Rusty Bolts
Discussion in '2nd Gen. Tacomas (2005-2015)' started by This_taco_obsession, Apr 23, 2020.
  1. Apr 24, 2020 at 7:24 AM
    dk_crew
    dk_crew Well-Known Member
    Dave
    Austin, TX
    2005 Tacoma 4x4
    I had a similar problem on my 05. Plenty of PB and cleaning, and after the initial failed attempts, I got a 6 point socket. I don't know the terminology here, but I used a grinder to flatten the bezel on the socket to get more surface area on the nut. Once I had that they gripped and came right out.
  2. Apr 24, 2020 at 8:17 AM
    Goosie0080
    Goosie0080 Well-Known Member
    North East
    07 Tacoma Access Cab 4x4 base
    The cool little tid bits you find here on Tacomaworld... I live in the rust belt and found penetrating oil ain't shit.... Just get the torch.... And a 6 point socket..
    dk_crew likes this.
  3. Apr 24, 2020 at 11:58 AM
    hemitruk
    hemitruk Old man , young boi truk
    Kurt
    Hawaii
    2010 Dbl Cab Sport,
    A few
  4. Apr 24, 2020 at 1:32 PM
    Crow Horse
    Crow Horse Well-Known Member
    Central NY
    2012 DCSB TRDOR
    Similar to heating and having wax wick into the threads, I've had some success with using anti-seize compound just like the wax.
    When you have removed the bolt or nut in question, it's best to use a new replacement if possible. If not, chase the threads and use anti-seize compound to install. A tap or die will work in a pinch but it's best to use a thread chaser to clean up the threads......
  5. Apr 24, 2020 at 4:53 PM
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    I too don't have much faith in the penetrating oil soaking into the threads, but I do use it to soften the crap in the exposed threads. Then you can continue to brush that crud out with a small wire brush.
    Where I think the penetrating fluid really helps, is once you get the nut to move just a little, you can work it back and forth and the oil will keep the nut and stud from galling on each other as much. I've had nuts like this come loose, only to be a bitch the entire length of the stud. If you get the threads a little cleaned up before hand and keep them soaked while removing, it will make your life easier.
  6. Apr 24, 2020 at 5:35 PM
    This_taco_obsession
    This_taco_obsession [OP] Well-Known Member
    Dan
    Virginia Beach
    HS coils w/5100’s, MD Dakar’s w/B110’s
    I’ve been soaking, and spraying, and brushing since 0600 this morning. All 3 on the drivers side strut assembly broke loose. On the passenger side, the one closest to the wheel well still doesn’t want to move, so I’m not quite sure what I’m going to do about that yet. The left rear shock broke loose. The right side however, the little nubbie on top you’re supposed to hold and loosen while loosening the nut sheered right off, so I think I’ll be cutting that shock out :sawzall:.....I’ve been wanting a new sawzall anyway. I’m only doing all of this now so in a couple weeks, come install day, I’ll have (most) of the swearing out of the way. I still have the UCA bolts though, so.....
    EatSleepTacos likes this.
  7. Apr 24, 2020 at 6:03 PM
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    X2 on the rear.
  8. Apr 24, 2020 at 6:06 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Might I recommend a corded Milwaukee. I have it and it’s a beast of a sawzall.
    dk_crew likes this.
  9. Apr 24, 2020 at 6:09 PM
    This_taco_obsession
    Dan
    Virginia Beach
    I was just comparing the Milwaukee to the DeWalt. I’m thinking Milwaukee if for no other reason than it comes with a case.
    EatSleepTacos[QUOTED] likes this.
  10. Apr 24, 2020 at 6:09 PM
    george3
    New Jersey
    I've heated til red hot and sprayed with water - that has worked many times but I'd love to try your method - first I've heard of it thanks.
  11. Apr 24, 2020 at 6:14 PM
    This_taco_obsession
    Dan
    Virginia Beach
    If I can’t get it broke loose by install day, I may try something like that. It’s in a REALLY shitty location.
  12. Apr 24, 2020 at 6:18 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    If you’re still planning on coming over, I was thinking I’d just use the oxy torch to literally turn the stud/nut into a puddle of molten metal and blast it away. Just turn it into nothing. Not sure if you were trying to save these coilovers but they’ll come off one way or another.
  13. Apr 24, 2020 at 6:25 PM
    Wsidr1
    Wsidr1 Well-Known Member
    Indiana
    2 x 95.5 Ext 2.7L & 3.4L A/T 4x4
    Fellow rust belter here:
    I use the 50-50 acetone and ATF when I see a big challenge coming. Just don't mix up much at once. The acetone evaporates. Kroil seems to be pretty decent. Worth the money...? Looks a lot like thinned ATF.
    Like has been said, things like PB really help make removal, once loosened, much easier/faster, but marginal as far as being "why it broke loose".
    I've used the wax trick on brake bleeder screws with some success. Not always, but often enough to keep trying it.
    Heat of course is always good when it can be used without danger or damaging other parts.
    Vibration in the form of hitting/tapping while applying torque, or using an air or electric impact when you have the space to work. I have a 3/4 drive air impact from Rural King that has saved me many times. 3 forward/reverse settings and of course you can dial the air up/down to get safe torque levels.
  14. Apr 24, 2020 at 6:29 PM
    This_taco_obsession
    Dan
    Virginia Beach
    What kind of beer do you prefer? I’m not saving anything. I’ve got all new stuff. HS 2” coils, 5100’s and freedom Offroad UCA’s up front. MD Dakars, and B110’s, per your advice in the back. Bump stops and a flip kit as soon as I can.
  15. Apr 24, 2020 at 6:30 PM
    #35
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Dragons milk, total wine carries it. If you bring a 4 pack of that over I’ll cut off anything you need.
  16. Apr 24, 2020 at 6:34 PM
    #36
    This_taco_obsession
    Dan
    Virginia Beach
    Deal.
  17. Apr 25, 2020 at 4:31 AM
    #37
    Too Stroked
    Too Stroked Well-Known Member
    Tom
    South shore of Lake Ontario
    2021 4Runner SR5 Premium
    Since we're sharing helpful hints on how to remove stubborn / rusted fasteners, here's one that's served me well over the years. After you've gotten the corroded fastener to break free and it starts to move, be careful. Many times it will move a little bit, then bind up. This is the corrosion breaking off and binding up the threads. When this happens, re-tighten the fastener just a bit to clear the threads. You may find that you have to loosen, tighten, loosen, repeat a number of times. If you don't stop and reverse direction, many times you will break the fastener free, only to break it off a moment later.
  18. Apr 25, 2020 at 7:49 AM
    #38
    george3
    New Jersey
    X2 - I've done this on fasteners that aren't rusted or corroded much at all when they don't turn CCW I'll try turning them CW a little then CCW and back'n forth - sometimes it works.
  19. Apr 29, 2020 at 1:12 PM
    #39
    Jllahman
    Jllahman Well-Known Member
    Jordan
    Northern Kentucky
    2008 Rugged Trail
    Make sure to use a 6 point socket and not one of the 12 points. The tool set I have has the 6 point only in the deep sockets. Less chancing of rounding off.
