Sad day
Discussion in '1st Gen. Tacomas (1995-2004)' started by Tacomaislife, Dec 29, 2019.
  1. Dec 29, 2019 at 3:30 PM
    Tacomaislife
    Tacomaislife [OP] Well-Known Member
    Texas
    2002 tacoma trd
    Well I bought a 2003 Tacoma v6 double cab and well it started smoking from the engine white smoke at first it came from all the engine then I saw some black gunk on the exhaust pipes smoking so I cleaned the engine and everything scraped the gunk of and now it just smokes from the passager side of the motor it only happens after 15 minutes after the engines is heated up I guess I got bamboozled lol but anyway do you guys think I need a new motor?
  2. Dec 29, 2019 at 3:32 PM
    Tacomaislife
    Texas
    2002 tacoma trd
    It does need a 02 sensor can that cause it
  3. Dec 29, 2019 at 3:35 PM
    Good deal
    Good deal Well-Known Member
    Texas
    Could it possibly be a leaking head gasket?
    CS_AR likes this.
  4. Dec 29, 2019 at 3:38 PM
    Tacomaislife
    Texas
    2002 tacoma trd
    idk I'm going to have it checked with machanic soon is a leaking head gasket bad I'm guessing it's going to be expensive
  5. Dec 29, 2019 at 3:40 PM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    It runs fine? Sounds like an oil leak is dripping onto some hot exhaust or something.
    It runs fine, correct?
  6. Dec 29, 2019 at 3:41 PM
    Killowatt
    Killowatt Well-Known Member
    Citrus County Florida
    2013 4x4 TRD OFF ROAD
    Started to read, but gave up.
    TWJLee, ffirg and cruiserguy like this.
  7. Dec 29, 2019 at 3:42 PM
    cruiserguy
    Elijah
    SEKS
    I had to really focus and care to get through it
  8. Dec 29, 2019 at 3:44 PM
    Tacomaislife
    Texas
    2002 tacoma trd
    Yeah
  9. Dec 29, 2019 at 3:46 PM
    cruiserguy
    Elijah
    SEKS
    May need a head gasket or head but I wouldn't say the motor is dead. You don't do any of the work yourself?
  10. Dec 29, 2019 at 3:47 PM
    Xperivent
    Xperivent Well-Known Member
    ‘24 Supersonic ORP & '04 Impulse Red DC OR
    Valve cover gasket?
    cruiserguy likes this.
  11. Dec 29, 2019 at 3:47 PM
    cruiserguy
    Elijah
    SEKS
    Wait a minute, smoke is coming out of exhaust pipe at back of truck? Or smoke is coming out engine bay?
  12. Dec 29, 2019 at 3:49 PM
    Tacomaislife
    Texas
    2002 tacoma trd
    Engine bay passager side
  13. Dec 29, 2019 at 3:50 PM
    Tacomaislife
    Texas
    2002 tacoma trd
    I'm hoping so wait i did notice the under side of the engine is covered in oil
  14. Dec 29, 2019 at 3:51 PM
    cruiserguy
    Elijah
    SEKS
    An oil leak leaking onto hot exhaust it sounds like
  15. Dec 29, 2019 at 3:51 PM
    Tacomaislife
    Texas
    2002 tacoma trd
    No just oil change and transmission oil change
  16. Dec 29, 2019 at 3:52 PM
    Tacomaislife
    Texas
    2002 tacoma trd
    I really hope so the engine sounds pretty good I was really hoping to have this truck for work
    cruiserguy[QUOTED] likes this.
  17. Dec 29, 2019 at 3:53 PM
    cruiserguy
    Elijah
    SEKS
    I meant are you gonna be fixing this oil leak causing this smoke? Or are you taking it in to have it fixed?
  18. Dec 29, 2019 at 3:53 PM
    Tacomaislife
    Texas
    2002 tacoma trd
    What do u think I should do
  19. Dec 29, 2019 at 3:54 PM
    Tacomaislife
    Texas
    2002 tacoma trd
    I was thinking about having one of this mobile machanic come to my house to check it out
  20. Dec 29, 2019 at 4:15 PM
    Area51Runner
    Area51Runner Well-Known Member
    Northern California, Bay Area
    02 3.4 DC TRD PreRunner 4WD SWAP
    After you bought it or perhaps just recently, did you change the oil yourself? Go make sure the filter is on snug (not over-tightened of course but make sure its on properly). Many, many moons ago I had the oil changed and a day or two later noticed a ton of smoke. Checked and I'm leaking oil. Oil covering everything from filter back to the rear diff. You guessed it, the oil change tech did not sufficiently tighten the filter. I gave it 1.5 turns to the right and leak gone.
