Sacrifice's Crunchy Taco
Discussion in '2nd Gen. Builds (2005-2015)' started by Sacrifice, Jan 31, 2014.
  1. Feb 26, 2016 at 7:28 PM
    #581
    AR15xAR10
    2013 TRD Sport 4x4 V6 ACLBFTMFW
  2. Feb 26, 2016 at 8:14 PM
    #582
    Sacrifice
    Sacrifice [OP] Motorcycle Goon
    KS
    DCSB OR 4X4 LT
    Pelfreybilt Front Bumper,BAMF sliders, Airflow Snorkel,Mini D2S Retrofits, ADS Rear Shocks, Deaver U402 Leafsprings, 35s, AllPro +2LT
    Youll see when i do it
  3. Feb 26, 2016 at 10:02 PM
    #583
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Load it up like you where camping. I like rake when loaded. Bet it'll be perfect loaded
    Sacrifice[QUOTED][OP] likes this.
  4. Feb 26, 2016 at 10:06 PM
    #584
    Sacrifice
    KS
    DCSB OR 4X4 LT
    I agree. Just over-thinking it on my part. Just need to go find somewhere to flex it out and check bumps. I love the droop it had on the lift at wolf fab.
    Now you have me looking at gears now though :frusty:
  5. Feb 27, 2016 at 10:36 PM
    #585
    Blackdawg
    Monte
    Wyoming/St. Louis
    Trust me. It'll bring life back to your rig.
  6. Feb 28, 2016 at 10:22 AM
    #586
    Sacrifice
    KS
    DCSB OR 4X4 LT
    I know, its more a matter of funding cause i might as well throw the arb in the front when i do it.
    Also drove 300 miles so far and there is zero axle leak! :woot:
    SconnieHailer likes this.
  7. Feb 29, 2016 at 4:49 PM
    #587
    Sacrifice
    KS
    DCSB OR 4X4 LT
    Got an "alignment" this evening. Well i should technically say a toe correction. Cam bolts are frozen, of course.
    But good news is that my caster is way positive like wanted (still rub in reverse full lock though). Toe is corrected. Only camber is out, but its not too horrible? Road manners seem be driving straightish. Havent been on a flat road to verify completely.
    Is there any reason to worry about the passenger camber? Or rotating should take care of any small issue there would be?
    Driver:
    Camber +0.4 (within oem specs)
    Caster +4.2
    Toe +0.03
    Passenger:
    Camber -0.7 (out of spec)
    Caster +4.5
    Toe +0.04
  8. Mar 1, 2016 at 3:24 AM
    #588
    Acerwin
    Acerwin The unNORM NORM
    Andrew
    South Carolina
    Toyota Tundra
    Mine still rub when reversing at full lock on passenger side also. I might just need to hit some more though
  9. Mar 1, 2016 at 4:20 PM
    #589
    Sacrifice
    KS
    DCSB OR 4X4 LT
    Stuck in between a hard place and a rock, ugh.
    Cam bolts need to come out in order to fix the alignment or i cut them off, order new ones and get aftermarket lowers?
    Dont see any point in fighting stock bushings if the bolts have to be cut.
  10. Mar 1, 2016 at 4:25 PM
    #590
    G.T.
    G.T.
    CONUS
  11. Mar 1, 2016 at 4:27 PM
    #591
    Sacrifice
    KS
    DCSB OR 4X4 LT
    damn peer pressure, haha
  12. Mar 1, 2016 at 4:30 PM
    #592
    G.T.
    G.T.
    CONUS
    I'm just breakin' balls. New LCA's are allot of coin, and while I'm glad to have them, it did sting a little bit.
  13. Mar 1, 2016 at 4:53 PM
    #593
    Sacrifice
    KS
    DCSB OR 4X4 LT
    I know, lol.
    The only hope i could have is getting an air hammer to punch the oem bolts out which preserves the bushing/bolts. Energy bushings require the use of the oem metal sleeve (useless if the bolt is frozen to it) which pretty much requires new stock arms. Also useless with all that effort put in.
  14. Mar 1, 2016 at 6:07 PM
    #594
    AR15xAR10
    You regearing this turd?
  15. Mar 1, 2016 at 6:08 PM
    #595
    Sacrifice
    KS
    DCSB OR 4X4 LT
    I was wanting to, but it wont happen anytime soon if i have to replace the lowers.
  16. Mar 1, 2016 at 6:16 PM
    #596
    ChandlerDOOM
    ChandlerDOOM International tent trafficker
    Chandler
    STL
    Truck
    37s yo
    Have you tried adjusting them yourself?
  17. Mar 1, 2016 at 6:27 PM
    #597
    AR15xAR10
    Why don't you just go LT
    You're already Mr. OT :p
  18. Mar 1, 2016 at 6:43 PM
    #598
    SconnieHailer
    SconnieHailer PutterClutch
    Marc
    West Central Wisconsin
    2012 TRD Off Road Double Cab V6 6Speed
    Try an air chisel. Hit em with pb and let it sit for a few days too. Hard to believe they're frozen since your truck is pretty new.
    ChandlerDOOM and AR15xAR10 like this.
  19. Mar 1, 2016 at 7:29 PM
    #599
    G.T.
    G.T.
    CONUS
    See Exhibit A.
    Sacrifice[OP] likes this.
  20. Mar 1, 2016 at 7:57 PM
    #600
    Sacrifice
    KS
    DCSB OR 4X4 LT
    I tried one cam. Looksened the nut and gave it a wack with a 4lb sledge and it didnt budge. Didnt try any others yet though
    No interest in LT here.
    Yea ill probably give that a try, just have to find access to one.
    AR15xAR10[QUOTED] likes this.
