S-Tech Dual USB port with Voltage Meter...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by evanair, Feb 20, 2022.
  1. Feb 20, 2022 at 4:31 PM
    evanair
    evanair [OP] New Member
    2013 Tacoma Extended Cab
  2. Feb 20, 2022 at 4:49 PM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    Cig lighter version in the RAV4.....
  3. Feb 20, 2022 at 4:53 PM
    idriveabox
    idriveabox Well-Known Member
    Calgary, AB
    2015 BRM SR5
    Im running it. Works fine. Quality? Probably not.
  4. Feb 20, 2022 at 5:11 PM
    Geeves77
    Geeves77 Well-Known Member
    Mark
    Northeast
    2011 Tacoma DCSB
    3 inch Icon lift with UCA’s
    And you just used the cig lighter wires for that I drive?
  5. Feb 20, 2022 at 6:29 PM
    idriveabox
    Calgary, AB
    2015 BRM SR5
    add a fuse on the drivers side fuse box. I have the larger size that fits the driver side switches.
  6. Feb 20, 2022 at 6:41 PM
    4xdog
    4xdog Well-Known Member
    Santa Fe, NM
    03 DC TRD OR, 15 DC TRD OR, 08 RX350, 62 TR3B
    I've had one of those for a couple of years, waiting for a chance to get into the wiring to fit it. I'd agree that the quality is OK but not more.
    How bright is yours when installed, @idriveabox? From bench tests it looks like the red display on mine might be brighter than I'd really like.
  7. Feb 21, 2022 at 8:24 AM
    idriveabox
    Calgary, AB
    2015 BRM SR5
    It’s bright. I would mount it low out if the way. Mine is beside the rsca button and the wheel blocks the light.
    4xdog likes this.
  8. Feb 21, 2022 at 9:23 AM
    kgarrett11
    kgarrett11 Master Yoda
    Garrett
    CA desert
    2015 DCLB
  9. Feb 21, 2022 at 7:28 PM
    Charlie Bravo
    Charlie Bravo Well-Known Member
    Charlie
    Coeur d'Alene, Idaho
    2009 Red Tacoma Access Cab 4wd 2.7MT
    RedLine Tuning hood QuickLIFT, Gen3 alloy 16x7J, All Pro Off-road bed stiffeners & IFS skid plate
    Thanks to evanair... I just ordered one and I hope (don't think) it'll fit where a blank is in the panel on the left side. (fog light switch maybe). It should provide better protection against interference with other systems as I looked at the exploded diagram of it, much better than the cheap lighter plug USB adapters. Ordered the red verse.
  10. Feb 21, 2022 at 9:31 PM
    4xdog
    Santa Fe, NM
    They’re available to fit both the left-side switch and center console switch openings, and those two spots aren’t the same size, of course.
    Charlie Bravo[QUOTED] likes this.
  11. Feb 22, 2022 at 3:13 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    my cheap cig lighter version shows voltage, charges whatever is plugged into it, makes no noise on stereo, has not interfered with any other systems and started no fires. same thing as the permanent installed switch blank type, only I can unplug it and use the port for other things or just shut the flipcap and not use it. Simply a whatever floats your boat situation. I have both types. Nothing wrong with either choice.
    Charlie Bravo likes this.
  12. Feb 22, 2022 at 2:52 PM
    Charlie Bravo
    Charlie
    I use the right 12v outlet with the Garmin nuvi 1350, but for charging a phone while traveling thought it would be nice to have a USB port somewhere. I don't use my phone while driving, but check the recent calls list when I'm not occupied with activity. There's always something going on outside the truck worthy of attention.
    A large reason to pay attention: A commercial fisherman I knew in Cordova, Alaska lived in the Mat-Su Valley and had a nice T100. The following spring he showed up for the gillnet season with a much heavier lifted Chevy and explained that he'd hit a moose in the dark between Palmer and Anchorage. Moose eyes do not reflect headlights, so it's a dark object in darkness. That long nearly flat highway commute runs through the Palmer Hay Flats, a very wet and good moose grazing area. Watching moose near I-90 (and the traffic) is one of the spectator sports in the area of Pinehurst, Smelterville, and Cataldo, Idaho... I enjoy the 2009 Access Cab, "Barcelona Red" thanks to two years of Spanish in high school at Grand Forks, North Dakota. Barcelona Red was among Dad's specs for his last truck, and his specs matched my own.
  13. Nov 21, 2022 at 2:26 PM
    evanair
    Just looking for an update on this. Of those who've installed this port, are they still working???
  14. Nov 21, 2022 at 4:02 PM
    idriveabox
    Calgary, AB
    2015 BRM SR5
    2+ years and no issues.
