S Mode
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Crabasket, Jun 13, 2023.
  1. Jun 14, 2023 at 10:22 AM
    Hairless_Ape
    Hairless_Ape Well-Known Member
    South Jersey
    2021 F150
    Adaptive transmission programming is terrible in concept and execution. It's the reason why people who log most of their miles cruising down the highway or milling around on back roads complain about the Tacoma transmission. The transmission "learns" to be lazy. Now when you need it to be responsive that goes against how it "thinks" it should behave, and it doesn't want to go...slow shifts, upshifting too soon, holding gears when it should down shift. Driving in S mode avoids that.
    D may be just fine for you, but that doesn't mean it's best for everyone.
  2. Jun 14, 2023 at 10:44 AM
    cryptolime
    cryptolime Here to Help
    Wilmington, NC
    2021 SR 4x4 2.7L
    what's the point of using s-6? that's not going to give you any engine braking at all. you don't want to be in overdrive going down a mountain. You should be in S-4 at the most when going down a long grade. I'm usually in S-3 or S-4 for mountain highways when going downhill.
    zoo truck and davidstacoma like this.
  3. Jun 14, 2023 at 12:06 PM
    kahanabob
    kahanabob Well-Known Member
    Maui
    16 TRD 2WD 4DR
    OP is saying that when he pushes the shifter to the left nothing happens and he is still in normal drive mode.
    this is a new one, if he is correct sounds like electrical glitch.
    TRDRed likes this.
  4. Jun 14, 2023 at 12:53 PM
    musicisevil
    musicisevil Lesser-Known Jack Wagon
    Alaska
    2019 TRD Sport
    Someone on here had the same issue a couple months back. I don’t recall if there was a resolution but also haven’t searched for the post.
    Not sure why you’re the only one making this point. I was confused about its purpose as well until I read about it bypassing the trans learning on here and tried it on my daily commute. There’s a distinct difference between S6 and D in shifting and acceleration for my truck.
  5. Jun 14, 2023 at 1:08 PM
    Tacoma Rant
    Tacoma Rant I can’t be good all the time.
    Wisconsin
    2023 Tacoma TRD Sport Electric lime
    Weird, when I push mine over to S mode it only shows the number four and nothing else.
    I assumed that it meant it would not go past fourth gear?
    When I get off of work I'm gonna have to go take a look at this
  6. Jun 14, 2023 at 1:13 PM
    Canadian Caber
    Canadian Caber R.I.P Layne Staley 67-2002
    Les
    B.C. Canada, eh
    2020 TRD Sport DCLB 4X4 Super White
    That's normal. It goes to S-4 by default. Once there push the shifter forward for higher gears. 5th & 6th. Or pull it back for 3, 2 and 1.
    TRDRed, kahanabob, Phlogiston and 3 others like this.
  7. Jun 14, 2023 at 1:21 PM
    Tacoma Rant
    Wisconsin
    Got it! Learned something new today.
    kahanabob likes this.
  8. Jun 14, 2023 at 1:30 PM
    TacoTime55
    TacoTime55 TT58
    Ed
    Delaware
    2021 Midnight Black TRD Sport AT/DCSB
    TRD Lift,OTT Tune, LED HLs,TRDSkid, TalonCAT
    Come on @Rock Lobster!
    Even I knew that!!! lol
    I use S4 and S5 mostly...flicked the gear one time in S5 and viola, S6! Who'd of thunk it?
    For quicker response, I engage ECT but I have to be careful since it won't down-shift. (I have OTT Tune)
    S4 without ECT for driving in town
    S5 without ECT for driving above 50mph
    When I'm on the freeway/highway, I go into D.
  9. Jun 14, 2023 at 1:44 PM
    Crabasket
    Crabasket [OP] New Member
    2018 toyato tacoma TRD
    None
    Yes it shifts just like it is in D. does not let me select gears doesn'teven show them
    TRDRed and Phlogiston[QUOTED] like this.
  10. Jun 14, 2023 at 2:40 PM
    jakbakcrak
    jakbakcrak Well-Known Member
    Jack
    2020 Quicksand TRD Off Road Tacoma
    Several aesthetic
    I've got a case of S6's in my garage. Selling them for a grand a piece. Discounting, if you buy 2 or more.
  11. Jun 14, 2023 at 2:46 PM
    Canadian Caber
    Les
    B.C. Canada, eh
    Hmmm. don't know what controls that function. ECU or the TCU. Maybe try disconnecting the battery for a short period of time? Also, don't know if the other person who had a similar problem had a resolution either. 2018.... Out of warranty so Dealership would be expensive.
  12. Jun 14, 2023 at 3:39 PM
    3GTCMLMTD
    3GTCMLMTD Well-Known Member
    2022 Limited
    Damn, you learn something new every day. I’m going to try out S6 and see how it shifts and accelerates compared to D.
  13. Jun 14, 2023 at 4:10 PM
    Phlogiston
    Phlogiston There are no victims, only volunteers.
    Not Karen
    The wild west
    2016 SR5 DCSB
    Aesthetically Challenged
    My god, i can't believe all this rocket science surrounding S mode.
    I never even read about it, i just tried it and figured out how it worked, it's not complicated.
    cropduster78 and kahanabob like this.
  14. Jun 14, 2023 at 4:15 PM
    musicisevil
    Alaska
    2019 TRD Sport
    I think acceleration is probably wishful thinking on my part after testing a little on my way home from work.
    I absolutely hate the one second delay when I stomp on the gas, but it does it in D and S.
    It definitely changes the shifting though. I can’t even get into 6th in D unless I’m doing over 70 downhill, but in s6 it gets there in a much more natural way I guess I would say
    Phlogiston and 3GTCMLMTD[QUOTED] like this.
  15. Jun 14, 2023 at 5:20 PM
    #35
    3GTCMLMTD
    2022 Limited
    Thanks for sharing your experience trying it out. I am curious to see if there will be any differences in how the truck acts not using any learned values.
  16. Jun 14, 2023 at 5:42 PM
    #36
    kahanabob
    Maui
    16 TRD 2WD 4DR
    then you have an electrical glitch. dealer time.
    could be a connector is not connected. anyone do any work on or around the tranny or any electrical work period?
  17. Jun 14, 2023 at 5:42 PM
    #37
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    Imo, thats mostly bs. I drive a combination of back roads, city, and major highways. My transmission works perfect on all. There''s really no need for the s modes except when towing. I think the main reason for these transmissions shifting wonky, is they're never broken the way I was told. Many owners use these other electronic modes from the beginning, instead of just leaving it in the d mode, then end up this way, and complain.
  18. Jun 14, 2023 at 5:48 PM
    #38
    Phlogiston
    Not Karen
    The wild west
    2016 SR5 DCSB
    Instead of trying to stomp on the gas, try using S mode to downshift, example- if you're cruising at 65mph, drop it into 4th and accelerate to say 70-75 then tap it up to 5th etc..
    That shift will still take a second of delay the difference is, you will hold a higher rpm when you shift up to the next gear.
    Canadian Caber likes this.
  19. Jun 14, 2023 at 5:49 PM
    #39
    zoo truck
    None
    Exactly, I feel it's why toyota locked out s6 in my truck....imo, there's no use for it. You can just slip the shifter over in the d mode if you want 6th. I've found s5 to work well for towing anything around 2k lbs.
  20. Jun 14, 2023 at 5:49 PM
    #40
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    Pull geography book and look at the topography of US of A and Canada. There are some big ass hills will make your tranny confused.
    3GTCMLMTD likes this.
