Rusty Bed
Discussion in '1st Gen. Tacomas (1995-2004)' started by oliverlove, Sep 15, 2010.
  1. Sep 15, 2010 at 7:24 AM
    oliverlove
    oliverlove [OP] Well-Known Member
    Oliver
    Laguna Vista, TX
    01 SR5 Ext Cab
    Let me explain the situation.
    A rust spot showed up recently in the bed of my truck near the right wheel well, right on the seam where the caulk is. I let it got for a few weeks and just today decided enough was enough. Upon closer inspection I have a few spots that need repair along the caulk line in the bed. Most of the rust appears to be coming through from the bottom!! :mad:
    So, how difficult is it to remove the bed? I was thinking I could remove the bed and address the rust at the source!
    Anyone in South Texas(Near SPI) that wants to help???:D
    Pictures to follow!
  2. Sep 15, 2010 at 7:42 AM
    Timicha
    Timicha Timicha
    TIM
    Tillamook / Portland , Oregon
    04 White Tacoma
    Fabtech 4 inch lift, tinted windows, diff drop, 33 inch MTZ tires on Raceline Raptor wheels, ELITE OFF-ROAD bumpers and sliders
    its very easy to remove the bed, just make sure you have enough people to safely carry it off
  3. Sep 15, 2010 at 8:05 AM
    vantaco
    vantaco Well-Known Member
    02 Taco Xtracab TRD Step Side
    i was going to ask the same question of removing the bed
    i'm looking at a tacoma that has a step side and eventually i'd swap it for a regular size bed, just wanted to know the work involved etc
  4. Sep 15, 2010 at 8:24 AM
    Timicha
    Timicha Timicha
    TIM
    04 White Tacoma
    all there is are i think 4 or 6 bolts holding it to the frame and then remove your gas fill neck from your bed side and just pick up the bed with a few guys and its off.
  5. Sep 15, 2010 at 8:27 AM
    vantaco
    beauty, i also assume you have to remove the wiring from the tail lights lol
  6. Sep 15, 2010 at 8:28 AM
    JLee
    JLee The Man! Vendor
    Jerry
    Benicia, CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    You beat me to it I'm pretty sure that's all you have to do I plan on doing it before this winter to do an under coating.
    Yeah there is the wires as well for the lights
  7. Sep 15, 2010 at 8:58 AM
    ywen
    ywen Well-Known Member
    I have the same type of rust on the right side caulk line as well. I took care of it from the top but rust worked its way thru. I'm assuming it's coming from the bottom. Can we get to it without removing the bed?
  8. Sep 15, 2010 at 11:34 AM
    Timicha
    Timicha Timicha
    TIM
    04 White Tacoma
    depending how bad it is i'm sure you could. there is a lot of room under our beds and not many things blocking it so unless its above your gas tank i would assume you could get to it
  9. Sep 15, 2010 at 11:47 AM
    ywen
    What's the best way of taking care of the rust from below? I'm thinking sanding the rust off, spray on naval jelly and then spray on rubber undercoating? Would this be effective if I just spot apply it where ever rust exist or do I really need to spray the whole area?
  10. Sep 15, 2010 at 11:50 AM
    Timicha
    Timicha Timicha
    TIM
    04 White Tacoma
    as long as you remove all the rust from the area you should be fine
  11. Sep 15, 2010 at 2:23 PM
    oliverlove
    Oliver
    Laguna Vista, TX
    01 SR5 Ext Cab
    I went all out and have a 5 step process that I am going to use. They are all Eastwood products.
    1. Prep Spray - cleans the area.
    2. Rust Converter - "transforms rust into a paintable surface"
    3. Rust Encapsulator - seals and stops the rust
    4. Chasse Black - Top coat to protect the Encapsulator
    5. Heavy Duty Anti Rust - "Wax Film"
    Thats my plan after I attack the rust with a wire brush and grinder to try and remove as much as I can.
  12. Sep 15, 2010 at 4:46 PM
    Timicha
    Timicha Timicha
    TIM
    04 White Tacoma
    nice, if you have a grinder you can get a wire wheel and that would tear that rust right out of there.
