SOLD: Sacrifice's '93 Integra K20 Swap DA9 Build
Discussion in 'Other Builds' started by Sacrifice, Feb 20, 2017.
  1. Feb 20, 2017 at 3:07 PM
    Sacrifice
    Sacrifice [OP] Motorcycle Goon
    KS
    DCSB OR 4X4 LT
    Pelfreybilt Front Bumper,BAMF sliders, Airflow Snorkel,Mini D2S Retrofits, ADS Rear Shocks, Deaver U402 Leafsprings, 35s, AllPro +2LT
    Engine/Trans:
    2004 RSX-S K20A2 w/ 6sp Transmission (from LKQ, unknown mileage)
    ACT Street-Lite Flywheel (11lbs)
    ACT HD Clutch Kit (AR1-HDSS: 255Ft/Lb Capacity)
    K-Tuned Ram Style Header
    K-Tuned Throttle Cable & Bracket
    K-Tuned Shifter Cable Grommet
    K-Tuned Universal 3" CAI w/ Velocity Stack
    K-Tuned IAT Adapter
    Hush Performance Cable To Hydro Setup
    Innovative K-swap Mounts (75A Durometer)
    Thermal R&D 3" Exhaust
    Insane Axles Intermediate Shaft (500hp)
    02-06 RSX-S Driver Axle (Insane Axles 500hp Rating)
    06-11 Civic Si Passenger Axle, Spare Insane Axles k-swap passenger
    Jackson Racing Power Steering Pulley (p/n: 052-154) w/ Summit Racing Belt (p/n: BAN-7PK1320, 7 Rib/52.00in Length)
    Fuel:
    Karcepts Fuel Rail
    AEM Fuel Pump 320LPH, E85 Compatible (50-1220)
    Aeromotive A1000-6 FPR
    Aeromotive Inline 40 Micron Fuel Filter (SKU:12348)
    RDX Injectors
    JegsFuel Pressure Gauge
    Cooling:
    Mishimoto RSX Full Size Radiator (2 core)
    Mishimoto RSX Fan Shroud w/ E-Fans
    K-Tuned RSX Silicone Hoses
    K-Tuned RSX Fan Switch
    K-Tuned Coolant Temp Sensor
    K-Tuned Temp Sensor Adapter
    K-Tuned Heater Hose Adapter
    K-Tuned Bolt On Radiator Stays
    Suspension:
    Ground Control Special Purpose Coilovers 550F/450R lb/in springs. (consist of custom valved Koni yellow shocks, extended top hats, bumpstops, 94-01 integra front shock forks)
    K-Tuned Traction Bar
    Hard Race Front UCAs
    Hard Race Full Bushing Set
    Hard Race Rear Camber Arms
    Hard Race Rear Toe Arms
    Blackworks Racing Billet Rear Lower Control Arms
    Wheels:
    Karcepts 36mm Kswap Hubs
    LS Meshies 195/55/15
    Brakes:
    ITR Front Calipers
    Mini-Cooper Front Rotors (280mm, non-s cooper)
    TSX Front Pads
    RSX Rear Calipers
    EP3 Si Rear Rotors
    New Centric Master Cylinder (Aug-8-18)
    Electrical:
    Rywire K-swap Adapter Harness
    Hondata Kpro v4
    K-Tuned Engine Harness
    Prosport JDM Style Oil Pressure Gauge
    Ultragauge EM+
    Other:
    StrutKing Pedal Covers
    Hybrid Racing Power Steering Conversion Kit
    AutoPower 4pt Race Roll Bar
    Seibon CF OEM Style Hood
    JDP Rear Lip Spoiler
    NRG 320mm Steering Wheel w/ Quick Release 2.0 & Hub Adapter
    Original Post:
    I've now been out of the car scene since 2014 (bought my tacoma) and had been getting a random itch every once in a while to explore Craigslist when I stumbled upon this 1993 Integra LS DA9.
    The car is in pretty rough shape mechanically but the body is solid. Anyone who has owned an Integra knows how prone they are to quarter panel rust, this car has none! Interior is spotty as it is missing the carpet, bottom of the rear seat, radio. A/C isn't hooked up, nor is power steering. Needed a battery/starter.
    Plans for the car are to k-swap and just have a decent fun car to drive around and participate in track days.
    A little background: my first car was an EJ1 '94 Honda Civic which I sold after two years of ownership after I had bought a '94 Acura Integra GSR (DC2). The GSR was then stolen and stripped just a month/two after ownership but I didn't let that stop me. I picked up a '98 that was totaled and swapped every single item/bolt to the '94. Which I sold after a couple years of ownership to move onto rwd '91 240sx. Eventually turbo-d the 240sx KA24de motor to ~300hp/300tq and then blew up the motor twice. I moved on then into a 2004 350z in Lemans Sunset Orange with track package (aka brembos)
    Biscuits, GPsevinSixx, Nickel and 3 others like this.
  2. Feb 20, 2017 at 3:12 PM
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    Nice, that was my first car too.
    Tatts521, TX444, AR15xAR10 and 2 others like this.
  3. Feb 20, 2017 at 3:16 PM
    Sacrifice
    KS
    DCSB OR 4X4 LT
    $1200
    Nice. I was debating about another gen 3 but the gen 2 was calling for my name.
  4. Feb 20, 2017 at 3:19 PM
    fatfurious2
    David
    Ashburn, VA
    the issues with mine, that I remember, were leaking trunk/windshield and the motor mounts.
    AR15xAR10 and ChadsPride like this.
  5. Feb 20, 2017 at 3:26 PM
    Sacrifice
    KS
    DCSB OR 4X4 LT
    I know the sunroof drains need redone for the same reason on this one.
  6. Feb 20, 2017 at 5:01 PM
    ChadsPride
    Sponsored by TacomaWorld.com
    Subd
    Sacrifice[OP] likes this.
  7. Feb 20, 2017 at 7:05 PM
    Sacrifice
    KS
    DCSB OR 4X4 LT
    Bought a cheapy battery from O'Reillys tonight to replace the bad one. Car started the first time but the starter is still going out unfortunately. Probably pick one up tomorrow to replace just to make sure I'm good for the drive back to KS from KY this friday.
  8. Feb 21, 2017 at 8:05 PM
    Sacrifice
    KS
    DCSB OR 4X4 LT
    Starter replaced with another O'crappy special. Pretty sure it has something wrong with the solenoid as it's giving the scratch sound like it isn't being pulled out of the way. Tomorrow I'll remove and reinstall just to be sure though. Got tired of standing in the rain without light replacing it.
    AR15xAR10 likes this.
  9. Feb 21, 2017 at 8:31 PM
    Sacrifice
    KS
    DCSB OR 4X4 LT
    :cookiemonster:
  10. Feb 22, 2017 at 8:10 PM
    Sacrifice
    KS
    DCSB OR 4X4 LT
    Finally looked at how many miles are on the cluster...only 122k :bananadance:
    Pretty sure that is original to the body
    AR15xAR10, ChadsPride and 14489 like this.
  11. Feb 22, 2017 at 10:28 PM
    Sacrifice
    KS
    DCSB OR 4X4 LT
  12. Feb 24, 2017 at 9:08 AM
    Sacrifice
    KS
    DCSB OR 4X4 LT
    She got through the maiden voyage. 8hr drive and 530 miles with 1 3/4 tanks. Averaged about 24mpg with the engine running crappy like it does.
    Not sure how I didn't bottom the damn thing out on some bridge/road merges.
    I did get pulled over once for no tags, knew it was going to happen as soon as I passed the cops on the side of the road. No ticket though, and now it's tagged in ks. So let the fun begin!
    AR15xAR10, 14489 and ChadsPride like this.
  13. Feb 26, 2017 at 2:03 PM
    Sacrifice
    KS
    DCSB OR 4X4 LT
    Obligatory car and truck photo
  14. Feb 26, 2017 at 4:48 PM
    Sacrifice
    KS
    DCSB OR 4X4 LT
    :puke:
  15. Feb 26, 2017 at 4:54 PM
    Sacrifice
    KS
    DCSB OR 4X4 LT
    Just do it
  16. Feb 26, 2017 at 8:43 PM
    AR15xAR10
    2013 TRD Sport 4x4 V6 ACLBFTMFW
    As a former honda hater, I'm in :anonymous:
    ChadsPride likes this.
  17. Feb 26, 2017 at 8:46 PM
    Sacrifice
    KS
    DCSB OR 4X4 LT
    Former hater???
    Blown the fuck up
    ChadsPride and AR15xAR10[QUOTED] like this.
  18. Feb 26, 2017 at 8:52 PM
    AR15xAR10
    Former life. :oops:
    Just supporting your goofy ass
    Edit: missed a few, there ya go
  19. Feb 26, 2017 at 9:07 PM
    Sacrifice
    KS
    DCSB OR 4X4 LT
    Thanks pal :cheers:
    Should be a fun build
  20. Mar 4, 2017 at 8:29 AM
    Sacrifice
    KS
    DCSB OR 4X4 LT
    Mmmm :drool:
    So I will need front tires and an alignment so why not order a set of wheels and tires. Just need to decide if I should order a full spare or not.. opinions??
