Sacramento Alignment
Discussion in 'Northern California' started by grubburg, Aug 8, 2019.
  1. Aug 12, 2019 at 9:14 AM
    grubburg
    grubburg [OP] Well-Known Member
    2019 TRD OR MT
    K & N Intake, Gibson Catback (chopped), Weathertech floormats, 285/70/17 Ridge Grapplers, Black Rhino Glamis wheels, Kicker Key, Kicker Hideaway, Infiniti Speakers, OV Tune, 888's, 5100s X 4, HS 3-leaf, LR SPC UCAs, Diff Drop, Carrier Bearing Drop, OEM Bed Mat, Morimoto HID low beams, Morimoto LED 2 Stroke High Beams, KC 336 LED bar, KC C3 LED pods for rear, KC LED 6'' SlimLites ditch lights, N-Fab Steps, Auxbeam Interior Blue Lights, 7r41lbr34k3r Shift Knob, Wet Okole Seat Covers, Diode Dynamics SAE Pro Fogs, Cali Raised ditch light brackets, hidden light bar brackets, tailgate light brackets.
    @Vyprdad I made it early cause I know you were gonna steal the first available appt!
  2. Aug 12, 2019 at 9:17 AM
    Vyprdad
    Vyprdad Well-Known Member
    David
    2019 Tacoma TRD Off Road
    You bastard hahah
    grubburg[OP] likes this.
  3. Aug 12, 2019 at 1:19 PM
    grubburg
    2019 TRD OR MT
    Radial hooked it up for only $75. Ask for Rafael. He drives a lifted 4 Runner.
    Thanks again for rec!
    TOP TACO likes this.
  4. Aug 12, 2019 at 1:21 PM
    eon_blue
    Azusa, CA
    That's a great price for a good alignment especially if they custom tailor the numbers to suit your rig. Usually alignments in that price range are the run of the mill factory spec ones. Good find
  5. Aug 12, 2019 at 1:45 PM
    grubburg
    2019 TRD OR MT
    Yeah PepBoys is $99.
    They quoted me $75-95, and I said I'll happily pay the $95 for good work.
    They also double checked the torque specs on my UCAs as a favor and without me asking.
    Decent places are hard to find and these guys deserve the word of mouth.
    https://www.radialtireservice.com/
    blu92in99, scocar and TOP TACO like this.
  6. Aug 18, 2019 at 9:22 PM
    maxdout
    maxdout Well-Known Member
    What are good specs for 2.5 lifted tacos?
  7. Aug 18, 2019 at 9:38 PM
    grubburg
    2019 TRD OR MT
    I've been very happy with these. Tech said its the same as his lifted 4runner20190813_213803.jpg
  8. Aug 18, 2019 at 10:14 PM
    eon_blue
    Azusa, CA
    Depending on your tire size you might want to push for 3 or more degrees caster. With 33s it'll help clear the pinch weld
    You gotta tell them that's what you want because technically 3 or more degrees is out of spec so they usually max it at around 2 - 2.5
  9. Sep 28, 2019 at 3:01 PM
    TacoEspecial
    TacoEspecial SSSlow
    Mark
    Sacramento
    13 Sliver TRD AC
    BAMF RCLT Deaver Fox 2.5 StopTech Dana 60 37s 475:1
    I just had my truck aligned at Goodyear on I St.
    I was given two quotes.
    They quoted me $115 for a one time custom alignment.
    I do think they warranted it for so many months.
    I asked for extra caster ~3 deg
    2nd quote was $204 for a 3 year custom alignment.
    On the 3yr they said I could bring it in each time I modified something.
    Here's the settings I ended up with.
    The person doing the alignment was great to talk with.
    I explained what I wanted before he started and then he explained what he did and why.
    He thinks this is the best I can do with what I have.
    He said the caster should be off about .5 from side to side.
    Basically he maxed the caster on the bottom then gave me as much as he could while keeping the other settings in range.
    I opted for the 3yr.
  10. Oct 8, 2019 at 11:16 AM
    93yotasr5
    93yotasr5 Well-Known Member
    Sacramento
    I have had great success with the lifetime Firestone alignment. My truck is there right now after I adjusted my coil overs. I guess I’ll edit this post if something isn’t right.
    Here is the final print out. I guess they couldn’t quite get it all perfect. I adjusted my drivers side quite a bit to make up for the “lean” compared to the passenger side.
    Can Anyone who knows alignment numbers tell me if these numbers look bad?
  11. Oct 10, 2019 at 9:12 AM
    lv_cement
    lv_cement Active Member
    You think they could do SPC UCA for 2019 tacoma
    TOP TACO[QUOTED] likes this.
  12. Oct 10, 2019 at 9:32 AM
    TOP TACO
    TOP TACO Well-Known Member
    Marz
    Sacramento
    15 Tundra Crewmax
    Blackvue dash cam
    Oh ya! That's what I have for uppers.
  13. Oct 10, 2019 at 9:36 AM
    lv_cement
    Thanks!
  14. Oct 10, 2019 at 12:08 PM
    lv_cement
    Are they pretty booked out? How much did they charge?
  15. Oct 10, 2019 at 12:42 PM
    #35
    TOP TACO
    Marz
    Sacramento
    15 Tundra Crewmax
    Blackvue dash cam
    Couldn't tell you what the current wait is, call and make an appointment. I haven't checked my records to verify what I paid either. I would take them the instructions that come with the Uppers just in case...
  16. Oct 18, 2019 at 12:03 PM
    #36
    ZR NO
    ZR NO Well-Known Member
    Andy
    2019 TRD PRO - Super White
    So far just a bed mat and a lighter wallet
    @grubburg i from sac as well. S&H 4wheel Drive was the shit back when I had my YJ (late 90’s). I’ve heard the quality which they were know is no longer. They contract services out which they never did before. Check these guys out when you get a chance. They are doing a top hat spacer lift for me
    https://stellarbuilt.com/
  17. Oct 18, 2019 at 12:27 PM
    #37
    lv_cement
    Thats cool I was there just this WEDS
  18. Oct 18, 2019 at 12:34 PM
    #38
    TacoEspecial
    TacoEspecial SSSlow
    Mark
    Sacramento
    13 Sliver TRD AC
    I did a custom alignment with Firestone and asked them for what I wanted.
    I felt they gave me a good alignment for what I asked for.
    What where you looking for?
    If you wanted a lot of caster you got it.
    I was told the caster should be different from side to side so yours could be a good compromise if you wanted 3 deg.
    On yours, I think your camber should be readjusted shooting for something closer to being even side to side and zero.
    Most important, I don't know much about this stuff other that what I posted in my other post in this thread.
