S/C Air Fuel Ratio question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by CleanupBoss, Feb 8, 2016.
  1. Feb 8, 2016 at 3:40 PM
    CleanupBoss
    CleanupBoss [OP] Well-Known Member
    Chet
    Sparks, NV
    SR 5 with Leer shell
    S/C w/ Gibson exhaust Araid CAI, afr/boost gauges in Craven Speed mount, LED camper shell lighting kit clear bra, fogs, Leer shell w/keyless entry & Thule roof rack system Pop & Lock tailgate handle Rugged country 30" light bar for lower front bumper, Baja Designs SR2 flush mount rear bumper lights, DB Customz grill w/ 3" cube lights, Viair 2 gal tank, Viar Compressor
    Just had my air pump replaced (Long story) on my 2015 DCLB w/factory installed supercharger with 6,000 miles currently on it.
    Prior to replacing my air pump my afr gauge read 14.6 @ idle, now it reads 15.
    What concerns me is that when the s/c was engaged (prior to install of air pump) I ran rich.
    Now, when s/c is engaged, I start out running rich but then I go lean @ about 2500 rpm & 3 lbs. of boost.
    To be honest, while I can recall the motor running rich when s/c was initiated before the install of the new air pump, I do not recall it ever going lean.
    Does anyone w/a supercharger and an afr gauge have similar readings?
    I was in the dealership (that installed the supercharger) having some work performed and asked if this was normal. They tested it and said the air/fuel parameters were normal. I just didn't get that good feeling they actually tested it on the road.
  2. Feb 8, 2016 at 4:38 PM
    Redsyota
    Redsyota Well-Known Member
    Denver
    15' SPORT 6 SPEED ACLB MGM
    Some of the things...
    Mine never goes lean while in boost period. How lean are we talking?
  3. Feb 9, 2016 at 8:28 AM
    CleanupBoss
    Chet
    Sparks, NV
    Thanks for your reply.
    Lean... All the way over to 19.
    It's like when you lift to slow down to stop...complete red
  4. Feb 9, 2016 at 8:29 AM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    It should NEVER go that lean while hitting the gas.!! Mine is about 14.7-15 at idle and cruise. Then as soon as boost hits it's never above 12.5
  5. Feb 9, 2016 at 8:39 AM
    CleanupBoss
    Chet
    Sparks, NV
  6. Feb 9, 2016 at 9:11 AM
    anthony250f
    Anthony
    San Diego, CA
    16 is not ok in boost
  7. Feb 9, 2016 at 12:37 PM
    Redsyota
    Denver
    Agreed. Sounds like something is seriously wrong. Most Toyota techs have not seen a try blower installed and likely they missed something when replacing your pump. Don't go into boost and take this thing to a dealer....my gut would be not the same one but they should warranty their work at least.
  8. Feb 9, 2016 at 12:41 PM
    anthony250f
    Anthony
    San Diego, CA
    Yup take it in! Don't ruin the motor
  9. Feb 9, 2016 at 12:44 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    It is most likely your new air pump assembly replacement is introducing unwanted air while in boost which is causing your AFR to go to the 19/1 range. Regardless, that is stupid hot and you risk inploding the engine with those kind of lean mixtures.
    I agree with the others. Take it back to the dealer. They probably fucked up on something during the install.
  10. Feb 9, 2016 at 1:46 PM
    CleanupBoss
    Chet
    Sparks, NV
    Thank you all for your input, I have a service appointment scheduled for Thursday morning
  11. Feb 9, 2016 at 1:53 PM
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    During the install, they might had disconnected your battery. ECU might have to relearn your driving habits :notsure:
