S Mode
Discussion in 'South West' started by TedTheTaco, Sep 12, 2020.
  1. Sep 12, 2020 at 10:52 PM
    TedTheTaco
    TedTheTaco [OP] Member
    2016 TRD Off-Road
    3” lift, Fuel Assaults 17x9 with 33s, Kicker Subwoofers, LEDs, Bakflip Cover
    I have a 2016 TRD Off Road, and every time I switch into “S” mode the truck automatically goes into 4th gear. Is anyone else having that problem, and is there a remedy to fix it?
  2. Sep 12, 2020 at 10:53 PM
    Bishop84
    Bishop84 Well-Known Member
    Normal with all toyotas, its basically like the old days of turning off overdrive.
  3. Sep 12, 2020 at 10:56 PM
    TedTheTaco
    2016 TRD Off-Road
    Okay. Bummer it doesn’t automatically adjust to the gear it is in based off the speed. Thanks
  4. Sep 13, 2020 at 12:06 AM
    JEEPNIK
    JEEPNIK Well-Known Member
    2020 Voodoo Blue TRD Sport
    By kicking it out of overdrive you get a power boost. Nice trick when you want to accelerate on a freeway.
  5. Sep 15, 2020 at 1:39 PM
    Technique
    Technique Well-Known Member
    Alex
    Utah
    2017 Silver Offroad DCSB
    -285/70/17 Toyo AT3 -Tuned
    That doesn’t mean the truck is necessary in 4th. It will be limited to 4th gear until you change it.
    You could be going 10mph and jump to S mode and it will show S4 but you may be in 2nd gear. As you go faster it’ll shift gears but then stay at 4 unless you change it if that makes sense.
