RV Towing
Discussion in 'Towing' started by cjman, Sep 5, 2010.
  1. Sep 5, 2010 at 8:06 PM
    cjman
    cjman [OP] New Member
    10 TRD Off Road PreRunner
    Has anyone used a drive shaft disconnect to allow 2010 TRD PreRunner to be towed behind a motor home on 4 wheels? It is not a 4WD, but does have the electronic differential lock.
  2. Sep 5, 2010 at 8:09 PM
    Black Taco
    Black Taco Well-Known Member
    Rob
    WPB, FL
    TOYOTA
    No mods whatsoever!
    Search the towing section if you haven't already. I recall seeing something about that a while back. Don't remember the outcome.
  3. Jan 14, 2011 at 5:10 PM
    senna
    senna Well-Known Member
    San Jose CA.
    09 DBL CAB TRD-OR OME shocks 885 and AAL
    I'm not only interested in the drive shaft disconnect, I want to know about towing a 4wd with all 4 wheels rolling :confused:, how disconnected are the front wheels when in 2wd ?
  4. Jan 14, 2011 at 5:24 PM
    senna
    San Jose CA.
    This is for my brother who is considering a Tacoma, but wants to be able to tow it behind his rv. When he told me this, we both said, the transfer case has no neutral :confused:. Today he called and said he found some info on the drive shaft disconnect for the rear, so he wanted to know how the front disconnected.
    So, for the front, driving or being towed are essentially the same thing. When in 2wd.
  5. Jan 14, 2011 at 5:26 PM
    senna
    San Jose CA.
    OK, disregard my comment about towing and driving being the same thing :eek:
  6. Jan 14, 2011 at 5:39 PM
    senna
    San Jose CA.
    I wonder, if by saying not to tow the tacoma, it is mainly because of the rear drive shaft. Once you go to the rear disconnect, might actually be ok.
  7. Jan 20, 2011 at 9:38 AM
    cc350
    cc350 Retired Member
    Best bet for towing a 4wd Tacoma would be to load it on a car hauler trailer.
  8. Jan 31, 2011 at 3:34 PM
    trd2001
    trd2001 Well-Known Member
    Simi Valley
    08 Double Cab Long Bed 4x4 Sport
    OME 884 TSB Springs Firestone Airbags
    I did some research for this for my Dad who was looking for a Tacoma to tow behind his RV. On a Tacoma, when its in 2wd, the front drive shaft is disconnected. This is how my 08 Tacoma was before I sold it. You have to buy the drive shaft disconnect for the rear, which for the Remco one is 900.00 plus. They disconnect the rear shaft at the axle housing. He was a bit weary, so he ended up finding a Jeep Cherokee 4x4 to tow behind the RV. He is still looking at a Tacoma, since the Jeep is not practical as an everyday vehicle.
