Sad taco
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Pauul_90, Aug 19, 2022.
  1. Aug 19, 2022 at 9:35 PM
    Pauul_90
    Pauul_90 [OP] Member
    Paul
    2017 toyota
    Swapped out my alternator now my truck doesn't start on push start 1st time. Cranks but won't turn over replaced camshaft position sensor #b code p0368 disconnected battery 1st still no start on 1st try any ideas
  2. Aug 19, 2022 at 9:40 PM
    Grossomotto
    Grossomotto Complete 3rd Member
    39.9526° N, 75.1652° W
    2017 4WDV6LB6MT
    Buy another one for $48K
  3. Aug 19, 2022 at 9:42 PM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    Damn I know prices of stuff have gone up a lot but 50k for an alternator is ridiculous.
  4. Aug 19, 2022 at 9:43 PM
    Grossomotto
    2017 4WDV6LB6MT
    Supply chains
    AxisCab, Mully, Tacospike and 2 others like this.
  5. Aug 19, 2022 at 9:44 PM
    T-Rex266
    T-Rex266 SpaceX Director Moderator
    Elon
    How did it come up with a camshaft error over an alternator replacement?
    Chew, Junkhead, Key-Rei and 2 others like this.
  6. Aug 19, 2022 at 9:46 PM
    Grossomotto
    2017 4WDV6LB6MT
    Where the hell did you come from Elon? You're crossed out!
  7. Aug 19, 2022 at 9:48 PM
    T-Rex266
    Elon
    First I take Twitter, then I take TW.
    AxisCab, Tacospike, Toyko Joe and 5 others like this.
  8. Aug 19, 2022 at 9:48 PM
    Superdave1.0
    Superdave1.0 Grandma Dave
    SoCal
    LX470, 2025 Civic Si
    What exactly lead you to replace the alternator?
    Battery connections tight?
    How many Volts do you have at battery?
  9. Aug 19, 2022 at 9:49 PM
    Grossomotto
    2017 4WDV6LB6MT
    Hold on, I have to think about this
    T-Rex266[QUOTED] likes this.
  10. Aug 19, 2022 at 9:55 PM
    Grossomotto
    2017 4WDV6LB6MT
  11. Aug 20, 2022 at 12:40 AM
    Pauul_90
    Paul
    2017 toyota
    Alternator was rattling badly like you can hear the knocking sound super embarrassing to be driving around like that. The Alternator wouldnt spin like normal i guess the bearing inside were shot out. Replaced it then installed the new one. Pushed the start button but wouldn't start on the 1st try. Then my check engine light came on along with Trac off....plugged in the obd scanner and that code came on for the camshaft position sensor. Replaced that as well. Then tried again to start it up...
    My truck wants to turn on but won't just keeps cranking over an over. Idk if it'll be the camshaft sensor or what
  12. Aug 20, 2022 at 9:13 AM
    Superdave1.0
    SoCal
    Did you disconnect the battery b4 replacing the alternator?
    A mistake was made somewhere, or a fuse blew, or the new alternator could be bad.
    What brand alternator?
  13. Aug 20, 2022 at 10:39 AM
    JTfromWV
    JTfromWV Active Member
    WV/VA border
    2022 AG TRDOR 6mt
    Check the connectors on your sensors. You may have knocked one of them loose.
  14. Aug 20, 2022 at 1:43 PM
    Pauul_90
    Paul
    2017 toyota
    Rechecked all connectors everything is all plugged in nothing is pinched. Oriellys brand don't remember name. All fuses are good. Double checked those as well. Going to swap out crankshaft sensor today
  15. Aug 20, 2022 at 1:55 PM
    TA2016
    TA2016 Well-Known Member
    Oregon
    2016 TRD Sport AT V6 4x4 ACLB P&T Package Red
    Put the old noisy alternator back in. If the truck starts, take the new alternator back to the store and get a different new alternator.
  16. Aug 20, 2022 at 2:00 PM
    Pauul_90
    Paul
    2017 toyota
    Old one is long gone
  17. Aug 20, 2022 at 2:06 PM
    jmneill
    jmneill Well-Known Member
    SE
    2018 Tacoma Sport ACC CB Inferno
  18. Aug 20, 2022 at 2:22 PM
    brandon78lusch
    brandon78lusch Well-Known Member
    Brandon
    East Carolina University
    2019 TRD Sport DCSB, 1978 Pontiac Firebird Trans Am
    that sounds very important
  19. Aug 20, 2022 at 2:38 PM
    Superdave1.0
    SoCal
    Made that mistake myself once. Sparks were flying lmao. Good thing it was a 90's honda civic, didn't even blow the fuse.
    skeletron and SandyTaco4x4 like this.
  20. Aug 20, 2022 at 3:20 PM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    With all due respect, stop playing swap-a-part, that’ll end up costing you more time, money, and frustration in the end. Get it to an actual tech to properly diagnose, it’ll be cheaper than spinning the wheel at the parts store or having the internet play guessing games with your time and money.
    snakeplissken and TexasWhiteIce like this.
