Sad New Owner
Discussion in 'Technical Chat' started by SaltH2oFisher, Oct 10, 2020.
  1. Oct 10, 2020 at 5:44 AM
    SaltH2oFisher
    SaltH2oFisher [OP] New Member
    2015 Tacoma XSP-X
    XSP
    I looked long and hard for a nice used Tacoma. I finally found a 2014 XSP-X with 160,000 miles in pretty darn good shape. I got a fair price and was thrilled the 1st few days. Now the tranny is slipping and banging hard into 2nd gear. I'm afraid I'm going to need a new transmission. I have an appointment with a Toyota mechanic in a couple days. I wanted to start my search for a transmission ahead of time , Just in case. I hope it's something simple.
    Where would you feel comfortable finding a reman or used tranny? I have the 4.0 engine.
    Hobbs and FishnTx like this.
  2. Oct 10, 2020 at 5:46 AM
    jowybyo
    jowybyo Well-Known Member
    Joe
    Baltimore, MD
    '14 MGM DCSB Postrunner 4wd Conversion, Debadged
    Car-part.com. You can find used low mileage transmissions for a reasonable price.
  3. Oct 10, 2020 at 5:47 AM
    Clearwater Bill
    Billy
    Largo Florida
    First thing to do is check the fluid level and condition. You could get lucky.
  4. Oct 10, 2020 at 7:45 AM
    ROAD DOG
    ROAD DOG Well-Known Member
    2019 I4 WHITE SR PRERUNNER
    FEW
    the mechanic thats goin in elbow deep would be my best bet
    or i would Not use him
    he should be connected enuf to provide U decent reasonable choices ( used....salvage.....reman)
    and No less get the job done right !!
    nxt time double check a 1/2 used up vehicle ..................
  5. Oct 10, 2020 at 7:48 AM
    davidstacoma
    davidstacoma Friendly Curmudgeon
    David
    NC
    2019 Tacoma SR Access cab - Utility
    *OEM Mods: Intermittent wipers, Fogs, Keyless Entry, Lomax
    How do you double check a problem that didn’t exist when he first got it?
    Naveronski and Wyoming09 like this.
  6. Oct 10, 2020 at 7:51 AM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Look at the driveshaft u joints and center bearing. I don’t believe the tranny is the problem..... yet
  7. Oct 10, 2020 at 7:52 AM
    ROAD DOG
    FEW
    there are ways to double check ANY used vehicle
    chances are prev owner KNEW trans was wonky
    no less its NOT about ‘ knowing ‘ whats wrong its about CHECKING !!!!
    BillsSR5 likes this.
  8. Oct 10, 2020 at 7:54 AM
    Hobbs
    Hobbs Anti-Lander from way back…
    Yep…
    Rock Bangen', Desert Tamin', Gold Findin' Machine!
    Welcome to The Forum! :thumbsup:
    I hope you get your issues worked out.
    G8R_Taco likes this.
  9. Oct 10, 2020 at 7:54 AM
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
    take it to a transmission repair facility
  10. Oct 10, 2020 at 7:59 AM
    BillsSR5
    bill
    2014 SR5
    its really hard to believe the transmission was working properly before he bought it, then all of a sudden its banging and slipping for no apparent reason, auto transmission issues don't just occur there are always tell tale signs that it may be having a problem before banging/slipping occur, first one would be hard to put the trans in gear or a hard clunk putting it in gear
  11. Oct 10, 2020 at 8:00 AM
    ROAD DOG
    FEW
    true dat !!
    BillsSR5[QUOTED] likes this.
  12. Oct 10, 2020 at 8:21 AM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    I'd start by making sure the fluid is at the right level before taking it to a dealer. They're going to take you for a ride as far as price goes. I'd try to avoid them at all costs. Car-part.com is a great resource for a low mileage used trans if you ultimately have to replace it like mentioned above
    TrdSurgie likes this.
  13. Oct 10, 2020 at 8:29 AM
    TrdSurgie
    TrdSurgie revised
    Oahu
    Is it an auto or manual?
  14. Oct 10, 2020 at 10:03 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    I am guessing you mean the entire truck should be disassembled and inspected with all non destructive inspection processes .
    Then any questionable parts should be brought to the sellers attention before the vehicle is allowed to be sold in any form.
    Correct??
    davidstacoma likes this.
  15. Oct 11, 2020 at 4:18 AM
    ROAD DOG
    FEW
    any used sale could be considered suspect
    which results in " Buyers Beware “ !!!
    there are toooooo any threads whereby the new owner finds themselves up to there earlobes
    in incidents....issues & trouble that known b4 the $$$$$$$$$ exchanges hand & the ink is dry
    the buyer might not close the deal
    many have been advised to have an experienced trained mechanic look a vehicle over
    wise move ........
    many have been advise to check insurance/ DMV records
    wise move ....... Car Fax comes to mind
    a good 15-20 test drive vehicle will warm up
    check out engine brakes & trans =fundamental evaluation
    some tho few have the history of vehicle in repair/ maintenance receipts
    another level o confidence
    a few suggestions/ recommendations that many would use if it were there son/daughter buying
    for U maybe NOT
    if i were compelled as U mentioned up top
    Id buy new
  16. Oct 11, 2020 at 4:31 AM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    Get it checked carefully before anyone pulls the transmission. My Honda Fit was throwing codes that indicated transmission trouble. A few days later started shifting hard and driving wonky. I was quoted $2000 for a rebuild. Less than an hour after dropping the car off at the transmission shop they called and said it was ready, come and get it.
    When they started looking around they found where mice had chewed the insulation off a wire under the hood. They repaired the damaged wire, charged me 1/2 hour labor, ($50) and that fixed the problem.
    Juice Weasel and davidstacoma like this.
  17. Oct 11, 2020 at 4:39 AM
    markm0311
    markm0311 ________________
    2000 Toyota RAV4
    Driveline/transmission shop here sourced the remanufactured transmission for me for vehicle. You shouldn’t have to worry about finding a replacement I wouldn’t think.
    Generally, if I’m buying a vehicle (no matter the vehicle) with over 150k I factor in a transmission to the sale price and ask myself is it worth it just as a rule of thumb
  18. Oct 11, 2020 at 5:49 AM
    markm0311
    2000 Toyota RAV4
    Also sorry the most important part!...to really answer your question...when I first got my transmission problem diagnosed it was at the Toyota dealership...they quoted me for a reman and new oem transmission.
    I think the OEM for my car was 5500 and the reman was around 3500. Ended up going to a different shop that specialized in transmissions
    Grossomotto likes this.
  19. Oct 30, 2020 at 4:15 PM
    outdoorgb
    outdoorgb (.)(.)
    Burbs of Oregon
    2014 DCSB TRD Sport Silver Sky...
    Assuming it is an automatic, there are easy instructions on how to just a wire in the OBD port to get a light to blink... lets operator know the trans is at temp. Then, open top plug and check. I did this the first month of owning my 2014 DSCB Sport.
