SACRAMENTO AREA: NEED HELP REPLACING NEEDLE BEARING WITH ECGS BUSHING
Discussion in 'Northern California' started by remysenpai, Aug 15, 2023.
  1. Aug 15, 2023 at 11:51 AM
    remysenpai
    remysenpai [OP] Member
    Remy
    2018 Tacoma TRD Pro
    i have a 2018 tacoma trd pro. i added a lift (only springs) and now im noticing a vibration/humming sound coming from the driver side. it does go away when the 4hi is engaged and comes back when turned off. i researched and a lot of people have come across the needle bearing replacement. im getting the parts to replace it but i am needing help to replace the part. anyone is the sacramento area willing to help? thanks!
    MyWyfsRnnr likes this.
  2. Aug 15, 2023 at 12:12 PM
    10YSON
    10YSON Well-Known Member
    GREG
    TACOMA & 4RUNNER
    TOTAL CHAOS / KING / DEAVER / PRP / DIRTKING
  3. Aug 15, 2023 at 12:21 PM
    remysenpai
    Remy
    2018 Tacoma TRD Pro
    is that someones ig? or here on TW? thanks by the way
  4. Aug 15, 2023 at 12:28 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    @MyWyfsRnnr
    Fixed it for him:thumbsup:
    MyWyfsRnnr and TOP TACO like this.
  5. Aug 15, 2023 at 12:29 PM
    10YSON
    GREG
    TACOMA & 4RUNNER
    That is someone here on TW.
    I don't know where you are in diagnostic process but I always start by jacking up the corner the noise is coming from and wiggling the tire to confirm it's not a tie rod or wheel bearing, then inspect the CV next and go progressively deeper. When I had my stock suspension lifted I would burn through tie rods at an incredible rate.
  6. Aug 15, 2023 at 12:34 PM
    TnShooter
    Deogee
    STOCK
    90% of the time, if the noise goes away in 4WD, it’s the needle bearing.
    Occasionally it’s a wheel bearing, but they typically still make the noise when cornering or going around curves.
    I’d feel comfortable recommending the bushing based on OP’s description.
    10YSON likes this.
  7. Aug 15, 2023 at 1:03 PM
    remysenpai
    Remy
    2018 Tacoma TRD Pro
    ill try to inspect more. all i know as of now is…i lifted my truck with the eibach springs using my trd shocks. and a day or two later i notice a humming/vibrating noise. its not a constant noise but its a noise/feeling that comes and goes. i first noticed at around 45-55ish mph especially slowing down. when i do engage 4hi it stops and when i turn it off the humming/vibration comes back. the humming/vibration feels like its coming from right below me somewhere drivers side. not the steering wheel.
  8. Aug 15, 2023 at 1:03 PM
    remysenpai
    Remy
    2018 Tacoma TRD Pro
    thank you! :)
  9. Aug 15, 2023 at 4:19 PM
    silvertep
    silvertep Well-Known Member
    Luke
    Sacramento, CA
    2018 4Runner TRD-Off Road
    The usual
    @MyWyfsRnnr just did my ECGS bushing, Chris is great and highly recommended.
    I'd check how much play you have in your CV by the diff.
    TnShooter, MyWyfsRnnr and notlefty like this.
  10. Aug 15, 2023 at 5:42 PM
    remysenpai
    Remy
    2018 Tacoma TRD Pro
    best way to contact him? @silvertep
  11. Aug 15, 2023 at 5:51 PM
    silvertep
    Luke
    Sacramento, CA
    The usual
    DM him through here and wait. Just FYI he's not always available and could be working on other projects.
  12. Aug 15, 2023 at 6:14 PM
    MyWyfsRnnr
    MyWyfsRnnr Well-Known Member
    Citrus Heights
    2018 4Runner TRD
    Prinsu full rack, 3" OME, 275/75/17 KO2, Anytime Backup, BudBuilt Skids & Sliders, Wet Okole covers, Tint front, Silverstar Headlights, black taillights, LED Backup lights, LED interior Lights
    I just got back into town from a trip without cell haha! @silvertep I will text you this evening
    JK, notlefty, silvertep and 1 other person like this.
  13. Aug 15, 2023 at 6:21 PM
    silvertep
    Luke
    Sacramento, CA
    The usual
    Figured :)
    MyWyfsRnnr[QUOTED] likes this.
  14. Sep 8, 2023 at 8:50 PM
    myn75
    myn75 Well-Known Member
    Nor Cal
    2021 TRD Off-Road 4x4 DCSB, 1996 4runner SR5 V6 4x4 auto
    ARB OME BP-51 2”, TJM sliders, AT3Ws, Diode Dynamics SS42"
    Ive got the full kit. Remove, install, seal install
