rx350 projector
Discussion in 'Lighting' started by Huha, Nov 17, 2019.
  1. Nov 17, 2019 at 5:58 PM
    Huha
    Huha [OP] Well-Known Member
    2017 Tacoma trd off road
    Arm rest organizer, dash cam, popnlock, anytime backup cam
    I've seen a lot of people mentioning the rx350 projector swap because they are one of the best hid projectors. My dad has an 06 rx350 and I never noticed this until night time when I drove it. On start up both projectors swivel and move into position which is pretty cool.
    Why do they do that or are they always re-aiming their selves? Will the same thing happen on a projector swap or is it unique to the 06 rx350 headlights? Just curious not planning on a swap.
  2. Nov 18, 2019 at 9:14 AM
    squarenone
    squarenone Well-Known Member
    SoCal
    2018 TRD OR 4x4 6sp-mt
    They're constantly adjusting to maintain the beam angle as you go over bumps, dips and uneven surfaces to minimize blinding other drivers and provide a consistent forward lighting area. If you watch them closely as you go over a dip or bump, you can see them adjust to maintain the same angle, pretty cool to see.
    The leveling motor is on the headlight housing itself so unless you retrofit the motor, leveling sensor and module, you will not have that function. Most, if not all Lexus models with HID headlights feature this and is not unique to the RX350, my 2001 IS300 had it but was equipped with HID reflector headlights.
    Huha[OP] likes this.
  3. Nov 18, 2019 at 10:36 AM
    18BRMTRDSportTaco
    18BRMTRDSportTaco Well-Known Member
    Sachse, Texas
    18 BRM TRDS DCSB
    TRD Pro SEMA wheels, 265/70/17 Falken Wild Peaks, OEM TRD Pro Grill, OEM Toyota Tundra LED foglights, Morimoto 5500K HID w/Hylux ballast, OEM Black Emblem Overlays.
    You are referring to AFS headlights. The projectors most use are the non-AFS versions that lack the swivel motors and are a direct swap. AFS versions can be use but require extra cutting and the AFS function is rendered useless. My Infiniti QX70S features something similar.
    Huha[QUOTED][OP] likes this.
