Sacramento members
Discussion in 'Northern California' started by stevenstaco, Mar 2, 2011.
  1. Oct 10, 2017 at 6:57 AM
    #4421
    KMFDM_V
    KMFDM_V Well-Known Member
    Ken
    Sacramento, CA
    09 Timberland Mica 2.7L 5MT 4x2 Access
    I may have tweaked a few things...
    I just read that 885s are not usable with stock shocks so I think I'm out of luck on this one.
    HAVING FUN[QUOTED] likes this.
  2. Oct 10, 2017 at 7:11 AM
    #4422
    HAVING FUN
    HAVING FUN Old Man
    Leonard
    Sacramento
    08 4runner
    Yeah they would push more than an inch also.
  3. Oct 10, 2017 at 7:25 AM
    #4423
    KMFDM_V
    Ken
    Sacramento, CA
    Good to know I have options if I decide to get some bro lean o_O
    FirstTimeFirstGen likes this.
  4. Oct 10, 2017 at 7:48 AM
    #4424
    Speedo
    Speedo Well-Known Member
    Sacramento, CA
    2006 dcsb 4x4
    Wrecked!
    KMFDM_V likes this.
  5. Oct 10, 2017 at 8:03 AM
    #4425
    KMFDM_V
    Ken
    Sacramento, CA
    Thanks for the advice, sounds solid. That said I'm not actually looking to lift, but I would accept up to an inch since it would level me. The only reason I said up to an inch is because I bought TRD OR takeoffs from a 3rd gen (without coils) and I know that the original coils I would have given an inch. So I should be able to use any coils that would provide up to an inch and still be within the limits of these shocks. My best bet is likely a pair of stock takeoffs, just not 3rd gen OR coils if they are heavy duty as I am running pretty light up front (2.7L, Prerunner, Access).
  6. Oct 10, 2017 at 8:06 AM
    #4426
    KMFDM_V
    Ken
    Sacramento, CA
    I'm not even sure I need to bother replacing mine. I just figured it's worth doing if I can find the right fit as long as I'm replacing the shocks already.
  7. Oct 10, 2017 at 8:09 AM
    #4427
    Speedo
    Sacramento, CA
    2006 dcsb 4x4
    Wrecked!
    I have the above setup off my truck the billys are done. but when I bought it they were set at .85 with stock springs and it set level.
    I then bought the lift springs to gain more lift . road like shit but did the job.
    make an offer if you want them
    KMFDM_V likes this.
  8. Oct 10, 2017 at 8:36 AM
    #4428
    KMFDM_V
    Ken
    Sacramento, CA
    I'm only looking for coils, preferably with low miles to refresh my suspension while I change the shocks. Otherwise I should be fine to keep use my original coils.
    I'm lacking the experience to know if mine are getting worn out or if they are just fine to reuse. I should have made it to the last Mod Day just to let someone with experience drive my truck and give feedback.
  9. Oct 10, 2017 at 9:06 AM
    #4429
    HAVING FUN
    HAVING FUN Old Man
    Leonard
    Sacramento
    08 4runner
    @jqueener you still have your truck I do believe. I seen on research you did the internal, (firewall) snorkel, would like to check it out, looks like it would be more safer for me going into the ruff.
    Took a hit on the A pillar couple trips back, and would have wiped out an external for me.
  10. Oct 10, 2017 at 9:17 AM
    #4430
    Speedo
    Sacramento, CA
    2006 dcsb 4x4
    Wrecked!
    Yes still have it.
    Currently sitting in my back yard slowly getting dismantled and ready for engine cage and LT.
  11. Oct 10, 2017 at 9:20 AM
    #4431
    Speedo
    Sacramento, CA
    2006 dcsb 4x4
    Wrecked!
    The coils are newer then thise shocks.
    There is probably 20k on the coils and there much stiffer them stock. There just broke in really. Thats why im offering then to you.
    You would have to remove them of corse. Like i said the shocks are pretty much toast.
    KMFDM_V[QUOTED] likes this.
  12. Oct 10, 2017 at 9:41 AM
    #4432
    KMFDM_V
    Ken
    Sacramento, CA
    Sounds good, I'll take a look at my budget and see what I can offer. Do you know what they are or what they came off of, just so I can know what to expect?
    Shouldn't be too hard to mount them temporarily and remove the coils the same way I will remove my stock setup (floor jack method).
  13. Oct 10, 2017 at 9:59 AM
    #4433
    Speedo
    Sacramento, CA
    2006 dcsb 4x4
    Wrecked!
    The coils are the ones i linked above. Toy tec
    They are off my 06 sport 4x4 with lots of extra weight. I might be able to get a freind to pull them off the billys for me or i think there is a mod day coming up.
  14. Oct 10, 2017 at 12:13 PM
    #4434
    KMFDM_V
    Ken
    Sacramento, CA
    Sorry for all the confusion, that's what I get for trying to follow a thread while I'm at work. Sounds like these coils might also be too HD for my use. Either way I think I'll just replace the shocks for now and worry about the coils later. Fix one thing at a time....
    Really appreciate the offer though! :thumbsup:
  15. Oct 10, 2017 at 2:17 PM
    #4435
    Speedo
    Sacramento, CA
    2006 dcsb 4x4
    Wrecked!
    it sounds like some new billstein 5100's would suit you fine. there adjustable for height up to like 2" safely. there settings are 0", .85" ect of lift. your springs are probably fine.
  16. Oct 10, 2017 at 9:10 PM
    #4436
    FirstTimeFirstGen
    FirstTimeFirstGen Less active than most
    David
    Pacifica
    2004 4WD 3.4L Tacoma (Manual)
    Not enough to have a build thread.
    i can take those to work and pull off the coils if you guys want...
    KMFDM_V and Fernando like this.
  17. Oct 10, 2017 at 9:16 PM
    #4437
    Speedo
    Sacramento, CA
    2006 dcsb 4x4
    Wrecked!
    Deal. It will be alot easier to get rid of them.
  18. Oct 11, 2017 at 6:39 AM
    #4438
    rochmpr
    rochmpr Member
    Krister
    West SAC
    2014 4Runner TE
    I have a pair of stock Icon coil over springs (Part #158504), 650# rating available. I installed these back in December 2014 and have about 3,500 miles on them. Changed out for the 700# springs. It'll cost you your time and gas to come and get them.
  19. Oct 11, 2017 at 6:44 AM
    #4439
    KMFDM_V
    Ken
    Sacramento, CA
    Awesome, let me do a little research to make sure they are a good fit for me and I'll let you know. Picking up would be easy for me, just a matter of finding a good time. I'll PM you to confirm.
    Thanks!
    rochmpr[QUOTED] likes this.
  20. Oct 11, 2017 at 6:45 AM
    #4440
    Speedo
    Sacramento, CA
    2006 dcsb 4x4
    Wrecked!
    they wont fit stock shocks
    FirstTimeFirstGen and KMFDM_V like this.
