S***ty Rear Diff Plug
Discussion in '2nd Gen. Tacomas (2005-2015)' started by DailyTacoMD, Jun 12, 2024.
  1. Jun 12, 2024 at 9:07 PM
    DailyTacoMD
    DailyTacoMD [OP] Well-Known Member
    Jeremiah
    2006 2.7L AC 4x4 5spd
    I’ll start by saying I’m a total hack, sometimes hamfisted.
    Had a day off today and decided to do fluid changes.
    - Front diff fluid changed & new driver side CV. Also did ECHS bushing and swapped out the OE Allen drain plug for a hex drain plug
    - Manual trans fluid change
    - Transfer case fluid change
    - Get to the rear diff and buggered the fill plug with a 12pt socket like an idiot. Sprayed beforehand with PB Blaster and let sit but still didn’t break loose, rounded the corners off. Got a good 6pt socket and hacked a sliver of a drink can and hammered the socket on. GOOD TO GO!
    … and there was much rejoicing… :bananadance:
    FishaRnekEd, steveo27, Crom and 8 others like this.
  2. Jun 12, 2024 at 9:15 PM
    DailyTacoMD
    Jeremiah
    A before shot from my crappy fix.
    New plug and ring ordered to fix er for good!
    tacoman45, Crom, HondaGM and 3 others like this.
  3. Jun 13, 2024 at 7:20 AM
    Hook78
    Hook78 Well-Known Member
    Eastern NC
    2015 DCSB TRD OR
    Bilstein 6112/5160 Icon RXT
    What even is the purpose of a 12 point socket anyway? Someone once told me they contact more surface area which seems opposite of truth.
    HondaGM, BabyBilly and Robnik like this.
  4. Jun 13, 2024 at 7:31 AM
    Robnik
    Robnik Disciplined Maniac
    Rob
    Greenacres, Florida
    2012 Base Reg Cab 2.7L 2TR-FE A340E
    Looked boogered up before you began. 6-point is the shape of the bolt.
    Glad you got it off. Way to think out of the six sided box, lol :thumbsup:
    HondaGM likes this.
  5. Jun 13, 2024 at 7:33 AM
    ridefreak
    ridefreak Well-Known Member
    NM
    2006 DCSB TRD
    minor tweaks
    I have a whole drawer full of sockets in my toolbox, very few are 12point and those rarely get used.
    12 point give more placement options and can sometimes help in places where there's limited room to work with a 6 point socket.
    Shawner1974, Robnik and Hook78 like this.
  6. Jun 13, 2024 at 2:00 PM
    paranoid56
    paranoid56 Well-Known Member
    San Diego
    14 double cab taco
    they are great for 12pt bolts :D
    Mully, Crom, b_r_o and 4 others like this.
  7. Jun 13, 2024 at 2:11 PM
    SomeGuy_GRM
    SomeGuy_GRM Well-Known Member
    2009 Tacoma SR5 TRD Off Road
    In the future, use an impact wrench.
    3JOH22A likes this.
  8. Jun 13, 2024 at 2:16 PM
    Hook78
    Eastern NC
    2015 DCSB TRD OR
    Never come across one in a lifetime of amateur wrenching
  9. Jun 13, 2024 at 2:26 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    ^Icon and All-Pro UCA bolts are 12-point.
    The intake manifold studs have an e-torx pattern. A 12-pt socket can be used to remove those, according to Toyota's install sheet for the v1 TRD intake.
    12-pt fasteners are very common on European cars like the Supra.
    Mully and Crom like this.
  10. Jun 13, 2024 at 2:41 PM
    Hook78
    Eastern NC
    2015 DCSB TRD OR
    Well, makes sense that I haven’t run across them then…I’m a Bilstein man, and (prayers) have never needed to work on the intake manifold (or European vehicles for that matter).
  11. Jun 13, 2024 at 2:43 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    ^For larger e-torx bolts (like those on your front diff torque tube) it's advisable to get proper e-torx sockets to avoid stripping the heads.
  12. Jun 13, 2024 at 3:01 PM
    Clearwater Bill
    Billy
    Largo Florida
    Thinner walls usually and a smidge easier to position sometimes, both from having more points and the thinner walls.
    I do have a nice small set of 8 point sockets too. :D
    Sometimes called double square. For working with pipe plugs. Which is what some marquees used as transmission fill plugs.
    winkel likes this.
  13. Jun 13, 2024 at 3:35 PM
    Hook78
    Eastern NC
    2015 DCSB TRD OR
    The ability to reposition with smaller movements is one I hadn’t thought of and makes sense.
  14. Jun 13, 2024 at 5:25 PM
    DailyTacoMD
    Jeremiah
    honestly I’ve always been leery of impacts with stuff like this because of the fear of stripping what is definitely a somewhat fragile bolt. Probably would’ve avoided the whole ordeal if I hadn’t grabbed the wrong socket:annoyed:
  15. Jun 13, 2024 at 6:54 PM
    2015WhiteOR
    2015WhiteOR Well-Known Member
    Gainesville TX
    I can't believe ginger ale has 130 calories smh
    tacoman45 and 3JOH22A like this.
  16. Jun 13, 2024 at 7:05 PM
    Albino Deer
    Albino Deer Member
    2007 Tacoma MT 4x4 Double Cab TRD OFF Road
    6112's with Total Chaos UCA's and Deaver U402 S1
    Had the same issue with the trans plug on mine (which is the same size and thread by the way). Ended up ordering a Vortex M18 x 1.5mm plug (P/N DP007) and replaced both the one in the Trans and rear don’t with it. It’s made of a better grade steel than the factory plug and is a hair smaller, which is nice if you get a lot of dirt on the rear diff. Either way, main takeaway is a 6pt socket works wonders.
  17. Jun 13, 2024 at 7:38 PM
    SomeGuy_GRM
    In my experience impacts apply less torque with more even distribution than I can with a box wrench. So they're less likely to break a bolt.
  18. Jun 13, 2024 at 7:54 PM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    I have a 6 point socket I ground flat to get on those..
  19. Jun 13, 2024 at 8:00 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Turns out it wasn't the drain plug that was shitty. It was your choice of socket
    ridefreak, 2015WhiteOR and dbittle like this.
  20. Jun 21, 2024 at 3:07 PM
    WOODY2
    WOODY2 Well-Known Member
    RAMONA,CA.
    FIFY
