Rusty Timing Chain Cover Plate
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jliberatore92, Jun 25, 2014.
  1. Jun 25, 2014 at 7:10 AM
    jliberatore92
    jliberatore92 [OP] Well-Known Member
    Troy, MI
    06 Tacoma TRD Off-road
    5100s with OME 885 coils. OME Dakar leaf and OME nitrocharger sport shocks., 265/75/R16 Duratracs
    I had trouble finding any answers on this, so I figured I would make a thread so someone else could find some answers.
    This was done on an 06 TRD Off Road V6 AC W/ tow package(I believe the fan will look different). 136,000 miles. In the North East.
    So here it goes.
    Here is the problem:
    A very rusty timing chain cover plate. This plate lets you access the timing chain tensioner. If it rusts enough, oil will leak from it.
    It is located here:
    Tools needed:
    10mm socket
    12mm wrench
    14mm socket
    flathead
    impact driver would help
    torque wrench
    wire brush
    PB Blaster or product of the like
    Parts needed:
    I ordered from villagetoyota.com
    4 BOLTS (FOR FRONT DIFFERENTIAL BREATHER PLUG OIL DEFLECTOR)
    P/N 9155180612 $ 0.59 ea.
    1 GASKET, TIMING GEAR OR CHAIN COVER . (L)
    P/N 113280P010 $8.40
    1 PLATE, TIMING CHAIN COVER . (L)
    P/N 113240P010 $7.01
    Shipping was like $12 but it was worth it for me to not have to drive to the dealer.
    Make sure to spray PB Blaster on the bolts ahead of time so it can soak in. I made sure to cover the belts below the bolts so they didn't get covered in PB Blaster.
    First remove the 2 10mm bolts on the engine cover(circled in red) and the plastic clips with your flathead (circled in blue). Also disconnect the hose on the radiator overflow (circled in green). Remove the engine cover and the radiator cover.
    Then remove the 2 10mm bolts on the radiator shroud( circled in yellow):
    (Photo credit to BlazeAce)
    Then remove the 4 12mm bolts holding the fan on. This was a pain but it can be done using a wrench:
    Then remove the radiator shroud and fan at the same time. It will take some maneuvering but they will come out.
    Now prep the bolts. Mine were rusty so I had to wire brush the rust off so the socket would fit over the heads well.
    At this point, I drained my oil. I had to do an oil change anyway and I didn't want to find out if any oil would spill out from behind the plate.
    Then use your socket or impact to remove the old 10mm bolts.
    Old and the new:
    Try to clean the area where the gasket will seat:
    Install the new gasket and plate. Torque the bolts ~7 ft lb.
    Re-install all the parts you took off in the prior steps.
    torque specs: fan nuts: 18 ft lb, fan shroud bolts: ~4 ft lb.
    The rest I just snugged to what I felt was sufficient.
    All Done:
    Now just finish your oil change.
    Overall this was a relatively cheap and effective repair. Hopefully this thread will be helpful to someone.
    lo2hi and CanadianTRDOffRd like this.
  2. Jun 25, 2014 at 7:11 AM
    LEX
    LEX --- --- --- - ----
    Houston, Texas
    100 Series LC
  3. Jun 25, 2014 at 7:54 AM
    RearViewMirror
    RearViewMirror Saw things so much clearer once you... were in my
    Craig Christ
    State of Love and Trust
    2023 Subaru WRX GT Manual
    Nice write up and holy shit that was rusted :eek:
  4. Jun 25, 2014 at 8:01 AM
    tomwil
    tomwil Well-Known Member
    East Coast USA
    2014 Reg Cab 4x4
    Great writeup!
    What's to prevent the new cover from rusting again? Would painting or some other application help that?
  5. Jun 25, 2014 at 9:11 AM
    jliberatore92
    Troy, MI
    I thought about that. I am going to wait and see if it starts to rust. I'm not sure if this metal is different than what they used back then.
  6. Jun 25, 2014 at 10:10 AM
    OffsetPlayer2
    OffsetPlayer2 Cornbread fed
    In the woods and fields, NC
    17 DCSB Off Road 4wd
    Weather Tech floor mats
    I remember seeing the first thread you started about this. Glad to see you figured out what part you needed and nice writeup :cheers:. Thanks for the pics with it.
  7. Jun 25, 2014 at 10:18 AM
    ranger098
    ranger098 Well-Known Member
    Brian
    Minnesota
    Is your water pump leaking? A constant spray of coolant may cause this... It also looked like your coolant level may be low too... Just something to consider
  8. Jun 25, 2014 at 10:47 AM
    jliberatore92
    Troy, MI
    I don't believe that the coolant is leaking onto the plate.
    I did not drain the coolant overflow tank. It may be slightly low but I don't see that as a problem. I will probably change the coolant soon anyway.
  9. Jun 25, 2014 at 11:33 AM
    jliberatore92
    Troy, MI
    The picture that shows the low coolant level is not my picture. Mine is at a healthy level.
  10. Jun 25, 2014 at 11:52 AM
    ranger098
    Brian
    Minnesota
    oooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooohhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhh:burnrubber::burnrubber::burnrubber:
