Sacrifice's Crunchy Taco
Discussion in '2nd Gen. Builds (2005-2015)' started by Sacrifice, Jan 31, 2014.
  1. Jun 4, 2017 at 5:58 PM
    #1101
    Sacrifice
    Sacrifice [OP] Motorcycle Goon
    KS
    DCSB OR 4X4 LT
    Pelfreybilt Front Bumper,BAMF sliders, Airflow Snorkel,Mini D2S Retrofits, ADS Rear Shocks, Deaver U402 Leafsprings, 35s, AllPro +2LT
    As far as truck build changes coming: I have since ordered a whynter 45qt fridge, pelfreybilt hi-lift mount, Air On Board compressor switch for under the hvac, two 5gal jerry cans off Amazon, 20ft tow strap, snatch block, 36inch plano box. Also hoping to pick up a tire gate to have somewhere to place the spare finally instead of in the bed.
    ChandlerDOOM and ChadsPride like this.
  2. Jun 4, 2017 at 6:00 PM
    #1102
    Sacrifice
    KS
    DCSB OR 4X4 LT
    still lacking the space unfortunately and with my current work traveling it doesnt make sense to delve into anything. Heard you may be buying an 80?
    We did not. Wanted to go back and run it but we will save it for next time. Also figured the escalator was the harder obstacle anyways.
    ChadsPride likes this.
  3. Jun 4, 2017 at 6:57 PM
    #1103
    Sacrifice
    KS
    DCSB OR 4X4 LT
    was a blast! need to figure out more trips
  4. Jun 4, 2017 at 7:11 PM
    #1104
    deeezy
    deeezy Well-Known Member
    Dana
    Hawaii
    2013 4x4 DC, 6 spd, TRD Sport
    King ext travel coilovers, Icon tubular UCA's Rear-King "Tundra" 2.5's, Allpro Expos, TRD cat-back, Hurst/Core short shift kit, etc...
    What did you use to pull the bumper "wings" back out? Both sides of my bumper are bent in. It doesn't bother me much, but if it was easily bent back out, then why not.
  5. Jun 4, 2017 at 7:36 PM
    #1105
    Sacrifice
    KS
    DCSB OR 4X4 LT
    just used a tow strap and a winch. wasn't able to get the original gap that there was between the hoop/headlight but a lot better.
  6. Jun 4, 2017 at 7:52 PM
    #1106
    deeezy
    Dana
    Hawaii
    Ah okay, I'll use my snatch block and winch to a tree at my house.
  7. Jun 4, 2017 at 7:55 PM
    #1107
    Sacrifice
    KS
    DCSB OR 4X4 LT
    hopefully it works. i may give it a try again when i get my snatch block off Amazon
    ChadsPride and deeezy[QUOTED] like this.
  8. Jun 5, 2017 at 11:58 AM
    #1108
    Sacrifice
    KS
    DCSB OR 4X4 LT
    Neither can I. Wasn't ready for work again this morning.
    Feel free to add anything
  9. Jun 5, 2017 at 7:12 PM
    #1109
    Sacrifice
    KS
    DCSB OR 4X4 LT
    Headlights got readjusted and fixed my compressor wiring tonight with an air on board center console switch.
    I tapped the positive/ground to one of the 12v sockets up front since the switch itself won't use much to drive a relay. Works like a charm from inside the cab now.
    Tomorrow I plan on tackling my fridge install and I should be receiving the plano, snatch block, tow strap so I will try to figure out where to place it.
    ChadsPride and ChandlerDOOM like this.
  10. Jun 5, 2017 at 7:24 PM
    #1110
    KevinTaco98
    KevinTaco98 Well-Known Member
    Kevin
    1997 3.4L Tacoma
    None yet :D
    Why do people take their mudflaps off? For cool looks or clearance or what? Just curious
    I thought it helps stop flinging mud and rocks.
  11. Jun 5, 2017 at 7:43 PM
    #1111
    G.T.
    G.T.
    CONUS
    They hate their paint.
  12. Jun 5, 2017 at 7:56 PM
    #1112
    Sacrifice
    KS
    DCSB OR 4X4 LT
    Because they break when they get caught on anything offroad anyways.
    :anonymous:
  13. Jun 5, 2017 at 9:10 PM
    #1113
    ChandlerDOOM
    ChandlerDOOM International tent trafficker
    Chandler
    STL
    Truck
    37s yo
    Doesn't matter when it only covers half of the tire, and it only covers the inside of the tire so it doesn't matter anyways
    Forgot to text you but yeah that should be good for recovery, im sure at some point you'll add along the way once you get yourself into a situation alone and wish you had more
  14. Jun 5, 2017 at 9:35 PM
    #1114
    Sacrifice
    KS
    DCSB OR 4X4 LT
    no worries. i didn't realize you had a 42 inch case till today when i was glancing. i ordered the 36 but i think at that size it will fit behind in the rear passenger cubby area at least, find out tomorrow when it arrives.
  15. Jun 6, 2017 at 2:20 PM
    #1115
    Sacrifice
    KS
    DCSB OR 4X4 LT
    I probably should have gotten the bigger box but this works for now. It doesn't fit behind the seat either so now to figure out a home for it. May end up of the roof rack eventually.
    deeezy likes this.
  16. Jun 6, 2017 at 4:11 PM
    #1116
    Sacrifice
    KS
    DCSB OR 4X4 LT
    Ah yea! Fridge is in. It fits with the seat laid down. But ill probably remove it if I like it there. Can't decide whether I should leave the fridge in full time or not.
    deeezy, ChandlerDOOM and G.T. like this.
  17. Jun 6, 2017 at 9:21 PM
    #1117
    ChandlerDOOM
    Chandler
    STL
    Truck
    37s yo
    Full time, fuck the seat
    Anyways it would drop the fridge way lower, which is a nice thing
    Jim Bob likes this.
  18. Jun 7, 2017 at 3:16 PM
    #1118
    Sacrifice
    KS
    DCSB OR 4X4 LT
    Done. A little bit more road noise I noticed today without the seat up but it wasn't too bad
  19. Jun 11, 2017 at 4:37 PM
    #1119
    Sacrifice
    KS
    DCSB OR 4X4 LT
    New taillight is installed. Looks just like stock. Also received the Jerry cans which appear to be ok quality. Definitely need rinsed out with gasoline before use since there is dirt/tiny metal shavings. The pour spout doesn't have a useful gasket though so I'll see how that works eventually. Main thing is that I'll at least have gas to spare.
  20. Jun 12, 2017 at 10:46 AM
    #1120
    Adventurer_Alex
    Adventurer_Alex Generic mall crawler
    Alex
    AZ
    2013 Nissan XTERRA
    I just got one of those boxes. I'm going to be mounting it on my rack soon. I wonder how well it will do in the sun all day every day
