?'s about Tundra's
Discussion in 'Tundras' started by A.I.I.Raciing, Dec 29, 2012.
  1. Dec 29, 2012 at 12:31 PM
    A.I.I.Raciing
    A.I.I.Raciing [OP] Well-Known Member
    Orange County
    01 Ranger
    I'm thinking about picking up a Rock Warrior and I have a few questions I was hoping you guys could help me out with since I know very little about this truck.
    Can the rear end be re-geared without any issues?
    My prerunner and trailer weigh about 8K, will I have any issues towing if I put Deavers in the rear?
    I'd like to run a 37x12.50x17 tire, can this be done with a mild lift and Fiberglass front and rear?
    Is a 39" tire even possible without cutting the truck up?
    Can you run a 17" rim or the brakes to large?
    Does the RW come in 4x2?
    When I change wheels will I get an idiot light for the sensors?
    When will Toyota be doing a body change, I read 2014 but is that confirmed
    Thanks, I'm thinking about going to the stealership but I know they won't know a majority of my questions like Forum members will.
  2. Dec 30, 2012 at 6:12 AM
    chart92
    chart92 Hailstate!
    Cody
    McChord AFB, WA
    Toyota Corolla S
    My best thought on everything is that. I know for a fact that the 5.7 will tow well over 8k. Did it with my 2010. Every lift I have seen to run 37+ had to be 6" or better. And I'm not quite sure if you can run 17" rim. I would assume not cause those brakes are monsterous.
    Best of luck to you bro, hopefully some of others can help you out with your quest.
