RVM's Superwhite DCSB 4X4 OR Build (Updated)
Discussion in '2nd Gen. Builds (2005-2015)' started by RearViewMirror, Feb 5, 2014.
  1. Mar 1, 2015 at 2:58 PM
    #181
    Sacrifice
    Sacrifice Motorcycle Goon
    KS
    DCSB OR 4X4 LT
    Pelfreybilt Front Bumper,BAMF sliders, Airflow Snorkel,Mini D2S Retrofits, ADS Rear Shocks, Deaver U402 Leafsprings, 35s, AllPro +2LT
    :thumbsup: gonna look good
  2. Mar 1, 2015 at 4:12 PM
    #182
    ThomasMore66
    Dallas/Fort Worth & Durango
    TRD Supercharger, TRD exhaust, Leather seats, running boards removed (why it came with them I cannot imagine), Salex organizers, BAMF behind-the-grill light bar, Rigid SR-20 and SR-Q - Spots mounted behind stock grill, color-matched grill, WeatherTech FloorLiner DigitalFit floor mats, Tech Deck, Avid bolt-on slider/step converted to weld on by TW member Achirdo, Diaz Fabrication Model T, Icon Stage 4 with OME Dakar rear leaf springs, OME Driveshaft spacer, Toytec 1" Front Diff Drop, FN BFD 18"x9" GMG Wheels, BFG KO2 285-65-18 tires, Ultragauge mounted above mirror, Tuffy Box lockable storage, MattGecko rear window security bar, Relentless Fab tailgate protector, CSJumper 700 lumen flood pattern back-up LED's, modified BeeRadd under-hood lighting with two KC Cyclones; KB Voodoo cargo management system and standard rails, AllPro hi-lift jack mount, 48" hi-lift, RCI Metalworks aluminum front skid, Flyzeye 3VP-RS in glovebox and console, AFE CAI, Coupe fuse box cover, battery hold-down bracket and CAI air-box cover, Wurton pod led's installed as bed lights on Lowbrow Customs motorcycle fork brake line aluminum brackets, Pop-n-Lock PL5400, Extang Solidfold 2.0, Rechelon Retro's, Moromoto LED fogs, URD Y-pipe, Walbro 255lph fuel pump, Speedhut AFR and Boost gauges, Cravenspeed gauge holder, CMC by Tandem Automotive, 70mm throttle body, CSF radiator, Doug Thorley shorties, Vibrant 7101 cats, SOS Offroad front and rear bumpers, Smoothflow 2.5” SC pulley, Steeda SC belt tensioner, roostfactor belt wrap kit, switch Pro 9100 in custom Tandem Automotive holder, WAT trans valvebody, FIC 650cc injectors, HP Tuner.
    Wind noise report on the rack?
  3. Mar 1, 2015 at 6:04 PM
    #183
    RearViewMirror
    RearViewMirror [OP] Saw things so much clearer once you... were in my
    Craig Christ
    State of Love and Trust
    2023 Subaru WRX GT Manual
    Haven't taken out of the garage other than to take the pictures. Fighting a cold and it was 37 degrees today so it wasn't the smartest thing for me to do but fuckit... It's been sitting in my living room floor for two days and I couldn't wait any longer. I imagine it will be noisy but my mud tires are loud also. If I wanted a quite vehicle I'd bought a Lexus. I wanted a vehicle that will take me everywhere I want to go and with as many aftermarket options we have for our trucks this was the perfect vehicle.
    The rack is amazing though and if you are looking for a rack with unlimited options this is the one.
  4. Mar 1, 2015 at 7:19 PM
    #184
    RearViewMirror
    Craig Christ
    I agree. That one is a very nice rack. I seriously gave it some consideration but I wanted a low profile rack with many options.
  5. Mar 3, 2015 at 7:50 AM
    #185
    squint0241
    squint0241 OVRLND
    Rick
    Tropics
    '14 DCSB/Off-Road 4X4
    Bone Stock
    Chris...some of my buds just installed the Prinsu rack w/the fairing and they are complaining about wind howling at freeway speeds. I get none of that with my Front Runner.
  6. Mar 3, 2015 at 7:54 AM
    #186
    RearViewMirror
    Craig Christ
    I was surprised that there isn't ANY wind noise with this rack. I drove down the freeway this morning coming to work and it is quiet with the exception of my tires.
  7. Mar 3, 2015 at 9:24 AM
    #187
    Sacrifice
    KS
    DCSB OR 4X4 LT
    Interesting. I still like the look :cool: ha
    I may get a roof rack someday if i ever decide for an rtt
  8. Mar 3, 2015 at 12:05 PM
    #188
    ThomasMore66
    Nice. I really don't need more noise that I have to mask with the stereo.
  9. Mar 3, 2015 at 2:11 PM
    #189
    squint0241
    squint0241 OVRLND
    Rick
    Tropics
    Bone Stock
    When I initially put mine on, I did so without the wind deflector. OMG...it was so loud and it actually reverberated so bad it made the cab shake and the rear view mirror was useless. I then put on the wind deflector and BAM...it was like it wasn't even there. I didn't even use the rubber adhesive tabs in the kit either. I was corresponding with Front Runner at the time and they mentioned that the rubber tabs aren't really needed. I'm sure Front Runner did some kind of wind tunnel test when they developed the rack. I had the same issues with noise and vibration with my 50" light bar. I ended up putting a cover around the light and securing it with Velcro straps. No noise anymore...:D
  10. Mar 3, 2015 at 3:05 PM
    #190
    RearViewMirror
    Craig Christ
    I put the pads on just because they were there :)
    But yeah you're right. There is no noise from the rack (surprisingly)
    *EDIT* Quite honestly I was more concerned about the back of the rack blocking the XM antenna but it works just fine.
  11. Mar 4, 2015 at 1:35 AM
    #191
    96tacoforlife
    96tacoforlife Well-Known Member
    California
    18 TRD Offroad 4X4
    Gorgeous truck man. I pick my 2015 TRD sport Manuel 6speed in 3 weeks in super white.
  12. Mar 4, 2015 at 7:18 PM
    #192
    Joeyo518
    Joeyo518 Well-Known Member
    Albany NY
    14 MGM TRD DCSB OR 4x4
    Sharpe looking truck. Looks great even with stock suspension. I have a '14 OR that I might put 5100's on it.
  13. Mar 4, 2015 at 7:24 PM
    #193
    RearViewMirror
    Craig Christ
    Thank you :)
    I'll probably do the same.
  14. Mar 4, 2015 at 7:34 PM
    #194
    Joeyo518
    Albany NY
    I was thinking at setting them at the 0.85 setting as I tow a pop up trailer and don't want to be nose high.
  15. Mar 4, 2015 at 7:38 PM
    #195
    Joeyo518
    Albany NY
    Do the LED headlights you installed have high and Lo beams? I know somewhere I've read that either LED or the HID don't always have both
  16. Mar 4, 2015 at 8:27 PM
    #196
    RearViewMirror
    Craig Christ
    They did until one went out. I've since went back to 5900k Halogen. LED technology just isn't there yet for reliability. Mine lasted around 10 months.
  17. Mar 4, 2015 at 8:35 PM
    #197
    Joeyo518
    Albany NY
    Thanks for saving me the money and head ache.
    Nice sticker on your back window!
  18. Mar 4, 2015 at 8:40 PM
    #198
    RearViewMirror
    Craig Christ
    No problem. I loved them when they worked and miss them. But they just aren't reliable.
    Yup... Same sticker:) Almost 22 years on and I'll retire at 50.
  19. Mar 4, 2015 at 8:46 PM
    #199
    Joeyo518
    Albany NY
    5 years. 20 more to go. Love everyday.
  20. Mar 5, 2015 at 10:28 AM
    #200
    Jkinz11
    Jkinz11 Well-Known Member
    Sk
    13 limited DC
    Are you mounting RTT to the roof rack of bed rack? Are you upgrading bed rack?
