?s with fitting 305/60/18
Discussion in '2nd Gen. Tacomas (2005-2015)' started by froggy256, Dec 26, 2010.
  1. Dec 26, 2010 at 7:53 PM
    froggy256
    froggy256 [OP] Member
    virginia
    07 black prerunner
    3" lift,
    im going crazy trying to figure this out on my own. i have a 2007 prerunner dc longbed. i just put a 3" leveling kit(3 in front 2 in the rear) i just got my 18x9 ultra goliath wheels in the mail today. now i am just stuck between getting the mickey thompson 305/60 or the 275/70. i really want the 305 but i have not been able to find many pictures with these tires. can i fit these tires without cutting into the frame. PLEASE HELP!! THANKS:D
  2. Dec 26, 2010 at 7:56 PM
    krimson
    krimson Nothin
    TRD Off Road
    OME 3" lift with 885 coils. OME Shocks with TSB 1.5 AAL. 285/75/16 KM2s. XD Hoss 16" wheels. DDM Tuning 6000K HIDs, H10 6000K Fogs. BHLM. Debaged. 20% tint on front windows.
    Did you ever consider 285s?
  3. Dec 26, 2010 at 8:02 PM
    RZRob
    RZRob Well-Known Member
    Robert
    Anaheim Hills
    I think 305s are just asking for fitment issues.
    RZ Rob
  4. Dec 26, 2010 at 8:20 PM
    froggy256
    virginia
    07 black prerunner
    3" lift,
    i am stuck on the mickey thompson and the only options i have is the 305 or the 275.(because of my 18" wheels) i just like the wide look.
  5. Dec 26, 2010 at 8:23 PM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    the 305s will rub like a bitch cause my 285s rub like a bitch before cutting. Also with the 305s most likely you will need to cut and plate the body mounts. IMO go with 285s and keep your caster over 2.6 to avoid the cab mounts
  6. Dec 26, 2010 at 8:27 PM
    froggy256
    virginia
    07 black prerunner
    3" lift,
    "cut and plate the body mounts. IMO go with 285s and keep your caster over 2.6 to avoid the cab mounts"
    sorry bro im new to this what is the body mounts and what is my caster
  7. Dec 26, 2010 at 8:41 PM
    ETaco23
    ETaco23 Marshall offroad Fabrication
    Evan
    PNW
    13' Pyrite Mica TRD Offroad DCSB 4x4
    Color Match Grille, Bed mat, Icon's with JBA UCA's, Dakars and 295 BFG KO2, Bora 1" spacers, Snugtop Canopy, and my "Marshall Fabrication" Rock Sliders.
    im ganna try and run a 295/70/17, which is a 33x12 AT tire
    and hope to not run into the cab mount...
  8. Dec 26, 2010 at 9:07 PM
    achirdo
    achirdo I Weld!
    Adam
    North DFW
    06 dodge ram 3500 5.9 cummins
    The castor is part of your alignment
  9. Dec 26, 2010 at 9:10 PM
    Jason'sLawnCare
    Jason'sLawnCare Prepared for Bambi
    Jacksonville Florida
    08 4x4 Double Cab TRD Rugged Trail
    CBI Moab 2.0, CBI Trail Rider 2.0, CBI sliders w/kickout, Superwinch EPi9.0S, OME sport shocks w/886 coils, OME n182, 1.5" aal, JasonBuilt 3/16th full belly skid, BuiltRight uca, Body Mount Chop, 285/75/16 km2's, Rear cat delete, exhaust crossover rerouted, Fog light anytime, Locker mod, Rear leaf tsb, Debadged, Uws Tool Box, Electric Exhaust Cutout, AFE Pro Dry S, Kiwi Wifi, Diff Breather Relocated, Grom Ipod Adapter, Dual Diehard platinum batteries isolated by BlueSea marine switch
    To my understanding it's the lower the caster the less rubbing at least on the back of the fender. If it's angled more then the tire will go farther back when the suspension is compressed.
  10. Dec 26, 2010 at 9:17 PM
    ktmrider
    Junk
    thats what I thought, but my original alignment without aftermarket UCAs the caster was 4.1 and 4.2 on each side. After my TC UCAs my second alignment was 2.2 on the drivers side and 2.6 on the passagner. I could not make a 90 degree left hand turn or a u turn without completely stopping my tire from moving. After i had my cab mounts chopped i got another alignment and 2.9s on each side and havent had any problems with rubbing anything.
  11. Dec 26, 2010 at 9:18 PM
    ktmrider
    Junk
    to the rear of your fenderwell is the body cab mount, they hit tires larger than stock when the caster is too low on your alignment. the caster is part of the alignment.
  12. Dec 26, 2010 at 9:28 PM
    Jason'sLawnCare
    :confused: I don't know then. I'm scratching my head at this. There's probably something we are missing.
  13. Dec 26, 2010 at 9:31 PM
    ktmrider
    Junk
    sorry i meant left hand turn if that clears things up
  14. Dec 26, 2010 at 9:34 PM
    Jason'sLawnCare
    I figured with the u turn but that further supports your point with the lower caster more rub. I don't know what it could be.
  15. Dec 26, 2010 at 9:40 PM
    ktmrider
    Junk
    http://autorepair.about.com/od/glossary/ss/df_alignment_2.htm
    I think this kind of clears it up
    but the tilt they are talking about is in relation to the spindle so if it is backwards tilt the tire would actually be forward and + caster number.
  16. Dec 26, 2010 at 9:51 PM
    ETaco23
    Evan
    PNW
    so when I go to get my allignment done tomarrow I should tell them to get my caster above 2.8? will this make the tire further away from my body mount?
  17. Dec 26, 2010 at 9:59 PM
    ktmrider
    Junk
    tell them this
    Toe: 0* (if not precisley 0*, it should have + toe out but not to exceed .05*)
    Camber: 0*
    Caster: between 2.3* and 3.1**
    caster i would go 2.9 cause thats what i did and havent had any problems
  18. Dec 26, 2010 at 11:30 PM
    ETaco23
    Evan
    PNW
    k. thanks!
  19. Dec 26, 2010 at 11:33 PM
    solus
    solus HOME!!!
    Mark
    Bremerton, WA
    RR 4wd SR5
    interesting size... I have 305/65/17 but then again I have 4.5" of lift
