off road premium 2023 tundra trd off road
    Anything that stays put usually means it dries out and long term it isn't as good as something like ff or rust check etc
    Big tall dave and boynoyce like this.
  19. Dec 8, 2019 at 7:56 PM
    #239
    Vo0Do0
    Vo0Do0 Well-Known Member
    2020 VooDoo Blue Tacoma TRD Off-Road
    I knew it had to be something different.. never had an issue with any of my Ford F150's rusting.
  20. Dec 8, 2019 at 8:00 PM
    #240
    Stocklocker
    17TRDORDCSBAT
    The Ford coating holds up really well. It’s a robust product even on gravel roads.
    shakerhood likes this.
