S-Pod's
Discussion in 'Lighting' started by Sky, Jun 26, 2013.
  1. Jun 26, 2013 at 2:20 AM
    Sky
    Sky [OP] Taco Member
    Brandon
    Redlands/Yucaipa
    05 V6 4x4 TRD Off-Road
    First of I painted my truck Satin flat black,.... well faded satin flat black lol, it has 5100s up front and J66's as well as billy 5150s in the rear, 285/ 75/16 Falcon wild peak A/T, Axis regulators painted satin black, with a tan rings! brush bar with 30 in led light bar , Custom rear Bumper, Straight Pipe. Led Hi/Low, and led fog lights, Flat Black Interior!
  2. Jun 26, 2013 at 2:22 AM
    blake5995
    blake5995 Well-Known Member
    Blake
    Truckee, CA
    98 Tacoma SR5 4x4 2.7L
    looks pricey...
  3. Jun 28, 2013 at 9:47 AM
    HighTQCummins
    HighTQCummins Instagram: stormtrooptaco
    Hank
    SE PA
    '12 SW DCSB Sport
    5% all around, derp'd wheels, FMS40, 30" E-Series, 55w 6k bi's, 35w 5k fogs
    I have one, its worth literally every penny, even though there are always naysayers that say you can do it for less. I would buy one again if I had to
  4. Jun 28, 2013 at 9:48 AM
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    JAndrews has one.
  5. Jun 29, 2013 at 10:35 AM
    wrmathis
    wrmathis Dark Lord of the Sith
    Bonaire, GA
    2006 Tacoma TRD OR 4x4
    parts and stuff
    i have one too. ive modified the harness to do what i need but that was easy and makes wiring up 6 things very easy especially when it comes to relays. i helped jandrews a little on his so he could get his hooked up correctly. they have updated thier kit since i got mine. i would buy again if i got a new truck or even for another vehicle if i needed it.
  6. Oct 20, 2013 at 12:07 AM
    benbacher
    benbacher Purveyor of Fun Vendor
    Anchorage, AK
    '10 Tacoma 4x4 LBDC SR5 TRD Sport
    Too many to list now.
    Thread revival. Amy of you guys see the new bluetooth adapter? Lets you run virtual switches on your i-device. Wondering if i get two Spods i can have one set of switches entirely virtual.
  7. Oct 21, 2013 at 2:25 PM
    HighTQCummins
    Hank
    SE PA
    '12 SW DCSB Sport
    you need 2 set of switches to run two 2 spods. they are manual over ride for the bluetooth module, you cannot run it purely on bluetooth
  8. Jan 31, 2014 at 8:30 AM
    ThomasMore66
    Dallas/Fort Worth & Durango
    I don't think the spod is pricey. Anything that would make the install nice and clean is good to me. Here's my question, has anybody installed one on the TRD OR? Spod doesn't include a panel with the Tacoma kit, but I don't have a bunch of blanks - only the two for the seat heaters. I'm just curious to see what other people have done.
  9. Jan 31, 2014 at 8:58 AM
    The Woodsman
    The Woodsman Well-Known Member
    James
    Batesville, IN
    08 FJ Cruiser
    A bunch of mods :)
    If you only consider the cost of the wiring, relays, switches, wire loom, connectors etc that it takes to do a decent job, the sPod may not seem like a great deal. If, however, you value your time at all and also want a very professional looking install then the sPod is pretty reasonable . . . and even more so if you buy it on a group buy like I did.
  10. Jan 31, 2014 at 9:37 AM
    Tuctaco
    Tuctaco Well-Known Member
    Todd
    Tucson, AZ
    2012 MGM TRD OR 4x4
    Katzkins, Redline hood struts, Pop & Lock,285/75/16 Toyo Open County ATll, 16X8 Konig Countersteer, Icon extended coilovers, Icon rear shocks, Icon progressive leaf pack, LR UCA's, extended brake lines,
  11. Feb 16, 2014 at 3:38 PM
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    You need to buy (1) remote control ($175) per sPOD and it only works on the new sPOD's. You could put the switches in a location that wouldn't be seen and control them by bluetooth but ultimately you still need the switches.
    Ill have (1) sPOD with no remote and (1) with the remote that will be installed come spring. Just waiting for the weather to break so I can rip out my interior and start wiring.
    For people like me who are anal and do not enjoy wiring, the cost of the sPOD is dirt cheap and I know of no one controlling their accessories from their phones with homemade kits.
    I am keeping all vital devices on the non-bluetooth sPOD and only putting non-vital accessories on the remote. No way I want my compressor or lockers controlled by bluetooth. I do enough butt dialing as it is. :D
  12. Feb 17, 2014 at 5:39 AM
    benbacher
    Anchorage, AK
    Thanks for the reply skip, I actually sell them now, so i know hahaha. Stoked for you to put yours in! You're gonna love it!
  13. Feb 17, 2014 at 9:26 AM
    XXXX
    sKiP
    05 Prius
    Cool. What would be the benefit from purchasing through you apposed to going to them direct? The first one I bought they shipped for free so that saved me $22.
    I just pulled the trigger on the second sPOD w/remote last week and had to pay shipping. The first one Ive had for months.
  14. Feb 18, 2014 at 6:36 AM
    benbacher
    Anchorage, AK
    No shipping from me either and you get to deal with someone you know, even if its just a bit. ;)
  15. Feb 18, 2014 at 3:53 PM
    XXXX
    sKiP
    05 Prius
    Gotcha....
    I was talking to Cindy yesterday about some custom stuff I want them to do to the next harness they ship me. So far I have nothing but praise to offer them. When the guy I was talking to couldn't answer my question he didn't BS me like other companies. He simply said "I do not know, but let me transfer you to our owner and she can help you." I like that.
  16. Feb 18, 2014 at 5:54 PM
    Sky
    Brandon
    Redlands/Yucaipa
    Now that's good survise
  17. Feb 20, 2014 at 3:20 AM
    benbacher
    Anchorage, AK
    Cindy is great, I have absolutely nothing but praise for them as well, I love companies that try and innovate, and more than that, I love companies that try and innovate with products aimed at MY vehicle. Those are the ones I end up carrying.
  18. Feb 24, 2014 at 2:01 PM
    XXXX
    sKiP
    05 Prius
    Had a good long conversation with Cindy and one of her employees Friday night.
    I urge anyone thinking of purchasing a sPOD call them up and talk to them. Once you talk to them I'd be amazed if you didn't get off the phone a customer.
    They also have custom mounting options for switches and other items for sale then just the ones is listed on their website.
    We have been going back and forth for a few days concerning what I want to have them do for me and they have been great to work with. Now the wait for them to make all the harnesses up and ship my baby out to me.
  19. Mar 21, 2014 at 8:19 AM
    XXXX
    sKiP
    05 Prius
    Just got my second one received earlier this week. Had them provide me with custom switches, a custom harness, and they were nice enough to wire everything for me long enough so all I have to do is plug it in, throw on my switch covers, and mount the bracket in my sun glass holder.
    The only wire that I need to tap into the factory system is an accessory wire so the switches light up when my key is in the ignition.
    There was no way I wanted 12 switches in my truck that only lit up when they were on. Now Ill have red for when the switch is "on" and amber for at night when the switch is "off".
    Props to sPOD, but the real review will be later in spring when I install it all.
  20. Mar 21, 2014 at 9:08 AM
    ThomasMore66
    Show me the custom switch panel!
